Old 06-25-2012, 08:11 PM   #1
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
Fuel pressure drop @6000RPM
I had the 2JZ 240sx on the dyno getting tuned last week and had a fuel pressure issue where the fuel pressure would drop from 50psi down to 38 or so in the high 5000-low 6000rpm range.
I have a 2JZGTE, Deatchwerks DW300 fuel pump, 750cc FIC injectors, Aeromotive FPR, and -6AN feed line and -6AN return line. The wiring to the pump is still stock.
revving the car only to 6000rpm on 14.7psi the car made 400rwhp through a high stalled automatic in 100 degree extreme humidity day.
I'm leaning towards the factory wiring to the pump is having the pressure drop. Any other things to look into? the pump has is BRAND NEW. the rail/injectors/lines/fpr have less then 1000 miles.
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 06-25-2012, 08:31 PM   #2
jr_ss
Yep, need a rewire with heavier gauge wire... Use the factory power feed as your switch 12v source and run new stuff from the relay to the pump.
Old 06-25-2012, 09:49 PM   #3
Flicktitty
Flicktitty's Avatar
thought so, thanks for a quick response just wanted a second opinion.
Old 06-26-2012, 09:39 AM   #4
cotbu
cotbu's Avatar
I agree with the hotwire setup, but I would also test the fpr to make sure it holding up to the task.
Old 06-26-2012, 11:37 AM   #5
S@nt0s
S@nt0s's Avatar
S@nt0s is an unknown quantity at this point
yup i had the same issue, running the same pump i couldnt push passed 16psi on the pem set up witht he DW pump passed that it was dropping and jumping in fuel pressure. started at 12v and dropped to 10.5V
i hot wired it with a relay from the battery in the trunk and then got 14V on start and constant 12V with full pulls.
the pump wants Volts to stay constant kuz when boost comes in it starts flowing.
MunkyW3rkz Racing
S@nt0s is offline   Reply With Quote
Old 06-26-2012, 01:27 PM   #6
Flicktitty
Flicktitty's Avatar
Thanks much guy's gonna fix that and a few other little things and back off to the dyno it goes.
Old 06-26-2012, 02:21 PM   #7
S@nt0s
S@nt0s's Avatar
this is word for word what i went thru on the dyno it should fix the problem
MunkyW3rkz Racing
