Old 05-07-2012, 02:39 PM   #1
focused
focused's Avatar
focused is a jewel in the roughfocused is a jewel in the roughfocused is a jewel in the roughfocused is a jewel in the roughfocused is a jewel in the roughfocused is a jewel in the roughfocused is a jewel in the rough
Send a message via AIM to focused
95' S14.5 - Well Rounded Build
After owning this car for almost 10 years and spending countless hours on it I am ready to move on. This car was built with lots of planning and consideration in making it a well rounded car. It has seen a lot of street driving and track days (grip).
Looking to sell, not interested in trades. More info, pics & such below:
161k on chassis. Aprox. 75k miles on S13 Redtop SR.
Quick Facts
• Purchased car in 2002 w/ ~87k miles
• SR swap done in 2005
• Front end collision in 2005.
o Core support replaced
o Dash & airbags replaced
o S15 front end conversion done
• 2-5 Track Day events per year since 2005. (road race)
• Well sorted & reliable car.
Engine
• SR20DET Redtop (swapped in 2005)
o Aprox. 70k miles currently
o Timing Chain Set (Winter 2011)
• K&N Filter & 3” Intake
• Garrett GT28RS
o (Polished compressor housing; Ceramic coated exhaust housing)
• Greddy V-SPL Front Mount Intercooler
• Upgraded silicone couplers & t-bolt clamps
• Blitz Dual Drive BOV
• Greddy Manual Boost Controller
• Koyo Dual Row Aluminum radiator
• Black silicone radiator hose set
• Coolant hoses under intake manifold replaced last year
• Waterpump replaced in 2009
• Shaved valve cover in wrinkle black
• Media blasted & clear coated intake manifold
• Rebuilt Alternator
• All new exhaust manifold studs (winter 2011)
• Megan racing turbo manifold
• Megan 3” turbo outlet
• 5-Zigen 3” downpipe
• HKS Hi-Power Catback Turbo version (3”)
• 3” Test-pipe with bung for Wideband
• SARD fuel pressure regulator
• NGK sparkplugs
• Apexi SAFCII
• Mines Tuned ECU
• Walbro 255 fuel pump
• Working AC; R134a
• Cusco Oil Catch Can
• Mobil 1 15w50 Oil Every 3k
• Royal Purple gear oil in trans & diff
• Exedy OE Clutch (~12k miles on it)
• Megan Racing engine & transmission mount (winter 2011
Suspension & Brakes
• Tein SuperStreet Coilovers with front camber plates
• Corner balanced & aligned
• Circuit Sports front tension rods
• Circuit Sports Rear upper control arms
• Rear subframe collars
• R33 VLSD
• Reman. 5-bolt J30 axles
• LF Wheel Bearing Replaced (10/10 OE Nissan)
• Project Nissan Outer tie rods
• Tein inner tie rods
• Brake cooling ducts
• 300zx Aluminum 30mm Front Calipers
• Powerslot rotors
• Hawk HPS+ Front pads
• Hawk Ceramics in Rear
• Stainless steel brake lines
• Suspension Techniques Swaybar set
Interior
• Alpine head unit w/ aux input
• Pioneer 6.5” 3ways front & rear
• HKS Turbo Timer
• Nismo leather shift knob
• Leather shift boot
• Momo Pedals
• Autometer dual & single A-pillar pod
• Autometer Ultra Lite Oil Pressure Electronic
• Autometer Ultra Lite Boost Gauge
• AEM Wideband O2
• Momo Hub adaptor
• Billet Momo to Nardi adapter
• Nardi Deep corn suede replica wheel
• Buddy Club Super Low Rails
• Recaro Pole Position Replica seat
• Battery Relocated to trunk
Exterior
• S15 Front end
o OEM S15 Projector Headlamps
o 5k HID Kit (Low Beams)
• VIS Carbon Fiber Hood
• OEM S15 Front Bumper
• Trust/Greddy Front Lip
• Fiberglass conversion fenders
• JDM Kouki Tail lights
• JDM Zenki Sideskirts
• JDM Kouki Rear Bumper
• Enkei RPF1’s
o 17x9 +35mm
o 17x10 +22mm
• Eibach wheel spacer; 10mm Front to clear coils
• Yokohoma S-Drive Tires (2010)
o 235/40/17
o 255/40/17
Extra’s & Parts
• Rear Fiberglass overfenders
o Nutsert & Stainless allen hardware for fenders
• Original driver seat
• Original steering wheel & clock spring
Overall body condition
Paint in good condition. Front fenders & bumper painted during conversion. Doors were blended to front fenders. Passenger side rear quarter had some rust that was cut out and patched then painted and blended. Factory spoiler was removed, holes filled and smoothed; Trunk painted. Rear kouki bumper painted & installed in 2009. Small dings & scratches here & there. Front bumper has rock chips. Crack forming in front lip that was repaired once. Some rust visible in driver side door sill. Rust on lower driver rocker was cut and patched then covered with POR15. Small rust hole on passenger side shock tower in engine compartment.
