Old 08-04-2012, 11:13 AM   #61
hamiltonbmx
hamiltonbmx's Avatar
hamiltonbmx is an unknown quantity at this point
Had the same problem in my old 240 the plug on the starter would deside when it was connected or not just zip tied it on tight and worked sorta
hamiltonbmx is offline   Reply With Quote
Old 08-04-2012, 08:30 PM   #62
slidesquad240
slidesquad240 is an unknown quantity at this point
thanks for the input man its not turning over when it doesnt start. im starting to think its the ignition itself considering its loose on the column would that do it?
slidesquad240 is offline   Reply With Quote
Old 08-04-2012, 08:41 PM   #63
hamiltonbmx
Well if you its not that plug then I'm not sure. I also had ignitior chip go bad did that too
Old 08-04-2012, 08:58 PM   #64
Javi802
Javi802's Avatar
Javi802 is an unknown quantity at this point
Edit: i didn't see that he said he switched the battery, hehe
Javi802 is offline   Reply With Quote
Old 08-05-2012, 01:50 AM   #65
BlueMax240
BlueMax240's Avatar
BlueMax240 is an unknown quantity at this point
I can assure you it is not any of the relays. If any of the relays were bad you would NOT hear a click sound at all. If you have a new battery and a new starter than it should no longer be either of those. I have had the same problem for a long time now replacing the battery, alternator, starter. The problem is the ignition switch. There is only 1 screw holding that onto the lock cylinder and sometimes when you put your key in and turn it, it causes the plunger in the lock cylinder to push the switch assembly just far enough away where good contact isn't made. Next time it happens, try and pound with your fist the top of the steering column just above the key cylinder. If your car starts after that as mine does then you know the problem area.
BlueMax240 is offline   Reply With Quote
Old 08-05-2012, 10:54 AM   #66
slidesquad240
i had replaced the ignition switch with a used one oout of my other car it was good for about a week that was about 2 months ago now. should a new one do the trick?
Old 08-05-2012, 12:01 PM   #67
ixfxi
Guest
Posts: n/a
rewire your starter with a high quality relay harness, bypass oem.
Old 08-05-2012, 05:40 PM   #68
BlueMax240
BlueMax240's Avatar
I would definitely go that route as using old used electrical parts is always dicey at best. I just wish the Nissan engineers had made a two screw attachment for the switch to the lock cylinder in the S13 like they did for the Maxima. Just a weak design IMHO. I have not replaced mine so far as it is a very infrequent problem and banging on the column so far always cures it for me.
Old 08-06-2012, 08:31 PM   #69
slidesquad240
yeah i found one online for 65$ brand new not bad im gonna ordr one in a few days. ive heard these switches go bad like its there job
Old 08-06-2012, 10:31 PM   #70
AsleepAltima
AsleepAltima's Avatar
AsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura about
i didnt read the whole thing but did anyone recommend smacking the starter with a mallet or hammer and then trying to start it?
AsleepAltima is offline   Reply With Quote
Old 08-08-2012, 05:06 PM   #71
slidesquad240
starters new
Old 08-09-2012, 09:12 PM   #72
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
i found my ignition switch was off from its original position. fixed it back and it never miss after that. i will post again after a week and let you guys know.
Old 08-09-2012, 09:13 PM   #73
wangan_cruiser
kouki man
Trader Rating: (36)
bought a new one from ebay for $14 shipped.
Old 08-10-2012, 10:45 AM   #74
slidesquad240
How was it off? I had a few broken wires in the driver side wheel well and it hasn't done it all week?
Old 08-11-2012, 03:10 AM   #75
wangan_cruiser
kouki man
Trader Rating: (36)
the screw was loose, so when you turn your key the switch itself moves, wont make a solid contact
Old 08-11-2012, 10:30 AM   #76
kennedy8383
kennedy8383's Avatar
kennedy8383 is an unknown quantity at this point
heres the deal my car will randomly decide not to start it willl just click whren turn the key i replaced the ignition switch battery and starter. it doesnt do this everytime i try to start the car only once a day usually around the same time? i know weird. my ignition itself is kind of loose on the coulmn do you tink that could be the issue? anyhelp would be great thanks
Probably loose connections problem.. I had this same problem and it was wiring and loose problem. IF the battery seen 12 volts than it ok and if you turn the starter and it turn slowly then it probably about to go.
kennedy8383 is offline   Reply With Quote
