Old 05-31-2012, 10:32 PM   #1
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
TONS of NEW and USED...AFTERMARKET and OEM...240sx, 350z, 200sx, and universal PARTS!
- If you low ball me, I won't even respond to you...simple as that.
- Please bump the thread when you view it, thank you.
PBM Spacer Packs 4-lug (each pack has a set...I have two packs, so enough for all four wheels) I WILL NOT PART OUT THE SETS!
- BNIB (Brand New In Box)
- $150 Per Pack $290 for both (I had to wait 3 months to get these from PBM)
Axxis S13 Ceramic Front Brake Pads
- BNIB
- $50
S14 Zenki Gauge Cluster
- 87xxx miles
- Perfect Shape
- $75
S14 A/C Bezel
- All tabs are broken
- $20
SR Timing Chain Tensioner
- ~3k miles
- Perfect Shape
- $30
HKS Timing Gear
- ~3k Miles
- Perfect Shape
- $110
Tomei Timing Gear
- ~3k Miles
- Perfect Shape
- $110
Cam Angle Sensor
- ~3k Miles (purchased NEW)
- PERFECT SHAPE!
- $150 (retails over $350)
WRX 05' Head Unit - SOLD!
- Perfect Shape
- $75
Intake and Exhaust Cam Gear Bolts
- PERFECT SHAPE!
- $5 each
Greddy Oil Cap
- PERFECT SHAPE!
- $40
KU Engineering S13 Intake Manifold
- Never Used (just sitting around for about 3yrs, but the last owner drilled injector port 1 larger to put larger injectors in but then sold it to me...costs about 60 to do it to the other 3 or 40 to correct port 1)
- $140
SR20 Upper Oil Pan - SOLD!
SR20 Oil Pump - SOLD!
SR20 Oil Screens (2 sets)
SR20 Rear Crank Case Cover (3)
SR20 Oil Block Galley w/ Sensor (2)
Unknown Brand BOV
- Slightly Used
- PERFECT SHAPE
- $50
SR Main Cap Girdle
- PERFECT SHAPE
- $25 each
SR Coolant Tubes - two left
- PERFECT SHAPE
- $20 each
OEM SR20VE P11 Valvetrain (IN+EX Valves, Springs, Cams, Gears)
- 15,000 Miles
- PERFECT!
- MAKE OFFERS ON WHAT YOU NEED!
SR20DET AAC Valve (1 NEW /1 USED)
- PERFECT SHAPE
-NEW- $110 - SOLD!
-USED- $40
stock KA24de airbox intake system and Filter is still clean (came from a 98' kouki)
- PERFECT SHAPE
- $75
Fuse Relocation Setup - SOLD!
- PERFECT SHAPE
- $30
S13 Non-ABS Driveshaft - Pick up only
- Used
- $100
S13 SR Transmision - Pick up only
- Roughly 30k miles
- PERFECT SHAPE
- $150
S13 SR20 Intake Gasket
- PERFECT SHAPE
- $15
S13 SR20 Coil Pack Cover
- PERFECT SHAPE!
- $30
S13 SR Bell Housing
- No cracks
- $40
S13 SR Clutch Fork
- Perfect Shape
- $20
SR20 Water Pump
- Great Shape
- $30
SR20 Coilpack Gaskets
- NEW
- $3 each
S13 SR20 Valve Cover Gasket
- Perfect Shape
- $20
(8) SR OEM Rocker Arm (1 Set)
- Used
- $5 each
(16) OEM Spring, Retainer, and Keeper (1 set)
(8) SR OEM Intake Valves (1 set)- SOLD
(8) SR OEM Exhaust Valves (1 set)- SOLD
(8) SR OEM Lifter (1 Set)
- Used
- $5 Each
(3) SR OEM Rod
- Great Shape
- $10 each
SR OEM Exhaust Manifold w/ Heat Shield
- Perfect Shape
- $40
Mr. Gasket (Copper) sr20det - SOLD!
Other sr20det Exhaust Gaskets (t3, T4, Exhaust mani)
- Perfect Shape
- $15
Crank Pulley Bolts (2)
-Perfect Shape
-$5
Transmission Mount Brackets
- Perfect Shape
- $15 each
Alternator Brackets
- Perfect Shape
- $25 each
Knock Sensor (4)...one doesn't have a sub-harness
- Perfect Shape
-$30 each (20 for the one without the sub-harness)
Godspeed Arm - $15
S13 Rear Links - $10 each
S13 Front Lower Control Arm - $30
Thermostat Housing- $10
Coolant Temp. Sensor Housing- $10
Coolant Inlet/Outlet- $10 Each
\/ \/ \/ 350Z PARTS \/ \/ \/
350z StopTech Front BBK (was going to use them on my new build but im going with something else now. This setup retials for around $3,000)
6-Piston Front with 2-Piece Rotors
- ~5k miles
- $1,250 (retails for ~3k)
350z LSD
- ~15k miles
- $250
350z OEM Suspension Links
- ~15k miles
- Perfect Shape
350z Master 1 1/16th
- Perfect Shape
- $50
350z Brake Booster
- Perfect Shape
- $120
350z 03' tinted tail lights
- Great shape
- $75
350z OEM Fuel Tank
- ~20k miles
- Perfect Shape
- $90
350z Seats
- ~20k miles
- $300
350z oem Radiator
- ~20k miles
- $100
350z oem Radiator Support
- ~20k miles
- $100
These are all the make an offer items...i dont want or need them so just make an offer...pictures of these upon request.
