Old 04-22-2012, 06:30 PM   #1
mystacarlo
mystacarlo is on a distinguished road
SR Fuel pump selection
What fuel pumps are you guys using for your sr20det setups?
I currently have a walbro 255lph, but im gonna upgrade, im stuck between the aeromotive stealth 340lph and the bosch 044 300lph, what has been everyones experience with pumps?
mystacarlo is offline   Reply With Quote
Old 04-22-2012, 08:46 PM   #2
jr_ss
Why upgrade? Do you need the additional flow? Are you making over 450hp?
Old 04-22-2012, 09:02 PM   #3
JDM SPUG
JDM SPUG is an unknown quantity at this point
Bosch 044 FTW!!!
1998 240sx 2jz swap in progress
2006 FULLY built WRX Rotated w/ PPG's
JDM SPUG is offline   Reply With Quote
Old 04-22-2012, 09:14 PM   #4
om3ga
om3ga's Avatar
om3ga is an unknown quantity at this point
i hear shitty shit about the Aeromotive for some reason.
om3ga is offline   Reply With Quote
Old 04-22-2012, 09:15 PM   #5
RZRSHARP_240SX
RZRSHARP_240SX's Avatar
RZRSHARP_240SX is an unknown quantity at this point
I just switched from the walbro 255 to the 340lph stealth. I ran into flow issues around 375whp on my s13 sr
RZRSHARP_240SX is offline   Reply With Quote
Old 04-22-2012, 09:19 PM   #6
mystacarlo
shootin for 400whp for pump gas/meth, and 550whp for high boost c16
Old 04-22-2012, 09:23 PM   #7
Seraphim38
Seraphim38's Avatar
Seraphim38 is an unknown quantity at this point
Send a message via ICQ to Seraphim38
they are two different animals, with respect to how they work and how they should be configured. The Bosch is a great pump but because of the design you need a fuel filter before and after the pump, as the 044 can displace particles into your fuel. It is a tried and true, reliable pump. The Aeromotive on the other hand is quite impressive on it's output readings and doesn't require a fuel filter after the pump. I have run both a dual external walbro setup and a single Aeromotive stealth 340 pump, and I am currently running the Stealth 340.
Seraphim38 is offline   Reply With Quote
Old 04-22-2012, 09:28 PM   #8
mystacarlo
i was gonna keep a walbro in the tank and run the bosch inline if i decided to go with the bosch, which maybe my route with more research, im jus not liking what im reading about the aeromotive pump
Old 04-22-2012, 09:31 PM   #9
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
While nothing wrong with the switch, I'm surprised you had issues at that powerlevel with a 255 (unless it wasn't a HP one). Heck a single 255 should be sufficient for 450whp.
O/P, don't forget to consider the line size as well.
Old 04-22-2012, 09:33 PM   #10
jr_ss
My current setup is a walbro to surge tank, surge tank to 044, 044 to 1000cc ID injectors. Should be good for 700hp. Twin walbro's will get you what you need. I think your only choice really is a big external or twin internals. Twin wallys are known to be good for serious power. My buddy has twin wallys running 600+ on pump and 800+ on race.
