Old 06-28-2012, 01:49 PM   #1
corey240
corey240's Avatar
corey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymore
Send a message via AIM to corey240 Send a message via MSN to corey240
SR20 wont start, has spark+fuel
Motor is a blacktop S13 SR. The motor will crank but not getting any turn overs.
Motor has brand new plugs, reset timing, is getting correct FP, tested spark on coilpacks and they work. Switched out CAS, ECU and ignitor with known working pieces just to be sure and no difference.
When I pull the plugs they are coated with fuel like its flooding? But if I unplug the injectors or FP to burn out the existing fuel in cylinders still nothing different. That worked on my last flooding SR so I gave it a shot. But even when the cylinders dry out and try again, again nothing. Really running out of ideas here and hoping not to have to pull valve cover to check for broken bits.
Email: [email protected]
corey240 is offline   Reply With Quote
Old 06-28-2012, 05:19 PM   #2
s13panic
s13panic's Avatar
s13panic is an unknown quantity at this point
Are you sure the timing is 100% correct? Not doubting you but if you have fuel and spark most likely the timings off enough to where its not hitting at the right time.
CLUSTER BOMB EC DORIFTO
s13panic is offline   Reply With Quote
Old 06-28-2012, 06:54 PM   #3
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
Did you clean the plugs? i know that you said that they're brand new but when i first put my sr in my car the plugs got coated real bad and then i started flooding the motor. cleared the flood and cleaned plugs and she started no problem.
godsmack is offline   Reply With Quote
Old 06-28-2012, 06:59 PM   #4
cbcm2435
cbcm2435's Avatar
cbcm2435 is an unknown quantity at this point
is your MAF sensor reading the air going into the engine? it not working correctly would cause that problem, ive seen it several times
cbcm2435 is offline   Reply With Quote
Old 06-29-2012, 09:35 AM   #5
kennedy8383
kennedy8383's Avatar
kennedy8383 is an unknown quantity at this point
Maybe your have ground wiresssss problem somewhere
kennedy8383 is offline   Reply With Quote
