Old 06-06-2004, 02:57 PM   #1
Strider
Strider is an unknown quantity at this point
s13 Silvia Headlight cracked
Okay, I cracked my headlight. UGH!
Now I have another spare one that doens't work, but the glass is still good.
So my question is, How do I remove the glass housing off the actual headlight. I know i'm supposed to remove all the rubber stuff and wiring then put it in the oven. But at what temp? ??
Anyone know exactly how to do this? I can't stand having this broken light especially after I bought some new bulbs for it.
-Frank
I refuse to answer that question on the grounds that I don't know the answer.
Strider is offline   Reply With Quote
Old 06-06-2004, 05:37 PM   #2
s13driver
s13driver is an unknown quantity at this point
pre heat over to 400 for 10 mins. then turn it off. put headlight in for 5~10 mins, depends situation, with the oven off. pry it open slowly. if it is too hard to pry it open. then keep repeat the process you can actually find more info about this @ www.hidforum.com good luck
s13driver is offline   Reply With Quote
Old 06-06-2004, 06:25 PM   #3
Strider
thanks a lot!
Old 10-02-2005, 10:16 AM   #4
jazzm
jazzm is an unknown quantity at this point
Did this work? I would like to open the headlight and flip the cutoff shield around so it doesn't blind people and lights up the road a little better.
Thanks,
Jazz
jazzm is offline   Reply With Quote