Car has always been well cared for and kept in great mechanical condition. Oil changed every 3k miles with Mobil 1 15w50. Has not seen snow since 2006. Last dyno run made 254 whp @ 11psi & 272 whp @ 15 psi on a Mustang Dyno.
Looking for $11,500 and am located in Central Illinois; About 3 hours south of Chicago. I will entertain reasonable offers. Best contact is via email @ [email protected]
focused is offline   Reply With Quote
Old 05-07-2012, 02:50 PM   #2
ESone3
ESone3's Avatar
ESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of light
so clean, looks great
www.illgarage.com
ESone3 is offline   Reply With Quote
Old 05-07-2012, 09:46 PM   #3
Nismo11
Nismo11 is an unknown quantity at this point
Looks exactly like mine, minus the rims, and color. You sit get a free bump. Glws
Nismo11 is offline   Reply With Quote
Old 05-07-2012, 09:53 PM   #4
Pinggg
Pinggg's Avatar
Trader Rating: (22)
Pinggg is an unknown quantity at this point
Feedback Score: 22 reviews
Clean!
GLWS
Pinggg is offline   Reply With Quote
Old 05-07-2012, 11:22 PM   #5
2005bluesti
2005bluesti is on the path to ruin2005bluesti is on the path to ruin
Pm sent!!!
2005bluesti is offline   Reply With Quote
Old 05-08-2012, 12:09 AM   #6
qt_240
qt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really nice
Nice s14.5
Dorimonster.blogspot.com
qt_240 is offline   Reply With Quote
Old 05-08-2012, 12:30 AM   #7
Silentoreo34
Trader Rating: (28)
Silentoreo34 is an unknown quantity at this point
Feedback Score: 28 reviews
You sir did it right.
Silentoreo34 is offline   Reply With Quote
Old 05-08-2012, 12:47 AM   #8
gbaby2089
gbaby2089's Avatar
gbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfection
Whoa. One of the nicer S-Chassis in the midwest!
gbaby2089 is offline   Reply With Quote
Old 05-11-2012, 03:41 PM   #9
focused
focused's Avatar
Thanks for all the compliments. Bump #1.
Old 05-11-2012, 05:09 PM   #10
xGUNKX
xGUNKX's Avatar
xGUNKX is making his/her stupidity well-knownxGUNKX is making his/her stupidity well-knownxGUNKX is making his/her stupidity well-known
Pretty small numbers for that turbo. Clean tho
Originally Posted by Darryl
Them Hondas can get pretty fast if you fix em up right
xGUNKX is offline   Reply With Quote
Old 05-11-2012, 06:23 PM   #11
cjwebb92
cjwebb92 is an unknown quantity at this point
BumP super clean! Very meticulous and done right! Glws
cjwebb92 is offline   Reply With Quote
Old 05-17-2012, 09:38 PM   #12
dreaming_tokyo
dreaming_tokyo is an unknown quantity at this point
sad to see it finally go up for sale, the buyer will be one lucky person. amazing job man.
-mike
dreaming_tokyo is offline   Reply With Quote
Old 05-17-2012, 10:09 PM   #13
MTec
MTec is an unknown quantity at this point
sir. you made me pinch my buttcheeks. free bump
MTec is offline   Reply With Quote
Old 05-17-2012, 11:15 PM   #14
Hanz41
Hanz41's Avatar
Hanz41 is an unknown quantity at this point
very nice 240! illinois crew checkin in!
Hanz41 is offline   Reply With Quote
Old 05-18-2012, 05:44 AM   #15
Karisusama
Karisusama is an unknown quantity at this point
Bump Bump! Nice job with the conversion!!!
Always up for an offer or trade (04 350Z 80K mi)
Karisusama is offline   Reply With Quote
Old 05-18-2012, 06:35 AM   #16
Drftr915
Drftr915's Avatar
Trader Rating: (22)
Drftr915 is an unknown quantity at this point
Bump, very clean, nicely put together.
Drftr915 is offline   Reply With Quote
Old 05-18-2012, 06:37 AM   #17
subiesean
subiesean's Avatar
subiesean is an unknown quantity at this point
s14.5 ftw love this it was def.done right
I change cars too often...
Ho.Mo.Co.
subiesean is offline   Reply With Quote
Old 05-18-2012, 07:31 PM   #18
C4L
C4L is an unknown quantity at this point
Trade?
http://zilvia.net/f/cars-sale/454261...tock-mint.html
C4L is offline   Reply With Quote
