Old 07-05-2012, 09:16 PM   #1
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
SR20det air/fuel mixture problems (SMOG related)
so, ive been futzing around with my car on a smog machine for the past few weeks (using diag mode). i have a blacktop SR in my s13. the SR barely failed smog...this is my current setup
sr20det blacktop
timing set to 15deg TDC (stock SR timing)
t28 S15 specR turbo @ stock boost
brand new OEM Water Temp Sensor (ecu, not gauge)
koyo aluminum radiator (55mm thick)
stock blacktop SR injectors
stock blacktop fuel rail
greddy FMIC
aeromotive 340 fuel pump
circuit sports FPR
stock SR exhaust mani
Brand new OEM 02 Sensor
circuit sports 02 housing
circuit sports downpipe
Catco 3" high flow cat
Trust PE2 catback
the car is very basic, just a few minor upgrades for living in the vegas heat. its my daily driver, not my race car.
a few issues im running into...
1) when plugged into the smog machine, my CO and HC conditions fluctuate on normal intervals. lets say CO is at 3%, it will drop down to 1.2% after 10 seconds, stay there, and raise back up again to 3% after 10 seconds. both CO and HC will do this at idle AND under load. i cant figure out what is causing this problem (as these shouldnt fluctuate unless something is wrong). ive read quite a few threads (on here and other forums) of guys getting sniffer tests done and passing with their SRs (the smog guys didnt pick up that the engine was an SR, they saw nissan and didnt care). the SRs passed with nothing more than stock boost and a catalytic converter.
2) to get my engine anywhere NEAR passable levels, i have to drop my fuel pressure to like 20psi. now correct me if im wrong, but isnt that like dangerously low for an SR? (not like im gonna be driving anywhere with it at 20psi, i just dont want it to pop under load at 2500rpms)
3) im running about 40psi of fuel pressure normally. my gas milage has been SHIT pretty much ever since i got the damn car 2 years ago. im getting about 20-21mpg city/hwy (and thats the BEST ive ever gotten it to just recently). i remember my old 2nd gen redtop getting roughly 24-28mpg city/hwy. i JUST replaced the 02 sensor with a 300zx TT 02. The cars ECU IS a blacktop computer (E5 or whatever the hell it is). there are NO boost leaks (boost leak checked it 2 weeks ago and went over everything with a fine tooth comb). cleaned my MAF sensor a few weeks back (took it out and shot it with MAF cleaner). cleaned my IACV today with intake cleaner. replaced the coolant temp sensor on saturday with a brand new OEM unit.
4) anything below 40psi of fuel pressure warrants a small shrug in the 3000-4000rpm range when hitting boost in 2nd/3rd gear. its not a hard shrug, but it is noticable. again, im running stock boost on a T28 S15 specR turbo (yes it has the divider).
Old 07-05-2012, 09:21 PM   #2
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
one of the few things i havent checked yet is the voltage going to my TPS. would incorrect TPS voltage cause the car to fluctuate during emissions check and also get craptastic gas milage?
Old 07-06-2012, 09:04 AM   #3
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
wow, NO ONE wants to take a stab at this???
Old 07-06-2012, 09:13 AM   #4
negrosx13
negrosx13's Avatar
negrosx13 is an unknown quantity at this point
Send a message via AIM to negrosx13
Put 87........
MORE BACON STRIPS
negrosx13 is offline   Reply With Quote
Old 07-06-2012, 10:00 AM   #5
s13 loverr
s13 loverr's Avatar
s13 loverr is an unknown quantity at this point
new spark plugs, air filter, and fuel filter? Maybe check again for vacuum leaks?
Drifting is not a crime, but driving an ugly car is
posted by: OBEEWON
s13 loverr is offline   Reply With Quote
Old 07-06-2012, 10:50 AM   #6
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
new plugs were put in a month and a half ago. i pulled them last week and checked for fouling, nothing out of the ordinary. fuel filter was replaced 3-4 months back. engine has no vacuum leaks, ive replaced/double checked damn near everythign in the engine bay as far as vacuum lines/intercooler couplers/t-bolt clamps. air filter doesnt really play a huge role in the whole thing (as long as its not covered in mud)
im not a noob with this stuff. im looking for more indepth answers than just the usual "you probably have a boost leak" (no offense meant by the statement either)
Old 07-06-2012, 11:50 AM   #7
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
I see you have a catco cat, how old is it? You could always try a stock cat.
di-devol is offline   Reply With Quote
Old 07-06-2012, 12:07 PM   #8
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
a little over a year old
Old 07-08-2012, 02:37 AM   #9
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
le sigh, bump
Old 07-08-2012, 02:37 AM   #10
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
i know for a fact that redtops/blacktops pass with NO emissions equipment outside of a catlytic converter. id really like to figure out why my engine is fluctuating on CO/NO like it is.
Old 07-08-2012, 11:24 AM   #11
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
Check your timing chain tensioner, if possible replace with a b15 tensioner once its bolted in and tensioned slowly unbolt it to get one.more click out of it then tighten it up. Sloppy chain means sloppy cam timing
Review Thread
bardabe is offline   Reply With Quote
