Old 04-24-2012, 08:56 PM   #1
jarend
jarend's Avatar
jarend is an unknown quantity at this point
LOTSSS of S13 sr20det parts you need! *San Diego*
MORE PARTS COMING, STAY TUNED..
NOT DESPERATE TO SELL, BUT EVERYTHING MUST GO! MAKE OFFERS!!
Long story short. Had a friend of a friend do the machine shop work on my black top s13 sr20det, sleeved it for me and it was done wrong.
Here is a rough list of what was installed and never ran, some parts are used but all are in perfect working condition. All prices are picked up in San Diego. --
S13 Rear Upper Control Arm (No Name Brand) - $50
S13 sr20det Coil Pack Cover - $20
S13 sr20det HKS 1.2 mm Metal Head Gasket (Bolted on, never ran.) - $160
S13 sr20det Main Cap Girdle - $20
S13 sr20det OEM Rocker Arm (8) - $40
S13 sr20det Flex Plate - $30
Q45 Throttle Body in good condition - $80
300zx TT 260 LPH Fuel Pump (Walbro's are 255 LPH) - $70
Arias 87.5 mm Pistons very lightly used from previous owner. - $350
Phase 2 MotorTrend Rocker Arm Stoppers - $50
OEM S14 Water Pump Unused - $50
Altima Electric Fans - $40 *Pick Up Only*
S13 sr20det Stock Flywheel - $50
S13 sr20det Stock Clutch Fan *Crack on two of the fins* - $5
Mishimoto Black Front Mount Intercooler and piping complete with couplers, hardware, hotpipe and Greddy Knockoff BOV (COLD PIPE IS CUT TO FIT GREDDY STYLE INTAKE MANIFOLD) - $250 *Pick Up Only*
Set of four (4) Sportmax 006 wheels and tires for sale. The two rear wheels are 18" x 9.5" and the fronts are 18" x 8.5". The lug pattern is 4 x 100 AND 4 x 114.3. The rear wheels are wrapped in 275/35/18 Nankang Ultra Sport NS-II tires while the fronts are 245/40/18 with the same tires. Tires have ~3k miles. - $650 *Pick Up Only*
S13 Harness Bar, Easy Install and Mounts very well! - $160
Unused S13 sr20det ISIS downpipe - $80
S13 sr20det Unused ISIS Cast Top Mount Turbo Manifold - $120
S13 sr20det Oil Dip Stick and Dip Stick Tube Brand New from FRSport - $40
S13 sr20det Valve Cover Shaved down and painted a dark blue (could use a touch up) - $50
SOLD STUFF -
S13 sr20det Freddy Intake Manifold - SOLD
S13 sr20det Unused Timing Chain Kit - SOLD
S13 sr20det Coil Packs (4) - SOLD to datm3
S13 sr20det Transmission NO GRINDS SHIFTS PERFECTLY - SOLD to destruck
S13 sr20det Unorthodox Crank Pulley (Bolted on, never ran) - SOLD
S13 sr20det Crank Shaft - SOLD to roman21716
S13 sr20det Stock Alternator around 60k - 70k miles came off a running sr - SOLD
Synapse Synchronic BOV welded to s13 sr20det hotpipe - SOLD
S13 sr20det Power Steering Pump Bracket - SOLD
S13 sr20det OEM Power Steering Pulley - SOLD
300zx N62 MAF (Orange Sticker) - SOLD to greenwood
S13 Strut Bars Front and Rear - SOLD locally
S13 sr20det Stock MAF Sensor - SOLD to nissansilviasr20
OEM S13 sr20det Water Pump *Came off a running car, worked perfect* - SOLD to znismspeed
S13 sr20det Mishimoto Starter ~2k miles - SOLD
Sentra SER SPEC V GOLD Brembo's that are fully loaded with brand new rotors, nearly new pads and lines. This is a bolt on upgrade for S13 and S14. FULL FRONT BBK - SOLD to nismojunkball
S13 sr20det Unused Koyo Aluminum Radiator - SOLD to randps13
S13 240sx Apexi N1 32 Way Adjustable Coilovers ran for ~3k miles - SOLD to kauaiboy808
No Name Oil Catch Can Polished Silver - SOLD to znismspeed
S13 sr20det Unused Nismo Low Temp Thermostat - SOLD to outlawstar1023
HKS Step 2 Intake and Exhaust Camshafts - SOLD
HKS Adjustable Cam Gears - SOLD
S13 sr20det Crank Angle Sensor - SOLD
Pauter Rods lightly used from previous owner - SOLD to DriftNinjah
S13 sr20det Black Top Valve Cover - SOLD to bladetech8
Pics of everything I was able to get to.
Pictures by ohhfasho - Photobucket
LET ME KNOW IF YOU NEED ANY STOCK PARTS, HAVE A TON OF STUFF.
Call/Text me at 858 822 9613 for fastest response, I'm not on here as often as I used to be.
Can get pictures of whatever you are interested in.
-Thanks
Jaren D.
jarend is offline   Reply With Quote
Old 04-24-2012, 09:57 PM   #2
Awwllll_Day89
Awwllll_Day89 is an unknown quantity at this point
pmmered....
Awwllll_Day89 is offline   Reply With Quote
Old 04-24-2012, 10:20 PM   #3
outlawstar1023
outlawstar1023 is an unknown quantity at this point
Send a message via AIM to outlawstar1023
Money sent for Nismo thermostat.
outlawstar1023 is offline   Reply With Quote
Old 04-25-2012, 07:09 PM   #4
jarend
jarend's Avatar
Payment received. Shipped out this morning via USPS.
