Old 07-23-2012, 10:04 PM   #1
c1L
c1L is an unknown quantity at this point
5 lug conversion on 95 s14
240SX S14 95-98 5-LUG CONVERSION KIT BEARING FRONT & REAR HUB 4X114.3 TO 5X114.3 | eBay
Has anyone ever ran these? all i need is s14 rotors besides this?
c1L is offline   Reply With Quote
Old 07-25-2012, 10:50 AM   #2
libz
libz is an unknown quantity at this point
anyone?? maybe a different route to go for the s14 5 lug conversion??
libz is offline   Reply With Quote
Old 07-25-2012, 11:40 AM   #3
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
You get what you paid for. Ebay is mostly a miss. But some people get lucky & their money's worth.
S14 front bearings cannot be replaced like S13 bearings can. The entire hub would have to be replaced. And in terms of money, if you keep replacing with bullshit parts, you will be spending as much as you could have been spending for OEM fronts.
As for the rears, it's not a bad deal considering bearings are interchangeable between S13/S14/NA Z32 so finding used ones or new ones for cheap isn't all that hard. I guess all you would have to worry about is the quality of the studs.
All in all, you get what you paid for. If you got your money's worth, awesome. Go OEM & be assured quality.
For Sale #1 | For Sale #2
zooopreme is offline   Reply With Quote
Old 07-25-2012, 02:56 PM   #4
s14skyvia
s14skyvia's Avatar
s14skyvia is an unknown quantity at this point
I'm currently running them and if i could do it over i will go oem. The rears don't fit as snugg but can be solve by tightening the axle end bolt tightly,the fronts have a little roar but its not that bad and it only noticible at low speeds. oem is the best route but these will do
s14skyvia is offline   Reply With Quote
Old 07-25-2012, 03:55 PM   #5
libz
what parts will be needed for front and rear? and can i use any year s13 s14 parts?
Old 07-26-2012, 11:16 AM   #6
zooopreme
Trader Rating: (38)
S14 doesn't need "conversion" parts. 5 lug S14 parts bolt on to 4 lug S14 parts.
You're better off using used OEM hubs than ebay parts. S13/S14/NA Z32 rears are interchangeable. Fronts are not. S14 & Z32 came with factory 5 lug (US).
Old 07-26-2012, 12:15 PM   #7
eek
Trader Rating: (29)
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
Feedback Score: 29 reviews
You will also need a set of 5 lug rims. Use the SEARCH function, its been covered MORE than a few hundred times... I promise.
eek is offline   Reply With Quote
Old 07-26-2012, 12:24 PM   #8
libz
^^ all the searching related directly to s13's because i guess the 95' 4 lugs are rare. and im not really that good with these cars yet. i have 5 lug wheels and trying to figure out the best way to change to 5 lug without it being a cheap or crappy way of doing things
