Old 04-23-2012, 04:38 PM   #1
brokeAs240sx
brokeAs240sx's Avatar
Trader Rating: (40)
brokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond repute
Feedback Score: 40 reviews
Precision Turbo GT2576rs (T2 style - Garrett Internals); Oil Coolers, Down Pipe
Local Pickup for most items (heavy or big items). Orange County area. Shipping for smaller items.
Turbo Exhaust Side
Precision Turbo GT2576rs (Garrett Turbo customized by Precision). Exhaust turbine housing professionally coated w/ high temp coating. Comes with HKS internal wastegate. No oil/coolant fittings. Only bad part is the area on the housing by the internal wastegate is slightly cracked (on the inside, not visible from the wastegate flap side - doesn't affect anything; common issue on majority of Garrett t2/t3 internal gate housings). Bought from another member on the boards. Used only for test-fit/coating bedding aka idling. No noticeable shaftplay. Spins smooth. Turbo & Wastegate only. $700 obo.
May need some adjusting/reclocking to fit perfect in your application. If using the HKS wastegate, may need to reweld/move the bracket for better fitment (or reclocking).
Trust/GReddy SR20 Downpipe - $80 picked up. $110 shipped.[/b] Small dent (pictured on bottom on SR pipe) from hitting speed bump or whatever, works fine otherwise. Pretty sure it's 2.5"/2.75" inlet, 3" outlet.
Cooling
Mopar Transmission Cooler (part # T548AB0303 - looks like for a PT Cruiser) (can be used as tranny cooler - worked great on my KA24DE auto tranny or power steering cooler if you really wanted) - 3/8" inlet/outlet. $50
RX-7 (big one) oil cooler. Cooler converted to -10an. No rubber brakets/bushings (broke when I removed them). Not daily driven. $80 obo
Video
Video showing the little/no shaft play from the turbo (password is qvturbo:
This is a password protected video on Vimeo
Some Pics
Most recent pics:
Garrett Stamp on turbo
Turbine housing
Exhaust housing
Exhaust housing (rear view)
Exhaust housing showing wastegate flap open
Older pics...
Trust SR20/KA24DE downpipe:
Dark area in picture below is the "dented" area.
RX7 Cooler:
Transmission Cooler:
bew bews!
brokeAs240sx is offline   Reply With Quote
Old 05-01-2012, 06:15 PM   #2
brokeAs240sx
Trader Rating: (40)
up up and away
bew bews!
Old 05-10-2012, 03:48 AM   #3
brokeAs240sx
Trader Rating: (40)
2nd bump...
bew bews!
