Old 06-15-2012, 05:45 PM   #1
gsracer
gsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond repute
9500rpm sr20det monster
Parting out a fully built by mazworx sr20det. z32 5 speed with aluminum driveshaft, blitz intercooler, tanabe exhaust. etc etc etc.This motor revs till 9500 rpms makes 400 whp ready to go and fuck shit up with.
This motor has been in storage for about 4 years, has less than 1000 miles..
Reason for sale is other projects.
From intercooler to exhaust price is 6500.00 obo That gives you a turn key build with everything and i mean everything you need to drop it in and drive in a weekend. This motor has more than 10,000 invested in it. No knock off anything on this build.
pics of motor when it was being built at mazworx and invoices.
Here is what i could remember from the build
The build sheet for the bottom end is as follows:
ATI Super Damper
SR20DET S13 Oil Pump
Manly Turbo Tuff Rods for SR20DET
ARP Main Studs or SR20
CP Pistons/86.5 mm Bore, 9:0:1 Compression
Calico Coasted ACL Thrust Bearing Set
Calico Coated ACL H-Series Rod Bearing Set, 17 mm wide, +.001
Calico Coated ACL H-Series Main Bearing Set, +.001
Machining/Assembly for Bottom End:
Mazworx Oil Groove Machining
Check line bore
Check and polish crank
Bore & Hone
Hot tan and clean components
Resurface Block and Oil Pump
Weld on AN fittings to steel neck
The build sheet for the head is as follows:
Supertech Valve Springs
Supertech Titanium Retainers
Supertech Seat Locators
Supertech Valve Stem Seals
R/R Oil Plugs
Tomei Solid Pivot
Supertech Exhaust Valve, Std, 6mm stem
Supertech Intake Valve, Std, SR20
Tomei Solid Type Camshaft 260 12 mm lift Exhaust
Tomei Sold Type Camshaft 260 mm 12 mm lift Intake
Tomei Adjustable Cam Gear
Timing Chain
Rear Main
Valve Guides
R/R Valve Guides
Machining/Assembly for Head:
CNC Combustion Chamber
Valve Job
Resurface Head
Shimmed and Assembled
OTHER PARTS:
Turbo Top Mount Manifold and Turbo:
Garrett GT2871R Top Mount Housing t3 64 a/r
Manifold peak boost with dump tube
tial 40mm wastegate
Tranny:
SR/VG Trans Adapter Kit
Aluminum Driveshaft
300zx tranny
Greddy Intake Manifold (powder coated flat black)
Nismo 740cc injectors
Blow off Valve – his super sequential
Remote Oil Filter with Adapter plate
Mazworx custom overflow cooling tank
Mazworx custom oil catch can
AN Fittings Throughout
to radiator and pretty much every where else.
Setrab Oil Cooler
Alternator Powdercoated black
tanabe racing medallion 3 inch exhaust
Blitz intercooler
custom built harness
Mazworx tuned ecu
Theres more I'm sure I'm forgetting but like i said this is a turn key swap
some of the many invoices
ANTI-STRETCH NAZI
Vortech Supercharged Vh45de S14 V8nissans.com
gsracer is offline
Old 06-15-2012, 05:58 PM   #2
mpact1981
mpact1981's Avatar
mpact1981 is an unknown quantity at this point
Put it back in storage until October so I can buy it
mpact1981 is offline
Old 06-15-2012, 06:34 PM   #3
punch
punch is a jewel in the roughpunch is a jewel in the roughpunch is a jewel in the roughpunch is a jewel in the roughpunch is a jewel in the roughpunch is a jewel in the roughpunch is a jewel in the roughpunch is a jewel in the rough
Thanks for posting this up Jerry. I have a few more pics that I will add tomorrow. The pics don't show all the parts listed. It's a great deal for sure.
Mazworx Built Time Attack S13
punch is offline
Old 06-15-2012, 07:04 PM   #4
Te37
Te37's Avatar
Te37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choices
Is it still in the car to see it run?
Te37 is offline
Old 06-15-2012, 07:05 PM   #5
gsracer
yes it is..
ANTI-STRETCH NAZI
gsracer is offline
Old 06-15-2012, 07:16 PM   #6
laurentj23
laurentj23's Avatar
laurentj23 is an unknown quantity at this point
Who build the motor? miles on turbo?
'Born Ready!',LJ
laurentj23 is offline
Old 06-15-2012, 07:17 PM   #7
gsracer
mazworx built the motor... has less than 1k miles.
Turbo has probably around 2k miles.
ANTI-STRETCH NAZI
gsracer is offline
Old 06-15-2012, 08:02 PM   #8
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Luvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of light
Feedback Score: 81 reviews
How much for the sr/vg adapter?
Luvs2slide is offline
Old 06-15-2012, 08:26 PM   #9
punch
^^ not being parted out. Being sold as a turn key setup.
punch is offline
Old 06-15-2012, 08:51 PM   #10
808_Drift
808_Drift's Avatar
808_Drift is a glorious beacon of light808_Drift is a glorious beacon of light808_Drift is a glorious beacon of light808_Drift is a glorious beacon of light808_Drift is a glorious beacon of light808_Drift is a glorious beacon of light808_Drift is a glorious beacon of light808_Drift is a glorious beacon of light808_Drift is a glorious beacon of light808_Drift is a glorious beacon of light808_Drift is a glorious beacon of light
if this is still for sale in two weeks i will have cash
808_Drift is offline
Old 06-16-2012, 10:25 AM   #11
punch
As a little background on the engine setup, Mark from Mazworx built the engine and a-lot of custom parts that you see pictured for my time attack S13. The head is built to rev to 9500. This is a very responsive setup. It pulls like a freight train. Here is another pic:
punch is offline
Old 06-17-2012, 08:54 AM   #12
gsracer
fathers day bump.......
