Old 05-01-2012, 01:05 AM   #1
Deimos
Deimos is an unknown quantity at this point
Help 75amp fuse blowing!
Hi Everyone,
I've tried everything suggested online and i still cant seem to figure it out. A quick overview.... When alternator is wired up and i connect negative wire to battery the fuse blows. If Alternator is not hooked up all electronics work fine. I have everything hooked up correctly and in the proper place. Im willing to pay $$$ for someone to come out and give me a hand. I live in New Lenox, IL.
*Note* I am not the best with cars but am learning.
Deimos is offline   Reply With Quote
Old 05-01-2012, 01:31 AM   #2
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
http://zilvia.net/f/tech-talk/450811...e-blowing.html
Old 05-01-2012, 08:43 AM   #3
JDMRIDDAZ
JDMRIDDAZ's Avatar
JDMRIDDAZ is an unknown quantity at this point
There's supposed to be a platic washer in between alt housing and 12v postive loop that goes to alt..
If its not there then alt power is grounding out
Wrong section also
シチサn w/ka20det:in progress
シチサnw/sr20det:stolen
JDMRIDDAZ is offline   Reply With Quote
Old 05-01-2012, 10:06 AM   #4
Deimos
Wrong section also
Its there. I know this is the Want to buy section. My title is a bit misleading i should of titled it better. But i do want to buy someones help, to come to my house and help fix my problem.
Old 05-01-2012, 10:11 AM   #5
Deimos
Originally Posted by KiLLeR2001 View Post
Im having the exact same problem. Thanks for the link ill try out what you said.
Old 05-01-2012, 11:12 AM   #6
runthatsht
runthatsht's Avatar
runthatsht is an unknown quantity at this point
i had same problem
was the wire to the alt.
pull off and inspect
runthatsht is offline   Reply With Quote
Old 05-01-2012, 11:30 AM   #7
lilrusty
lilrusty's Avatar
Trader Rating: (37)
lilrusty is an unknown quantity at this point
Feedback Score: 37 reviews
Make sure you are connecting the ground correctly on the alternator, people think that both small threaded holes are for ground....
lilrusty is offline   Reply With Quote
Old 05-01-2012, 12:11 PM   #8
MiSuNdErStOoD
MiSuNdErStOoD's Avatar
MiSuNdErStOoD is an unknown quantity at this point
Originally Posted by Deimos View Post
Hi Everyone,
Sounds like a gground shorting out for sure. Take some high quality pictures of that entire area and I can promise one of us here will be able to help you work it out. Is this on a s13 or s14? You can pm me or email. I will talk ya through it.
Wheels in sig pic forsale. Rear 18x12.5 - 12 fronts are 18x10.5 - 10.
MiSuNdErStOoD is offline   Reply With Quote
Old 05-02-2012, 03:10 AM   #9
nissan240
nissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to all
try switching the two wires on the alt. around. that is what usaully happen when you the two wires are switched. one is ground the other is something else
nissan240 is offline   Reply With Quote
Old 05-02-2012, 10:17 AM   #10
Deimos
Im using a KA alt, which only has one threaded hole and i had a guy tell me that was the right one cuz i made a post with pictures awhile ago. However when i put my old sr20 alt on there are 3 threaded holes, only one of them is near the others and is an 8mm hole so i am possitive that is the one. my ground wire wouldnt even reach to the others. I am thinking its the possitive wire that connects the the alt has a short, need to investigate.
Old 05-02-2012, 10:18 AM   #11
Deimos
ok give me a few days im a bit busy to do it now. Ill show pictures of how i have both alternators hooked up.
Old 05-02-2012, 12:34 PM   #12
traxx07
Trader Rating: (63)
traxx07 is an unknown quantity at this point
Feedback Score: 63 reviews
If you have a 75 that you can blow then put it on have someone else put the negative cable on and you watch the alt to see where it is sparking. Mine did that and I found the problem.
traxx07 is offline   Reply With Quote
Old 05-02-2012, 07:12 PM   #13
JDMRIDDAZ
JDMRIDDAZ's Avatar
its hard to mix them up ground is blk wire
and 12v is a wht wire and should have a boot on it
Old 05-03-2012, 10:10 AM   #14
Deimos
Exactly, lol
75amp fuse, alternator, short
