Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Interior & Exterior
Old 07-01-2012, 04:55 PM   #1
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
S13 Center Vent Gauge Plates
  • Fits LHD and RHD S13's
  • Main plate is CNC'd from 1/8" aluminum
  • Inside radius of the gauge openings are beveled so the gauge will drop in when angled
  • ABS angled rings are prepped to remove all casting nubs
  • ABS angled rings are trued on the bottom side as they do not come 100% flat
  • Main plate and rings are texture coated for OEM look
  • Painted with high quality SEM Satin Black
  • Angled plates Include aluminum mounting brackets that can be modified to fit your particular gauge(see pics below)
  • The mounts can also be modified to make a rock solid mounting system for the dash(see pics below)
(3) 52mm Gauge Plate: $45 Shipped 1 in stock
(3) 52mm Angled Gauge Plate: $75 Shipped 8 in stock
(1) 52mm and (2) 60mm Gauge Plate: $45 Shipped 1 in stock
(3) 60mm Gauge Plate: $45 Shipped 1 in stock
(1) 60mm Gauge Plate With Vents: $65 Shipped 2 in stock
(1) 60mm and (2) 52mm Gauge Plate: $45 Shipped 1 in stock
(2) 52mm Gauge Plate With Vents: $65 Shipped 0 in stock
(2) 52mm Angled Gauge Plate With Vents: $85 Shipped 5 in stock
Blank Gauge Plate: $19 Shipped 1 in stock
All Angled Gauge Setups Include Universal Brackets:
The brackets can be cut/modified to accommodate virtually any gauge. This will ensure the gauges do not budge when mounted in the plate. On top of that, the mounting bracket gives you the ability to also make a mounting system to hold the plate to the dash. You can simply tap out the center of the bracket and use some threaded rod to make a rock solid mounting system. I like to cut some aluminum strips to make "washers" and then some simple wing nuts to fasten it in the dash. The wing nuts make it simple to fasten while the dash is still in the car. You can find examples of the modified brackets and mounting system below. Note: I do not sell the mounting system, as it can vary depending on the brand and model of gauge. So I leave that to the consumer if they so choose.
Example of Modified Bracket:
Example of Modified Brackets Mounted:
Example of Mounting System Utilizing Modified Mounting Brackets, Threaded Rod, "Washers" and Wing Nuts:
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline
Old 07-01-2012, 10:41 PM   #2
KoukiMonsta
KoukiMonsta's Avatar
KoukiMonsta is a well-known jackass
Toby makes the coolest stuff ever. If only I could afford it
@UpshiftEngineering
KoukiMonsta is offline
Old 07-01-2012, 10:49 PM   #3
bmg671
bmg671's Avatar
bmg671 is an unknown quantity at this point
Great stuff! Anything for S14?
bmg671 is offline
Old 07-01-2012, 10:59 PM   #4
Broadfield
Broadfield's Avatar
Thanks man!
I can make just about anything you want... but it would have to be a one-off. The S14 obviously doesn't have a nice vent that you just pop out and slap a piece of aluminum in it's place... like the S13 does. But I can modify your OEM HVAC panel to house whatever you want:
My Portfolio
Please Share
Check Out My Builds
Old 07-02-2012, 12:30 AM   #5
s14boy
Trader Rating: (26)
s14boy is an unknown quantity at this point
Feedback Score: 26 reviews
i was about to make a cad file for something like the angled tripple gauge holder and do a 3d print but i might go with yours
and btw your work it fantastic
s14boy is offline
Old 07-02-2012, 05:15 PM   #6
240zach
240zach's Avatar
240zach is an unknown quantity at this point
with the s13 vent gauge plates does the dash have to be removed to install them correctly or can you do it with the dash still in?
240zach is offline
Old 07-02-2012, 05:53 PM   #7
Broadfield
Broadfield's Avatar
Taken from original post:
My Portfolio
Please Share
Check Out My Builds
Old 07-02-2012, 08:17 PM   #8
7jpat
7jpat is an unknown quantity at this point
Can u make one for s13 so i can keep one adjustable vent in center
7jpat is offline
Old 07-02-2012, 09:29 PM   #9
240zach
240zach's Avatar
LOL i knew id end up feeling dumb
240zach is offline
Old 07-02-2012, 09:31 PM   #10
240zach
240zach's Avatar
once i get all the s-gear gauges i want ima get the triple 52 angled. lol cant wait. lol
240zach is offline
Old 07-03-2012, 01:58 AM   #11
funes
funes is an unknown quantity at this point
im gonna get one of these
I do window tinting PM me for a good deal
funes is offline
Old 07-03-2012, 04:46 AM   #12
Tantwoforty
Tantwoforty's Avatar
Tantwoforty is an unknown quantity at this point
$85 for 75 cents worth of plastic is a bitch, but that's supply and demand for ya
Well its supply and demand with a side of making a gaaang of loot, But i cant hate, I'd do the same thing....
These things are sick, I'll be picking one up soon!