ANTI-STRETCH NAZI
gsracer is offline
Old 06-17-2012, 11:06 AM   #13
sharpe_corners
sharpe_corners's Avatar
Trader Rating: (29)
sharpe_corners is an unknown quantity at this point
Feedback Score: 29 reviews
stock rods?
Originally Posted by Goofs View Post
Reminds me of a guy around here who bought a e36 because he said his truck has a "rap sheet, and a high heat level." I told him this isn't need for speed most wanted.
sharpe_corners is offline
Old 06-17-2012, 11:27 AM   #14
Pinggg
Pinggg's Avatar
Trader Rating: (22)
Pinggg is an unknown quantity at this point
Feedback Score: 22 reviews
Originally Posted by sharpe_corners View Post
stock rods?
**Manly Turbo Tuff Rods for SR20DET**
Bump for OP, this is a sick setup!
Pinggg is offline
Old 06-17-2012, 01:31 PM   #15
gsracer
yes they are manley turbo tuff rods. rods alone cost. 700.00.....
ANTI-STRETCH NAZI
gsracer is offline
Old 06-17-2012, 01:38 PM   #16
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
i love your bottom end set up. this build is no joke. lots of goodies and being built by mazworx is well worth it.
bump for you guys.
wangan_cruiser is offline
Old 06-17-2012, 04:22 PM   #17
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
I have had a few Mazworx engines now and they are sick engine builders! currently running a Mazworx sr22ve-t. Good luck with the sale, thats a killer deal for what it costs to get an engine built by Mazworx...let alone all the other parts for sale with the engine.
https://instagram.com/eck_matthew/
Imarvin240 is offline
Old 06-17-2012, 05:18 PM   #18
hks4life
hks4life is an unknown quantity at this point
god damn trade yah my sr hatch!
hks4life is offline
Old 06-17-2012, 05:55 PM   #19
kevs1992
kevs1992 is an unknown quantity at this point
how much you askin for the motor and everything else??
kevs1992 is offline
Old 06-17-2012, 06:22 PM   #20
gsracer
6500.00 obo complete with everything from intercooler to exhaust plus shipping.
ANTI-STRETCH NAZI
gsracer is offline
Old 06-17-2012, 07:04 PM   #21
punch
Some additional parts that weren't mentioned:
New Greddy Breather Tank
New Greddy Oil Pan
New Nismo Oil Cap (powder coated black)
There was no expense spared with this build. I'll try to think of other parts used. Spent well over $12K on this setup. Whomever picks this up, gets a hell of a deal.
punch is offline
Old 06-21-2012, 08:04 PM   #22
gsracer
nba playoff bump?
ANTI-STRETCH NAZI
gsracer is offline
Old 06-21-2012, 08:08 PM   #23
TougeLabs
TougeLabs's Avatar
TougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to behold
Send a message via AIM to TougeLabs
If someone buys my 1125r I'm on this !
GLWS !
TougeLabs is offline
Old 06-26-2012, 06:53 PM   #24
punch
Bump for this killer setup.
punch is offline
Old 06-26-2012, 07:08 PM   #25
alexg103
alexg103 is an unknown quantity at this point
part it out
alexg103 is offline
Old 06-26-2012, 07:18 PM   #26
ground_shaking
ground_shaking is an unknown quantity at this point
bumb from florida
ground_shaking is offline
Old 06-26-2012, 08:01 PM   #27
punch
Also, so that everyone is aware, the FAL fans identified in the first series of pics posted by GSRacer are not included. We ditched those pieces of shit for two new fans, of which I can't remember the name. I drove from Orlando to Miami on this setup and cooling temps stayed great.
Further, the fuel rail in the first pic shows a completely powder coated rail. We couldn't get that one to work because of some issues with the blasting/powdercoating process. The last engine pic shows what's on there now, which is the stock fuel rail, just not powder coated.
Thanks.
punch is offline
Old 06-27-2012, 01:24 PM   #28
mpact1981
mpact1981's Avatar
I like the fact that this hasn't sold yet and if it's still around on the 1st of October, we just might have a deal!
but, since the car has been sitting up for x years. mind posting a current video of it running? even an old video of it running would be nice to see what can be expected from the engine. a DYNO sheet maybe? how much boost and type of fuel were you running to hit 400whp?
I've got a lot more questions, such as who is going to pull the engine etc... but I'll wait to make sure this thing last until October before I ask those....
Old 06-27-2012, 02:42 PM   #29
punch
For the record, we haven't dyno'd it on this setup. GSracer has a supercharged VH, so when he drove it, I believe he was comparing it to what he has. I'll let him compare as to his setup.
I've just been driving it off the wastegate. I haven't set boost. Sure, when I get around to it, I don't mind videotaping this screamer.
BTW, I have someone seriously interested right now. We are working out the specifics. I'll upate this thread when necessary. Thanks.
punch is offline
Old 06-27-2012, 03:39 PM   #30
gsracer
dare i say its just as fast as my car..
I will be pulling the motor out for jason.
ANTI-STRETCH NAZI
gsracer is offline
