Old 09-06-2012, 06:25 PM   #1
247_c2c
247_c2c is an unknown quantity at this point
Sr20det overheating :(
Hey everyone I just rebuilt my Sr new Megan racing rad new hoses new water pump and it's overheating I haven't replaced the thermostat because it still looked in good condition but I will be replacing that tomorrow... Any ideas on what it could be?? I have an electric fan that's hooked up to the ignition so it's on 100% of the time...
Any help would be greatly appreciated
247_c2c is offline   Reply With Quote
Old 09-06-2012, 06:29 PM   #2
rb25_s13*CHUKI
rb25_s13*CHUKI's Avatar
change coolant sensor and temp sensor, at the same time you change your thermostat, Then bleed the system. Also I do not care what people read online or what they think they know, Please use water wetter. It does drop your temp a bit and helps with hot spots in the block/head. I swear by that stuff I always use it and it's awesome, I seen instant temp drop using water wetter.
I like to use a full bottle of water wetter, with mostly water and a little bit of coolant, Straight coolant not 50/50. You don't need coolant with water wetter because it does the same thing as water wetter but for street cars i always put a little bit of coolant for extra corrosion protection
Obliterate
rb25_s13*CHUKI is offline   Reply With Quote
Old 09-06-2012, 06:30 PM   #3
rb25_s13*CHUKI
You will be using coolant sensor and temp from a s13 ka24de or possibly a 91-94 sentra Se-r.
Obliterate
Old 09-06-2012, 06:30 PM   #4
rb25_s13*CHUKI
The coolant sensor is like $10 and the temp is $10. Also the bleeder bolt is on the water neck right next to the Oil dip stick
Obliterate
Old 09-06-2012, 06:42 PM   #5
247_c2c
How would you do the bleeding? I usually did the old method which was to take off rad cap let it burp and then then it starts to over flow to put cap on and done...
Old 09-06-2012, 06:44 PM   #6
rb25_s13*CHUKI
That works to a certain extent but sr20 are picky bitch engines and need more attention. It's a 10mm bolt just unscrew it and let it burp the air out from there, After a while you'll see coolant start to spit out a little bit and let it do that until its flowing like a volcano. Sometimes it might act like a geyser and spirt water up just straight water, either one of those is a sign that all the air is out and time to put the bolt back in. I'd wear gloves doing this cause that water can get stupid hot
Obliterate
Old 09-06-2012, 06:45 PM   #7
rb25_s13*CHUKI
Also are your fans pulling air into the engine bay or pushing air out?
Obliterate
Old 09-06-2012, 07:08 PM   #8
247_c2c
Well it was pulling it and i had in front of the rad so I reversed it and they help a shit ton... Im gonna try the bleeder screw because I'm thinking that's it... Would I do it with the cap on or off??
Old 09-06-2012, 07:29 PM   #9
247_c2c
And should I do it to where it's like a steady stream or dribbling out? Or like a water hose like continuously flowing??
Old 09-06-2012, 08:00 PM   #10
S14DB
AFC #1
S14DB's Avatar
Coolant raises the boiling point, prevents corrosion and flashing. I would run 50/50 in a street car.
Old 09-06-2012, 08:01 PM   #11
247_c2c
That's what I'm running now...
Old 09-06-2012, 08:03 PM   #12
rb25_s13*CHUKI
So does water wetter
Obliterate
Old 09-06-2012, 08:05 PM   #13
247_c2c
So what about the bleeding process?? Like a lot or to where is comes out a Lil then stops then goes again?
Old 09-06-2012, 08:07 PM   #14
rb25_s13*CHUKI
yea put them inside the engine bay pulling air into the bay, do it with the cap on and you want it a constant flow of water
Obliterate
Old 09-06-2012, 08:08 PM   #15
rb25_s13*CHUKI
Constant flow of water
Obliterate
Old 09-06-2012, 08:09 PM   #16
247_c2c
Ok I'll have to mount the fan in the engine bay... I have it in front of the rad but pushing.. So I'll do that tomorrow as well
Old 09-06-2012, 08:09 PM   #17
rb25_s13*CHUKI
When its dribbling out and spitting at you thats the air getting pushed out of the system, once it starts a steady flow then your good to go.
