Old 06-28-2012, 06:36 PM   #1
pepe123
pepe123's Avatar
pepe123 is an unknown quantity at this point
300zx front brake swap question/issue
ok heres the set up
s13 knuckles
s14 5 lug hubs
30mm 300zx calipers
300zx rotors 30 mm
for some reason i looks like i need a spacers where the caliper mounts to the knuckles, as if the knuckles to far back. if i mount the calipers like this the pull the rotor toward the mounting points, and lock up the rotor so it wont spin. im thinkk i could just run some spacers and it would work but idk why im having this issue
pepe123 is offline   Reply With Quote
Old 06-28-2012, 06:38 PM   #2
WERDdabuilder
WERDdabuilder's Avatar
run a washer on the caliper bolts. i had to do the same.
/fixed.
When the power of love overcomes the love of power, the world will know peace
Old 06-28-2012, 06:57 PM   #3
7jpat
7jpat is an unknown quantity at this point
thanks for the heads up im doing r32 brakes this weekend i assume that ill have the same problem , but i have drop engineering hubs
7jpat is offline   Reply With Quote
Old 06-28-2012, 07:06 PM   #4
Srsil
Srsil is an unknown quantity at this point
Ur spacin is off becouse ur using s13 hubs on s13 knuckles ye bearing surface is diffrent s13 is s13 only for the conversion hubs
Srsil is offline   Reply With Quote
Old 06-28-2012, 07:07 PM   #5
Srsil
Sorry s14 hubs on s13 knuckles ^
Old 06-28-2012, 07:28 PM   #6
7jpat
im using s13 hubs to s13 knuckle so ill be ok ???
Old 06-28-2012, 09:52 PM   #7
Srsil
U said ur using s14 hubs with s13 knuckles the s14 hubs and bearings do not match s13 u will screw stuff up
Old 06-29-2012, 12:37 AM   #8
eek
Trader Rating: (29)
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
Feedback Score: 29 reviews
IIRC the stock z32 caliper bolts should come with washers on the bolts. If not you can can put a lock washer on each bolt when mounting the caliper to the ears. Hopefully that will space it out enough for it to work.
eek is offline   Reply With Quote
Old 06-29-2012, 02:11 PM   #9
7jpat
No i didn't start the thread
