Old 12-21-2001, 12:33 AM   #1
s13cruzer
s13cruzer is an unknown quantity at this point
ok , i'm kinda new to this but have big plans for the future , but first , where is the #### speed limiter on my car and how do i get rid of it safely?
                          '90 240sx fastback
s13cruzer is offline   Reply With Quote
Old 12-21-2001, 12:45 AM   #2
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
I'm not sure if there is a way for SOHC's to disable the speed limiter.  At least, it isn't documented.  For info on the DOHC speed limit cut check
http://www.240sx.org ,
it's in the FAQ.
Maybe you can see if your ECU has the same wire color/stripe and position.  If it doesn't have both, I wouldn't mess with it.
The other way to get rid of it would be the Apexi Rev/Speed meter.  At least I've heard it intercepts the speed signal and disables the governor by "tricking" the ecu.
AceInHole is offline   Reply With Quote
Old 12-21-2001, 01:17 AM   #3
240booster
240booster is an unknown quantity at this point
<a href="http://www.zilvia.net/forum/topic.cgi?forum=1&topic=1619&start=0
I" target="_blank">http://www.zilvia.net/forum....t=0
I</a> just did it man make sure u cut the right wire and u will be ok although im not sure about this for the SOHC mine is a DOHC s14
240booster is offline   Reply With Quote
Old 12-21-2001, 02:08 PM   #4
LanceS13
AutoX Junkie
LanceS13 is making a name for him/her selfLanceS13 is making a name for him/her self
I cut that wire on the ecu and now instead of the engine just quitting at 5100rpm (5th gear) it starts vibrating violently (rev limiter) at 5200rpm. &nbsp;I does the same in fourth gear (different rpm limiter--6300? forgot). &nbsp;So I probably gained a whole 3 mph top speed from doing this. &nbsp;Where is that backup limiter? &nbsp;And how are you (240booster) hitting 125?
LanceS13 is offline   Reply With Quote
Old 12-22-2001, 02:33 AM   #5
240booster
welll urs is an s13 so maybe a little different than my s14 but im hitting the same 5th gear rev limiter ur talking about at about 5500 rpm i think and my speedo only goes to 120 so im guestimating im topping out at about 125 now .... &nbsp; there is a FAQ at 240sx.org about that 5th gear rev limiter u have to disconnect some plug at the tranny i think and something else check it out ... then the sky should be the limit .... lol untill u blow ur motor &nbsp; :-P
