Old 04-02-2012, 12:15 PM   #1
Nothinspecial
Nothinspecial is an unknown quantity at this point
lexan rear windows
Ive been searching the forum for a while and cant find much on it. All im wanting to do is replace the side and rear window. Ive found where someone just went to home depot for the lexan and cut to fit it.
I was just wondering what process would need to be done for the rear? Should i do it in 2 pieces?
anyways thanks for any advice.
flame on! lol
Nothinspecial is offline   Reply With Quote
Old 04-02-2012, 11:06 PM   #2
Nothinspecial
Anyone even seen an article on this?
Old 04-03-2012, 08:26 AM   #3
conrad_s13.5
conrad_s13.5's Avatar
conrad_s13.5 is making a name for him/her selfconrad_s13.5 is making a name for him/her self
like,..the whole rear window?
ive never seen it done it 2 pieces. Just take measurements that will obviously fit,. and cut to shape. Think i hear of some people heating it up to 'shape' it slightly.
i have seen people add gusset type things down the middle just to give it a little rigidity.
.....again tho, ive never done it,. anytime i asked people about it tho, they explain it as if its no big deal and i was over thinking it..hahha
cONtRol FReAkS
conrad_s13.5 is offline   Reply With Quote
Old 04-03-2012, 08:43 AM   #4
JFoxx
JFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choices
ok.....this was a fun project a while back......
look up a plastics company in your area.....ask them for polycarbonate.... lexan is just a brand name.... this will save you some money..... make a template from your existing windows to trace onto the polycarbonate sheet.... the only way to shape it is by putting the sheet on a clamped mold then putting it in an oven. using a heat gun will work breifly in small areas, but as soon as it cools it straightens back out..... there are several ways to cut the sheet, find out what works best for you. i used a jigsaw, then polished the edges with a torch CARFULLY! for the rear window you will definately need a brace(s) i used 2 1"x1/8" strips to brace. i riveted the window on placing a small bead of silicone to seal it.... if you want it to lokk better, paint the black border on the inside, before mounting..... here is a picture of my rear window before i did the sides.......
it is pretty easy to do....
*edit* if you use a similar brace, make sure you cut it long and bow it into place... it will probably take 2 people to do this.....
hope this helps! good luck!
JFoxx is offline   Reply With Quote
Old 04-03-2012, 10:35 AM   #5
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
i don`t know if the rear s13 hatch window is still available, but DRIFTSPEED used to carry them.
rcdad123 is offline   Reply With Quote
Old 04-03-2012, 10:43 AM   #6
sofargone561
sofargone561 is an unknown quantity at this point
^ i just check they have it in stock and its on sale
sofargone561 is offline   Reply With Quote
Old 04-03-2012, 10:53 AM   #7
BTplaya
BTplaya's Avatar
BTplaya is an unknown quantity at this point
Nice! Can prob save a bit of weight pulling that glass out.
95' S14 w/ SR20DET - 412hp
BTplaya is offline   Reply With Quote
Old 04-03-2012, 11:54 AM   #8
Nothinspecial
forgot to mention its for a coupe lol. but im sure its about the same idea.
Old 04-03-2012, 11:59 AM   #9
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
Send a message via AIM to hOngsterr
y u no put plexi on QP glass.
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
hOngsterr is offline   Reply With Quote
Old 04-03-2012, 12:22 PM   #10
TheRealSy90
TheRealSy90's Avatar
I found a place in Japan that carried lexan coupe windows but they were very expensive.
Such a good signature.
Old 04-03-2012, 12:40 PM   #11
Nothinspecial
i figured making your own wouldnt be that hard. just some good cuts and being real gentle with the mounting part because you dont want it to crack.
anyone have any idea what the rear window of a coupe weighs?
Old 04-03-2012, 02:39 PM   #12
JFoxx
i put in the post that these pics were taken before i got to the quarter glass..... i did do those.....
please do not buy the pre-cut ones...... it is really easy to do and costs 1/4 the price.......
Old 04-03-2012, 03:00 PM   #13
Black240Ct
Black240Ct will become famous soon enoughBlack240Ct will become famous soon enoughBlack240Ct will become famous soon enough
Send a message via AIM to Black240Ct
get hte glass and bend it around your glass rear windsheild.. once its out trace, cut and rivet it on
dont think home depot has the correct stuff.. but as mentioned before fine a plastic company.
and dont wash with windex.. bad news
Black240Ct is offline   Reply With Quote
Old 04-04-2012, 09:02 AM   #14
conrad_s13.5
jfoxx....awesome stuff
gracias
cONtRol FReAkS
Old 04-04-2012, 09:14 AM   #15
JFoxx
gracias
no problem..... glad i could help....the only difficult part is when you do your front side windows, you have to fabricate window frames for them.....
Old 04-04-2012, 06:15 PM   #16
Nothinspecial
So is heating them to fit with a heat gun impossible? Never tried to shape lexan before
Old 04-04-2012, 11:47 PM   #17
JFoxx
heating it will bend it temporary.... but as it cools it will straighten back out.... the only way to shape it like your stock windows is to place it on a mold and bake it in a huge oven.....
Old 04-05-2012, 12:13 AM   #18
Nothinspecial
does it look retarted if skip the baking part? does it look too flat?
Old 04-05-2012, 06:30 AM   #19
JFoxx
not at all, i didnt bake mine......but the only way to mount it without baking it is with rivets...... baking is only required if your trying to mount it like stock windows.........
polycarbonate is flexible...long as you support the rear window, when you mount with rivets the window will take the stock curve very nicely
Old 04-05-2012, 08:04 PM   #20
Nothinspecial
hell yeah. thanks for the tips!
Old 04-20-2012, 05:12 PM   #21
Nothinspecial
so just to let anyone know the rear glass on a s13 coupe doesnt weigh as much as i thought. maybe 5-10lbs.
Old 04-20-2012, 05:38 PM   #22
Def
Just for reference, the S13 hatch glass is HEAVY. Someone with a shipping scale weighed a stock rear hatch at 56 lbs, I took the glass out of mine and cut a bit of the skeleton out (about 1.5 lbs), and mine weighed 25.5 lbs. So about 30 lbs or so. I believe it. I collected about half the glass after it shattered and it was around 14-15 lbs. It's about 3/16" thick.
DEFSPORT
Old 04-20-2012, 05:45 PM   #23
Duke89
Duke89 is an unknown quantity at this point
So there isn't rly much point in replacing the glass in a coupe
Duke89 is offline   Reply With Quote
Old 04-20-2012, 06:13 PM   #24
Nothinspecial
i would say no unless your trying to shed every bit you can.
