Old 07-06-2012, 10:18 PM   #1
1992s13hatch
1992s13hatch is an unknown quantity at this point
Question rounded bolt on turbo
Hey guys does anyone have any suggestions on how I can get the bolt out of the hot side of the turbo under the oil drain I rounded it off has anyone had this problem???????
1992s13hatch is offline   Reply With Quote
Old 07-06-2012, 10:27 PM   #2
eli-s13
eli-s13's Avatar
eli-s13 is an unknown quantity at this point
u can take it to a muffler shop and have them weld something on to the head of the bolt and turn it out
eli-s13 is offline   Reply With Quote
Old 07-06-2012, 10:40 PM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Bolt extractors...
CLICK HERE!!!
Old 07-06-2012, 10:42 PM   #4
jedi03
+1 on bolt extractors...so smooth!!!
Old 07-07-2012, 01:11 AM   #5
1992s13hatch
I tried to use the bolt extractors but they can't fit
Old 07-07-2012, 01:28 AM   #6
joeboo1
joeboo1's Avatar
joeboo1 is an unknown quantity at this point
Originally Posted by fliprayzin240sx View Post
Bolt extractors...
Exactly!!!!
Originally Posted by ShadowMan View Post
because the car and aero is around 20 years old, things don't stay perfect forever. Its a fact of life, titties sag and bumpers sag as they age.
joeboo1 is offline   Reply With Quote
Old 07-07-2012, 01:32 AM   #7
1992s13hatch
Yea the only thing that fits is wrenches I like the ideal about welding ill try that tomorrow
Old 07-07-2012, 01:38 AM   #8
dawagarage
dawagarage's Avatar
dawagarage is an unknown quantity at this point
vice grips
formerly known as "hotboiblaze"
ratsun: dawa (73 datsun 620)
clublexus: properD (97 sc300)
dawagarage is offline   Reply With Quote
Old 07-07-2012, 01:40 AM   #9
TurboGoKart
TurboGoKart is an unknown quantity at this point
Take the turbo off, re-clock it to make space for bolt extractors.
Locking vice grips, lots of PB blaster.
TurboGoKart is offline   Reply With Quote
Old 07-07-2012, 01:43 AM   #10
1992s13hatch
How do you re clock it ?
Old 07-07-2012, 02:19 AM   #11
fliprayzin240sx
Loosen the bolts to the back of the housing, maybe knock it slightly lose if the rubber mallet since some turbos have a sealant on the housing.
CLICK HERE!!!
Old 07-07-2012, 04:07 AM   #12
Drifting Kalamari
Drifting Kalamari is an unknown quantity at this point
Most places sell a drill bit set that extracts studs or broken parts.
It drills a tiny hole and then you use the other part to grip in the hole and reverse it out.
Sorry, I don't have the name of it, not at home ATM...
Drifting Kalamari is offline   Reply With Quote
Old 07-07-2012, 07:00 AM   #13
1992s13hatch
Yea I know what your talking about I think there easy outs
Old 07-07-2012, 01:03 PM   #14
fliprayzin240sx
Which fucking sucks cuz they have a tendency to snap off inside the studs. Ask me how I know...
CLICK HERE!!!
Old 07-07-2012, 01:08 PM   #15
blessedhellrider
blessedhellrider's Avatar
blessedhellrider is an unknown quantity at this point
grinder, grind to a size that fits open end wrench or heat up and hammer a socket on to it.
blessedhellrider is offline   Reply With Quote
Old 07-07-2012, 08:24 PM   #16
Drifting Kalamari
Never had a problem with mine snapping! I think it was called the Grabber?...
I'd probably try and apply heat to the bolt before extracting
Old 07-08-2012, 12:31 AM   #17
jedi03
ive ground them off...it works too...i also have a set from snapon thats just a socket, may have to pull turbo an manifold out to get it off tho...
Old 07-08-2012, 12:38 AM   #18
Contract_Killer
Contract_Killer is an unknown quantity at this point
vice grip or take a grinder and cut a groove in the head and back it out with a flat head screw driver
Contract_Killer is offline   Reply With Quote