Old 04-25-2012, 07:20 PM   #5
ReLiC
ReLiC is an unknown quantity at this point
Happen to have a stock s13 sr airbox? If so, pm me.
ReLiC is offline   Reply With Quote
Old 04-25-2012, 09:49 PM   #6
pejsa
pejsa is an unknown quantity at this point
pm'd bout the coilovers
pejsa is offline   Reply With Quote
Old 04-25-2012, 11:06 PM   #7
jarend
jarend's Avatar
No stock airbox, sorry.
Old 04-25-2012, 11:08 PM   #8
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
so you have new eagle rods for $250?
PM me, ill pick em up next week for sure
R@ddy is offline   Reply With Quote
Old 04-26-2012, 09:07 AM   #9
jarend
jarend's Avatar
Not sure where you read that. I have Pauter Rods that will fit a S13 sr20det for $350. Pretty firm considering they are $900 new.
Old 04-26-2012, 11:03 AM   #10
2LiterTurbo
2LiterTurbo's Avatar
2LiterTurbo is an unknown quantity at this point
Pics of the valve cover??
2LiterTurbo is offline   Reply With Quote
Old 04-26-2012, 11:14 AM   #11
jarend
jarend's Avatar
Call or text me at 858 822 9613 for pics.
Old 04-27-2012, 10:59 AM   #12
jarend
jarend's Avatar
Replied to all pm's. Getting pictures of the mounting points for the Harness Bar today as well as the Stock Clutch Fan and a few other parts. Call or text if you have any other requests!!
Old 04-27-2012, 10:55 PM   #13
jarend
jarend's Avatar
Sorry to those who were interested in the Harness Bar, wasn't able to get pictures of mounting points today, will try my best to get them for you guys tomorrow.
Sold the Koyo Radiator and Mishimoto Starter today.
Thanks Zilvia.
Old 04-29-2012, 06:26 PM   #14
znismspeed
znismspeed is an unknown quantity at this point
S13 water pump and catch can sold!
znismspeed is offline   Reply With Quote
Old 04-29-2012, 10:57 PM   #15
jarend
jarend's Avatar
Payment received. Will ship out tomorrow morning.
Thanks.
Old 04-30-2012, 08:30 PM   #16
jarend
jarend's Avatar
Thanks Zilvia.
Have pictures of the Harness Bar as well as mounting points. Other stuff too, check it out. Pictures by ohhfasho - Photobucket
Thanks.
Old 05-03-2012, 10:59 PM   #17
jarend
jarend's Avatar
Going to take off the coilovers and Brembo's tomorrow morning and they're selling Sunday, will let everyone else who was interested know what happens with all that! Thanks for all the interest in everything.
Old 05-03-2012, 11:12 PM   #18
chaosxsteve
chaosxsteve is an unknown quantity at this point
Hi do you have complete chuki fender extensions? If you do would you ship to 92553? And how much thanks also looking for mud flaps if you have them how much pm me if you have any of these thanks
chaosxsteve is offline   Reply With Quote
Old 05-05-2012, 04:03 AM   #19
jdmspooge
jdmspooge's Avatar
Trader Rating: (39)
jdmspooge has a spectacular aura aboutjdmspooge has a spectacular aura aboutjdmspooge has a spectacular aura aboutjdmspooge has a spectacular aura aboutjdmspooge has a spectacular aura aboutjdmspooge has a spectacular aura about
Feedback Score: 39 reviews
I need a working t25 off an sr. Lmk i can pick up asap!
jdmspooge is offline   Reply With Quote
Old 05-05-2012, 12:23 PM   #20
jarend
jarend's Avatar
No and no unfortunately.
Old 05-05-2012, 12:24 PM   #21
jarend
jarend's Avatar
Bah, the T25 is looonng gone.
Old 05-05-2012, 01:34 PM   #22
lewisfk
lewisfk's Avatar
lewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond repute
^^ i have one and im in Oceanside, ca
Hey i need the dip stick set setup!
lewisfk is offline   Reply With Quote
Old 05-05-2012, 08:21 PM   #23
DriftNinjah
DriftNinjah is an unknown quantity at this point
Still have the Pauter Rods?
DriftNinjah is offline   Reply With Quote
Old 05-06-2012, 02:20 PM   #24
jarend
jarend's Avatar
Still have the dipstick and tube. Give me a call at 858 822 9613 if you want to come pick them up.
Old 05-06-2012, 04:52 PM   #25
DriftNinjah
Payment sent for The rods! Thanks man.
Old 05-06-2012, 07:05 PM   #26
kauaiboy808
kauaiboy808 is an unknown quantity at this point
Apexi coilovers sold to me, very nice. thanks
kauaiboy808 is offline   Reply With Quote
Old 05-06-2012, 07:10 PM   #27
Bound
Bound is an unknown quantity at this point
pm'd about the alternator !
Bound is offline   Reply With Quote
Old 05-06-2012, 10:45 PM   #28
jarend
jarend's Avatar
Shipping first thing in the morning. Thanks again.
Old 05-07-2012, 05:55 AM   #29
bladetech8
bladetech8's Avatar
Trader Rating: (32)
bladetech8 is an unknown quantity at this point
Payment sent for the stock S13 Blacktop SR20DET valve cover!
Thanks!~
bladetech8 is offline   Reply With Quote
Old 05-07-2012, 08:28 AM   #30
jarend
jarend's Avatar
Thanks!~
Payment received. Going to get that shipped out this morning, thanks.
