Old 05-22-2012, 01:09 PM   #1
Zacho
Zacho is an unknown quantity at this point
FS: 450whp RB20/25 setup turbo/manifold/gate/lines/plumbing(CANADA)
Will split up
Details:
-GT3076r .82 - fresh garrett CHRA with 5k on it
-Custom sch40 near equal volume turbo manifold. Leaves lots of room for downpipe. Ceramic coating, has dulled in very tight areas. I built this and an entire thread on the construction of it can be found here: Manifold building adventure .There is no way around it, this is a really nice piece. Sounds really, really good. Not even 1k on it.
-Tial MV-R wastegate - 4k will come with water fittings and all clamps/barbs/fittings
-10an aluminum oil drain adapter.
-A mix of summit/earls fittings for the oil/coolant lines
-ATP -4 restrictor
-3/4BSPT to -10 oil drain block adapter
-metric to AN for coolant & oil feed line(s).
-All assembled hoses
-Custom downpipe & wastegate dump. Downpipe isn't fully shown, there is another piece that joins up to the factory cat location. Downpipe uses a 3'' vband to join the two pieces. 3'' 4bolt flange for the gt30. Has wideband bung. Only thing to note is the 4bolt flange is slightly warped. It seals fine, used it for my past two track days. The downpipe *should* line up with your existing exhaust(s13/r32) but I cannot 100% gaurantee. If it doesn't, it won't need much modification.
PRICE: $2300 + SHIP. Probably in 2 boxes as it all together is heavy & cumbersome.
Notes on setup: Please note the motor mounts used. Not sure what else it will fit. I don't know LHD fitment, But I can find out. Does not allow factory PS res location. Can include PS "U" bend hardline to relocate the res as seen in some pics.
Zacho is offline   Reply With Quote
Old 07-28-2012, 06:19 PM   #2
Zacho
Some additional pics, I can also split it up now.
Old 07-28-2012, 09:07 PM   #3
lrb99
lrb99 is an unknown quantity at this point
How much for the intake pm me
.........Whipthis Drifting.........
lrb99 is offline   Reply With Quote
Old 07-28-2012, 09:27 PM   #4
SupaDoopa
SupaDoopa's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
http://zilvia.net/f/sale-items/46776...torsxdmax.html
See anything interesting for the turbo?
SupaDoopa is offline   Reply With Quote
Old 07-28-2012, 11:18 PM   #5
s13_rb25
s13_rb25 is an unknown quantity at this point
OMG i want this so bad. FUhhh i hate being broke
s13_rb25 is offline   Reply With Quote
Old 07-28-2012, 11:21 PM   #6
Nismo11
Nismo11 is an unknown quantity at this point
That turbo spools so nice. Glws
Nismo11 is offline   Reply With Quote
Old 07-28-2012, 11:26 PM   #7
mikevangs14
mikevangs14 is an unknown quantity at this point
How much for the oil return line with the fittings for turbo and side of block?
mikevangs14 is offline   Reply With Quote
Old 07-28-2012, 11:27 PM   #8
mikevangs14
Shipped to 46227? Lol forgot to add that part
Old 07-29-2012, 06:16 AM   #9
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Luvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of light
Feedback Score: 81 reviews
Fuck I want this setup. Would drop right into my laurel. Your video is sick man. Its one of the reason I chose the GT30R.
How much for the setup without the turbo?
Luvs2slide is offline   Reply With Quote
Old 07-29-2012, 07:33 AM   #10
turbob16ef
turbob16ef's Avatar
turbob16ef is an unknown quantity at this point
How much for turbo shipped to 29907?
turbob16ef is offline   Reply With Quote
Old 07-29-2012, 08:18 PM   #11
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Interested in a trade minues the turbo for a HKS setup + cash?
Old 07-29-2012, 08:47 PM   #12
BoredEE
BoredEE is an unknown quantity at this point
Where did you find the BSPT to -10an adaptor? (I must fail at google)
How much do you want for it?
BoredEE is offline   Reply With Quote
