Old 10-09-2012, 02:16 PM   #1
Eramo323
Trader Rating: (22)
Eramo323 is an unknown quantity at this point
Feedback Score: 22 reviews
Send a message via AIM to Eramo323
Overheating at high rpms or high speed only
Raidiator bubbles :/ - YouTube
Only overheating at high RPMS and or High Speed
Thermostat was removed because i thought it was possibly stuck closed
fan clutch is working properly (or so I think?)
no signs of leaks -.-
I provided a video that i uploaded to YouTube showing tiny air bubbles every time i give the engine gas...
I'm thinking possible head gasket?
Not sure tho, There is no coolant in the oil or oil in the coolant and no white smoke coming from the tail pipe
Eramo323 is offline   Reply With Quote
Old 10-09-2012, 02:21 PM   #2
s13mikesr20
s13mikesr20 is an unknown quantity at this point
Outer headgasket is muffed up recommend radiator pressure text and leak down test
s13mikesr20 is offline   Reply With Quote
Old 10-09-2012, 03:30 PM   #3
shagspeed
shagspeed is an unknown quantity at this point
DO NOT remove the thermostat .... The dam SR20 pumps flow crazy volume... The Thermostat acts as a restriction .. You take it out and for sure it will over heat .... The water passes the core quick enough it can't cool.. A larger radiator will help put at least cut out the spring and maybe the diaphragm if its truly stuck but water volume needs to be slowed down ...
Also bubbles could be that the water is boiling in the block or head .. This too is very bad if air gets stuck in the block as it will create hot spots and I have seen engines lost to this as well ...
I recommend running Evans NRG+ if you can afford it.. It will not boil tell 375* and it doesn't expand .. You can also run a ZERO or LOW pressure cap and it will be easier on all your coolant lines as well ..
1. Replace TSTAT
2. Evans NRG+ Coolants ยป Engine Cooling Systems
3. Optional - Low or Zero pressure cap ..
Hope that helps ..
shagspeed is offline   Reply With Quote
Old 10-09-2012, 07:47 PM   #4
dawagarage
dawagarage's Avatar
dawagarage is an unknown quantity at this point
higher rpms/speeds = more rpms = more explosions = more heat.
step up your cooling system. (your probably knew this.. maybe the next person doesnt?)
also, something else i recently learned about, (in regards to you removing the thermostat that acts as a restrictor) is cavitation damage to front cover, water pump, etc.)
formerly known as "hotboiblaze"
ratsun: dawa (73 datsun 620)
clublexus: properD (97 sc300)
dawagarage is offline   Reply With Quote
Old 10-09-2012, 08:09 PM   #5
Prozac
Prozac is an unknown quantity at this point
Get a thermostat , cooling requires time!
Bubbles , you either have air in your cooling system or headgasket problem , feeding back crankcase pressure into cooling system. Start the car cold with the rad cap off get up to operatiing temp, holding throttle around 3k rpm , once your thermostat opens you should get a flow , throttle the engine and watch for bubbles , burp the cooling system of air you should have a bleeder screw on the neck 10m open it wait for fluid and tighten. Let cool down remove rad cap ,start car hold throttle at around 2.5 rpm and if you get bubbles you have Mild HG problem that could blow a rad , hoses and more.
Prozac is offline   Reply With Quote
Old 10-09-2012, 10:17 PM   #6
RU4REAL
RU4REAL's Avatar
RU4REAL is an unknown quantity at this point
It wouldn't hurt to check your timing. SR's like 15 degrees. Anything less, you'll get heat soaked and temps will rise.
RU4REAL is offline   Reply With Quote
Old 12-15-2012, 04:54 PM   #7
Natural Aspirations
Natural Aspirations is an unknown quantity at this point
Did you thigure it out?
Looks like you need a head gasket. Have you figured it out if not I can help.
Natural Aspirations is offline   Reply With Quote
Old 12-15-2012, 05:14 PM   #8
JFoxx
JFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choices
something else that could effect it are pinholes in your cooling system, they will draw air into your cooling system (wont leak) and sr absolutely hate air in the system, it happend to me before....
JFoxx is offline   Reply With Quote
Old 12-15-2012, 05:26 PM   #9
steve shadows
steve shadows's Avatar
You should always run a thermostat...it helps keep the pressure in the cooling system at the correct level. Get a nismo one asap. Also I would do a leak down and compression test when the motor is cold to see if anything on the head is leaking. Good luck!
Like Me on FaceBook !
Old 12-15-2012, 05:50 PM   #10
Wookie384
Wookie384's Avatar
Wookie384 is just really niceWookie384 is just really niceWookie384 is just really niceWookie384 is just really niceWookie384 is just really niceWookie384 is just really niceWookie384 is just really niceWookie384 is just really nice
Send a message via AIM to Wookie384
It might be a long shot but with the thermostat out, the cooling system is flowing too freely, and every-time your at high engine speeds the water pump could be cavitating causing air to separate from the coolant and appear in the system.
Wookie384 is offline   Reply With Quote
Old 12-15-2012, 06:07 PM   #11
240shawty
240shawty's Avatar
240shawty is an unknown quantity at this point
im pretty sure that running the engine with the radiator cap off bleeds the coolant system of air.....
240shawty is offline   Reply With Quote
Old 12-15-2012, 06:10 PM   #12
240shawty
240shawty's Avatar
like the wookie mobile
Old 12-15-2012, 06:13 PM   #13
rb25_s13*CHUKI
rb25_s13*CHUKI's Avatar
Hold up pause that motion, that is false son!
Obliterate
rb25_s13*CHUKI is offline   Reply With Quote
Old 12-15-2012, 06:18 PM   #14
JFoxx
^^^ what he said..... but a swirl pot will....
Old 12-15-2012, 06:42 PM   #15
240shawty
240shawty's Avatar
well please inform me then
Old 12-15-2012, 06:56 PM   #16
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
Bubbles 100%
Old 12-15-2012, 08:05 PM   #17
Wookie384
Wookie384's Avatar
uhhhh....what are you trying to say? lol
Old 12-15-2012, 10:27 PM   #18
Kingtal0n
Kingtal0n's Avatar
you can also get bubbles if the coolant is contaminated with power steering fluid or any number of other car related fluids.
Pressure the coolant system with the engine off and check for leaks. A leak can let water out, or air in. Do NOT flip out and automatically assume the headgasket is toast.
And, I see metal end tanks. Is that a KA radiator?
tinyurl.com/4l80er
Old 12-30-2012, 05:33 PM   #19
Eramo323
Trader Rating: (22)
water pump gasket was fucked!
Old 12-30-2012, 09:23 PM   #20
jt1583
jt1583 is making a name for him/her selfjt1583 is making a name for him/her self
I believe you but how would air get into the coolant system from a bad WP gasket? Just curious, glad you found the issue.
jt1583 is offline   Reply With Quote
Old 01-03-2013, 01:36 PM   #21
Eramo323
Trader Rating: (22)
^^^ no clue but I replaced it and the thermostat housing gasket and it stopped heating up and losing coolant
Old 01-03-2013, 01:37 PM   #22
shaggy sr
shaggy sr's Avatar
shaggy sr is an unknown quantity at this point
the same happened to me. check my thread. Maybe it will help u
shaggy sr is offline   Reply With Quote
Old 01-03-2013, 10:31 PM   #23
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Serious question? What happens when you pour water out of a cup? Does the water level stay the same?
CLICK HERE!!!
