Old 09-05-2012, 04:45 PM   #1
victormak91
victormak91 is an unknown quantity at this point
Cant start engine when MAF is disconnected
hi, ive been having start up issues n drivablity issues where the rpm would dip n lose power everytime i go over bumps on the road. I suspect the maf of going bad, so i tried disconnecting the maf and tried started the car, but it wont start. I thought the car will still start with the maf disconnected but in limp mode. Whats wrong with the car? my car is a obd2 s14 ka24de
victormak91 is offline   Reply With Quote
Old 09-06-2012, 11:30 AM   #2
victormak91
bump this is just a quick question
Old 09-06-2012, 11:41 AM   #3
boostedsi
boostedsi is an unknown quantity at this point
I had this issue on my 2jz jdm motor , over time the connections rusted and corroded, so i took it off fixed that up with some new wire and also used a brake cleaner to clean the maf sensor itself, put it back on worked like a charm, but yes the car win't start with out the maf at all.
hope this helps
boostedsi is offline   Reply With Quote
Old 09-06-2012, 12:44 PM   #4
blessedhellrider
blessedhellrider's Avatar
blessedhellrider is an unknown quantity at this point
hope this helps
for some reason Toyota has problems like that.had to fix a friends 7MGTE.
blessedhellrider is offline   Reply With Quote
Old 09-06-2012, 12:47 PM   #5
240dream
240dream's Avatar
240dream is an unknown quantity at this point
repin the maf its super easy, use a paper clip and remove each wire from maf connector then find some spare connectors from your harness and depin/repin them into your maf connector
240dream is offline   Reply With Quote
Old 09-06-2012, 01:08 PM   #6
Darren
Darren's Avatar
Darren is an unknown quantity at this point
hmm, my s13 sr starts without the mafs connected... i would think the kad would too...
Darren is offline   Reply With Quote
Old 09-06-2012, 01:41 PM   #7
pacotaco345
pacotaco345's Avatar
pacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond repute
My ka starts without the maf plugged in... It is obd1 tho
pacotaco345 is offline   Reply With Quote