\/ \/ \/ 2005 WRX (less then 20k miles on items)\/ \/ \/
OEM Air Box Setup
OEM Downpipe
OEM Full Exhaust
OEM Uppipe
OEM Turbo Heat shield
\/ \/ \/ Auto 200SX SER Engine Part Out \/ \/ \/
Head (currently has valves, springs, retainers, and keepers but can remove if buy requests)
Rocker arms
Oil tubes in SR head
Intake and Exhaust cam gears
Valve Cover
EGR valve (in WORKING order)
distributer (in WORKING order)
Headers
Injectors w/ Fuel rail
Water Pump
Water Pump pulley
oil filter block
crank pulley
Intake Manifold (perfect Condition w/ all connectors and hoses)
(3) Pistons
(3) Rods
Coolant tubes
Coolant outlet
Lower Oil Pan
Oil Pan baffling
Timing chain tensioner
Flex Plate
Auto trans spacer?
Alternator bracket
intake bracket
power steering bracket
ac bracket
Auto 200sx Engine Harness (completely uncut)
injector harness
tps (throttle position sensor)
Thank You For Looking!
https://instagram.com/eck_matthew/
Imarvin240 is offline   Reply With Quote
Old 05-31-2012, 11:59 PM   #2
sigma_kid
sigma_kid is an unknown quantity at this point
R u willing to part with that heatshield?
sigma_kid is offline   Reply With Quote
Old 06-01-2012, 07:52 AM   #3
nissanfreak317
nissanfreak317's Avatar
Trader Rating: (18)
nissanfreak317 is an unknown quantity at this point
Hi, can you give some more info on the spacer packs? Like, what thickness they are and all that? I'm interested in them as well as some of the knock sensors. thanks!
WTB: S13 Silvia front pieces
Need: Hood, Fenders, Bumper, Headlights + brackets.
Have decent pop-up front to trade with oem hood + vis racing carbon fiber hood if interested.
nissanfreak317 is offline   Reply With Quote
Old 06-01-2012, 08:29 AM   #4
sigma_kid
I sent you a pm about the oem mani and heatshield
Old 06-03-2012, 09:17 AM   #5
sigma_kid
lemme know if im still pickin that up today... i pmd u my number
Old 06-04-2012, 02:40 PM   #6
Imarvin240
Trader Rating: (18)
buy this stuff before I start throwing out some of it. This stuff is taking up to much room and needs to go...NOW!
Old 06-06-2012, 10:13 PM   #7
Imarvin240
Trader Rating: (18)
bump it up!
Old 06-07-2012, 08:31 AM   #8
g35gabby
g35gabby's Avatar
Trader Rating: (26)
g35gabby is an unknown quantity at this point
Feedback Score: 26 reviews
Does the greddy cap fit a VQ? not sure the thread pitch is the same so I figured I would ask first.
g35gabby is offline   Reply With Quote
Old 06-07-2012, 08:45 AM   #9
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
i want that 350z seats for my z but i have no time right now to get them fuck.
Old 06-08-2012, 06:27 AM   #10
Evo2372
Evo2372 is an unknown quantity at this point
Thanks for the GK, great dealing with you even though I'm on the otherside of the planet lol.
Great delivery time.
All the best with "everything"
Until the next time you have Mitsu parts, take it easy.
Evo2372 is offline   Reply With Quote
Old 06-08-2012, 06:37 PM   #11
Imarvin240
Trader Rating: (18)
dropped prices on a lot of parts, let me know what you need!
Old 06-08-2012, 10:48 PM   #12
Big Zee
Big Zee's Avatar
Big Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choices
Send a message via MSN to Big Zee
Aside of the obvious exhaust sprocket on the hks cam gear brand name and color is there a difference between the tomei and hks cam gears?
I am interested in buying the set, but just curious why you went with the 2 different brands
Big Zee is offline   Reply With Quote
Old 06-09-2012, 10:09 AM   #13
stayclassy
stayclassy's Avatar
stayclassy is an unknown quantity at this point
Did you make that fuse box relocation panel yourself? or did you buy it? Im in the process of relocating mine in my usdm S14 right now.
stayclassy is offline   Reply With Quote
Old 06-09-2012, 11:26 PM   #14
firebrick240
firebrick240's Avatar
firebrick240 is an unknown quantity at this point
do you still have the oem lifters? if so how much shipped to 50703
firebrick240 is offline   Reply With Quote
Old 06-17-2012, 10:10 AM   #15
Big Zee
Big Zee's Avatar
Payment sent for the cam gears!
Thank you
