Old 06-16-2009, 07:19 PM   #1
Tom25666
Tom25666's Avatar
Tom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choices
SR20DET w/ T25 not boosting
first off: s13 w/ redtop sr, stock t25/actuator, stock smic/bov, sr maf, aftermarket downpipe/ test pipe, walbro 255, ele fan, mostly stock (370cc injectors, no tune), no a/c, no boost gauge/controller
question: it feels like the turbo only spools half the time. or maybe it spools all the time but the boost gets lost along the way. there are no unusual noises (whistling) or smoke anywhere (blue or otherwise) that I can tell. I know the stock bov isn't a SSQV, but are you supposed to be able to hear it at all? Could the BOV be sticking open/closed sometimes? Maybe the actuator sticking? I haven't taken the turbo out to inspect, but I was thinking that if the turbo itself was bad it would be fairly obvious. Its been doing this since I had the SR swap, and I've done all the obvious stuff i.e. filters, belts, plugs. I'm running a Maxima clutch, feels like it is gripping just fine. WTF?
Tom25666 is offline   Reply With Quote
Old 06-16-2009, 07:31 PM   #2
encludemeout
encludemeout's Avatar
encludemeout is making a name for him/her selfencludemeout is making a name for him/her self
I don't think it would be your bov
Could be the wastegate staying open though so you aren't able to hold boost
encludemeout is offline   Reply With Quote
Old 06-16-2009, 07:43 PM   #3
Sileighty_85
Sileighty_85's Avatar
EDIT: I see you said no boost controller, so you are just running a Vac line to the W/G?
When not running a BC with just the Vac line on the W/G your only running like 4psi, which would explain why you feel like there is no boost
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 06-16-2009, 07:45 PM   #4
slider2828
slider2828's Avatar
Check your timing, look for boost leaks... check wastegate (per fsm).
Turn and Burn!
Old 06-16-2009, 07:47 PM   #5
Rapier46
Rapier46's Avatar
Rapier46 is an unknown quantity at this point
Send a message via AIM to Rapier46
Originally Posted by Sileighty_85 View Post
are you running a boost controller or just putting a vac line straight on the Actuator?
msglngthfuck
Left hand drive 240sx's ARE NOT SILVIAS.
Rapier46 is offline   Reply With Quote
Old 06-16-2009, 07:51 PM   #6
Sileighty_85
Originally Posted by Rapier46 View Post
msglngthfuck
Thanks for helping
I just noticed, go be not so helpful somewhere else
後輪駆動車1番
1986 SR86 - 200ish
Old 06-17-2009, 01:05 AM   #7
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Sounds like ignition timing could be too retarded.
Old 06-17-2009, 01:13 AM   #8
DataXUnknown
Trader Rating: (30)
DataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfection
Feedback Score: 30 reviews
check your wastegate and make sure there is a clip holding it on at the end. mine felt like this too and i noticed my wastegate actually fell off because the clip rusted and broke.
DataXUnknown is offline   Reply With Quote
Old 06-17-2009, 02:53 AM   #9
waynehead05
waynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura about
Send a message via AIM to waynehead05
Why wouldnt it be 7 if the wastegate is a 7psi gate?
Who in their right mind would want to lead this nation of Me-First Right-Now Do Nothings??
waynehead05 is offline   Reply With Quote
Old 06-17-2009, 12:23 PM   #10
DataXUnknown
Trader Rating: (30)
^ I don't understand that either. I believe that is only for the KA-T setups, with SR it's 7psi.
Old 06-17-2009, 12:34 PM   #11
burnsauto
burnsauto's Avatar
check timing first, then the wastegate, piping leak, etc.
go to advance/autozone/etc and buy a $20 boost gauge... just something to get you by so you know what psi you're running. (put a T fitting between the fuel pressure regulator, and the throttle body vacuum line, and run the boost gauge signal line off that.)
Old 06-18-2009, 02:58 PM   #12
Tom25666
Tom25666's Avatar
that's what i was thinking. i appreciate the input everyone. so probably wastegate or timing? if it was vacuum it would feel weak all the time and be audible, yes?
Old 06-18-2009, 03:37 PM   #13
waynehead05
one way to check if you're boosting or not is pull the wastegate signal off completely. Start the car and ONLY go down the block and back. Punch it, but don't go past 5k. You'll know if you're boosting or not, cause it should boost upwards of 20 pounds. If it isn't boosting it's not your wastegate.
Old 06-07-2012, 05:20 PM   #14
highlifein909
highlifein909's Avatar
highlifein909 is an unknown quantity at this point
YO! i need some help., recently my car was running fine, nd outa the no where car made a small boom noise from exhuast nd shutted down, i restarted it and after the car wasnt holding boost, after tryin to BOOST it while driving car shut off, car is idling fine but smells rich, no funny or knocking noises, can it be my turbo? wastegate or turbo leak???
highlifein909 is offline   Reply With Quote
Old 06-11-2012, 10:53 PM   #15
sandeezy
sandeezy's Avatar
sandeezy is an unknown quantity at this point
check all your exhaust gaskets most definitely. exhaust leaks = boost leaks and they can throw you off bad.
sandeezy is offline   Reply With Quote
Old 06-12-2012, 06:48 AM   #16
kikcaffine
kikcaffine is an unknown quantity at this point
My car did the same thing, the guy grabbed what he thought was a vac source off the cold pipe after the intercooler but before the throttle body (stock SMIC piping), re-routed the lines correctly (stock) and it works fine afterwards. Check to make sure your lines are routed to the correct locations on the throttle body.
kikcaffine is offline   Reply With Quote
Old 06-13-2012, 12:11 AM   #17
steve shadows
steve shadows's Avatar
A lot of times people diagnose problems like this and they can't figure out what in the world it is.
It is often the CAS or base timing being off...i.e. you need to get a timing light and an old distributor wire and check your timing per FSM to make sure it's 15 BDTC on the crank so you're all setup right...
Granted this is usually the problem if everything else checks out first.
Another thing is to check the ground wire that goes from the coil pack harness to the back of the head/firewall as well. This usually comes loose and can cause a pretty annoying mis-fire right where you don't want it.
Like Me on FaceBook !
Old 06-13-2012, 12:28 AM   #18
Jesse SR20
Jesse SR20's Avatar
Jesse SR20 is an unknown quantity at this point
After you confirm your timing, and grounds, go to home depot and buy the parts to build a boost leak tester (you'll need an air compressor, or a hand pump of some kind). Search google and youtube for what I'm talking about.
You can NOT visually inspect for boost leaks. You'd be amazed at how many leaks the average boosted setup has unless they pressure test it.
http://zilvia.net/f/image.php?type=sigpic&userid=64204&dateline=132878  0706
Jesse SR20 is offline   Reply With Quote
s13, sr20det, t25, turbo