Tantwoforty is offline
Old 07-03-2012, 09:04 AM   #13
Broadfield
Broadfield's Avatar
No, that would be much more involved. The aluminum plate would need to have pivot points for the actual vent to attach to. I kind of like the idea though... I may look into it to see what the additional cost would be.
Do it!
Do it!
What the hell are you talking about?
My Portfolio
Please Share
Check Out My Builds
Old 07-03-2012, 03:52 PM   #14
7jpat
yeah let me know if u come up with something , i was thinking like just popping 1 vent out and just pop a plate in with 1 angled, i want 20 % for giving u the idea lol
7jpat is offline
Old 07-03-2012, 04:00 PM   #15
Broadfield
Broadfield's Avatar
Shit, if it works out I was going to give you the first one.
My Portfolio
Please Share
Check Out My Builds
Old 07-03-2012, 04:30 PM   #16
7jpat
ill take that freebee
7jpat is offline
Old 07-04-2012, 12:41 PM   #17
frsh4
frsh4's Avatar
frsh4 is an unknown quantity at this point
I sent a pm for the (3) 60mm vent.
http://thatistupid.tumblr.com/
frsh4 is offline
Old 07-04-2012, 09:45 PM   #18
Broadfield
Broadfield's Avatar
I sent you a reply on July 2nd at 6.59PM... it's in my sent messages
My Portfolio
Please Share
Check Out My Builds
Old 07-15-2012, 03:45 PM   #19
Nikko
Nikko is an unknown quantity at this point
what is your paypal?
i am interested in a (3) 52mm angled gauge plate.
email me your paypal
[email protected]
and how long will i be expecting to wait till i get them?
thanks
Nikko is offline
Old 07-15-2012, 03:59 PM   #20
Broadfield
Broadfield's Avatar
[email protected]
thanks
You can Paypal me at:
[email protected]
Please enter in the comments box what the payment is for and make sure NOT to gift the payment. Also make sure your correct shipping address is associated with your Paypal account to prevent shipping delays.
I will ship the item out no later than the next after I receive payment. I ship Priority Mail which is "suppose" to take 2-3 business days.
Thanks,
Toby
I also sent a copy of this to your email.
My Portfolio
Please Share
Check Out My Builds
Old 07-15-2012, 04:18 PM   #21
Nikko
payment sent. thank you, cant wait for them to arrive
Nikko is offline
Old 07-15-2012, 05:34 PM   #22
Broadfield
Broadfield's Avatar
Sweet! It will ship out tomorrow morning.
My Portfolio
Please Share
Check Out My Builds
Old 07-16-2012, 08:50 PM   #23
ohshtnoboost
Trader Rating: (18)
ohshtnoboost is an unknown quantity at this point
Feedback Score: 18 reviews
Payment has been sent for 1 (3)52mm angled gauge plate.
ohshtnoboost is offline
Old 07-16-2012, 08:53 PM   #24
Broadfield
Broadfield's Avatar
Awesome! I already printed out the shipping label and slapped it on the box. It will ship out first thing tomorrow morning. You should be receiving an email to your Paypal email address with tracking info. Thanks again!
My Portfolio
Please Share
Check Out My Builds
Old 07-19-2012, 02:46 AM   #25
Nikko
i just got my order today, on the angled pieces since they dont come attatched to the plate are the gauges themselves supposed to hold the angled piece down to the plate when i mount them? or was it intended for me to just glue the piece on
Nikko is offline
Old 07-19-2012, 08:39 AM   #26
Broadfield
Broadfield's Avatar
Essentially the rings are sandwiched between the plate and gauges. Ideally you want to modify the universal brackets that come with my kit and use them to bolt to the back of your gauges. You will need to cut the legs of the brackets down to fit your particular gauges. You can see examples of this in my original post.
Note: there may be some model of gauges that don't use the typical industry standard mounting points. You may have to modify the mounting holes on the brackets to get the holes to line up with your gauge mounting points. Which you can see I had to do in the example in my original post... I had to "hog" out the mounting holes to get them to line up.
2nd Note: there is the rare case that the gauge doesn't have any provisions to mount it. In this case you will have to come up with your own way to hold the gauges to the plate.
Please let me know if you have any other questions.
My Portfolio
Please Share
Check Out My Builds
Old 07-19-2012, 08:20 PM   #27
ohshtnoboost
Trader Rating: (18)
Received my gauge plate today and couldn't be happier. The quality of the piece is outstanding. Thanks again
Old 07-19-2012, 08:32 PM   #28
Broadfield
Broadfield's Avatar
I'm glad the product was up to your standards... and thanks for taking the time to leave feedback!
My Portfolio
Please Share
Check Out My Builds
Old 07-30-2012, 02:44 PM   #29
7jpat
how is that adjustable vent idea working out , did it get passed thought stage yet
7jpat is offline
Old 08-07-2012, 09:09 AM   #30
hockeyrules
hockeyrules is an unknown quantity at this point
Broadfield when are you going to have some dual guage angled with vent in stock?
hockeyrules is offline
240sx, angled gauge, broadfield, nissan, s13 center vent gauge
