Old 09-09-2012, 02:55 PM   #1
DamnedButDetermined
DamnedButDetermined's Avatar
DamnedButDetermined is an unknown quantity at this point
What to do with EGR Canister Control Solenoid Valve Connector when removing emissions
I am attaching a drawing that shows everything that I am removing outlined in red. Removing everything is very straight forward because all you are dealing with are vacuum lines. However the EGR Canister Control Solenoid Valve and SCV Control Solenoid Valve both have electrical connectors coming from the wire harness. When I eliminate those two solenoid valves what should I do with the electrical connectors? Can I just tape then to the wire harness so they are out of the way or do I need to actually need to leave the solenoid valves and connect the wires to them but remove the vacuum lines?
I was hoping to remove the complete plate on the back of the cylinder head that those two solenoid valves are attached to.
I have searched for this answer for about and hour and haven't found anyone making mention of the electrical connectors and what they did with them.
Thanks,
Zac
DamnedButDetermined is offline   Reply With Quote
Old 09-09-2012, 03:58 PM   #2
booey13
Trader Rating: (91)
booey13 is an unknown quantity at this point
Feedback Score: 91 reviews
Just let them hang, ziptie, tape whatever.
www.monkeyboysyo.blogspot.com
booey13 is offline   Reply With Quote
Old 09-09-2012, 04:02 PM   #3
DamnedButDetermined
They won't cause any issues with the ECU throwing codes?
Old 09-09-2012, 04:56 PM   #4
JasianBlazin
Trader Rating: (24)
JasianBlazin is an unknown quantity at this point
Feedback Score: 24 reviews
is this obd2?
JasianBlazin is offline   Reply With Quote
Old 09-09-2012, 05:16 PM   #5
DamnedButDetermined
Originally Posted by JasianBlazin View Post
is this obd2?
The wire harness/chassis/ECU is from a 93 hatch but I will be using a 95 KA24de along with the 95 intake manifold but I will be using the 93 fuel rail assembly to keep the original wire harness nice and neat. I will only be using vacuum for the fuel pressure regulator and brake booster, until I decide to go turbo.
Zac
Old 09-09-2012, 09:52 PM   #6
booey13
Trader Rating: (91)
No sir. Mine were disconnected for years when I was NA.
Old 09-10-2012, 06:47 AM   #7
DamnedButDetermined
Thanks!
Zac