Obliterate
Old 09-06-2012, 08:10 PM   #18
247_c2c
Ok yea I'll do that tomorrow when I change the thermostat
I smell coolant inside the car also so I think the heater core might be leaking also :/
Old 09-06-2012, 08:11 PM   #19
rb25_s13*CHUKI
your using one fan? what size fan is it? that would also be a problem with electric fans, unless is a ford taurus single fan with 3 speeds your gonna need two fans, Esp if they are the godspeed or cx racing fans, they have no where near as much cooling affect on the engine as the stock clutch fan
Obliterate
Old 09-06-2012, 08:12 PM   #20
rb25_s13*CHUKI
Mine did that shit too! It's a bitch! that would allow air into the system even if you bleed it
Obliterate
Old 09-06-2012, 08:13 PM   #21
247_c2c
Yea!? Damn! Ok I'll just bypass it tomorrow lol I have a lot to work on tomorrow... Oh well as long as it stops over heating
Old 09-06-2012, 08:15 PM   #22
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Actually, you dont want to run just water and water wetter. Water wetter doesnt have any anti-rust property. You want some coolant in there to prevent rust and the coolant acts like a lubricant to the water pump. That's the reason the instructions on the bottle tells you to run some coolant with it.
Best way to bleed the SR in my experience is raise the front as high as possible, take the cap off, massage the upper radiator hose while the car is running and keep the radiator topped off. Once you stop seeing bubbles come out and you start feeling the hose getting hot, it should be good.
CLICK HERE!!!
Old 09-06-2012, 08:21 PM   #23
blessedhellrider
blessedhellrider's Avatar
blessedhellrider is an unknown quantity at this point
CFM is really important. are they cheapo fans? your going to need about 2000/3000 CFM
blessedhellrider is offline   Reply With Quote
Old 09-06-2012, 08:21 PM   #24
rb25_s13*CHUKI
that is what i said my friend! i add a bit of cooooolant! I did say you don't need coolant didn't i, I argued with my self in the same post hahaha. Ok yes you need coolant but you don't add the 50/50 mix as you will be running mostly water anyways so add straight coolant so it's not too watered down
Obliterate
Old 09-06-2012, 08:24 PM   #25
fliprayzin240sx
I usually toss one of the gallon 50/50 coolants in the radiator, then the water wetter and top it off with distilled water. You want distilled water since its pure and doesnt have any contaminants. The contaminants in tap water is what could potentially cause your engine to rust.
CLICK HERE!!!
Old 09-06-2012, 08:28 PM   #26
rb25_s13*CHUKI
Yea distilled water is the goods! I usually add straight coolant and just let it mix with the water that I'm already adding, Have you tried Super coolant or that royal purple max cool? Everyone has they're own way of doin thangs!
Obliterate
Old 09-06-2012, 08:30 PM   #27
rb25_s13*CHUKI
When you bought the megan radiator was it new or used? Either way did you run a hose through it for a few mins before installing it? Some times with the cheaper radiators they have metal shavings inside and cause the rows to get clogged and then pump those shavings right into your engine
Obliterate
Old 09-06-2012, 08:34 PM   #28
247_c2c
It was a used rad from a local performance shop
Old 09-06-2012, 08:47 PM   #29
S14DB
AFC #1
S14DB's Avatar
No it doesn't it's just a surfactant.
Did you flush it with a hose like stated above? You have to wonder why it was sold in the first place.
I have to think its the thermo.
Old 09-07-2012, 02:53 PM   #30
247_c2c
Well I bled the system yesterday while I was at work and it didn't overheat on my way home and I bypassed the heater core right now and let the bleeder open for like 15 mins and it was like a consistent dribble so idk it that worked... I also added the water wetter to the mix aswell
