Old 10-22-2012, 07:37 PM   #1
Frank_Jaeger
Axle nut cap won't go on
I'm installing my Drop Engineering 5-lug hubs, and I can't get the axle cap back on . It's not bent or anything, I think the inside diameter of the hub is too small for it to fit. Does this sound right, or am I a retard?
When I hit it, one side will go into the hub, and the opposing side will push out. I checked to make sure the cotter pin isn't obstructing, and it isn't. I can't get this fucking thing on. If I hit it harder with the mallet, it just pops itself off.
EDIT: Sorry guys, didn't even check what subforum I was in.
Frank_Jaeger is offline   Reply With Quote
Old 10-22-2012, 07:53 PM   #2
PureRush
PureRush is an unknown quantity at this point
You don't even need it lol
PureRush is offline   Reply With Quote
Old 10-22-2012, 10:04 PM   #3
Frank_Jaeger
Are you sure? As it was, there was very minimal corrosion underneath the cap, even after 20 years. And no dirt.
Old 10-22-2012, 10:30 PM   #4
beems240sx
beems240sx's Avatar
beems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant future
post pics to show what you mean. just the cover for the nut? yeah done need that
beems240sx is offline   Reply With Quote
Old 10-23-2012, 12:38 AM   #5
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
Yes you absolutely need it.
The front wheel bearings are not sealed -- without the dust cap you will experience premature wear and failure of the wheel bearing.
e1_griego is offline   Reply With Quote
Old 10-23-2012, 01:11 AM   #6
Sileighty_85
Sileighty_85's Avatar
Youp^
PO removed mine before I bought it and the WB were destroyed.
you need to tap it in evenly. If you have a Micrometer check both diameters.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 10-23-2012, 08:19 AM   #7
Frank_Jaeger
Originally Posted by Sileighty_85 View Post
Youp^
I've tried. it always ends up uneven. I don't have a micrometer, I'll just sand down the lip of the cap until it fits. Thanks guys.
Old 10-23-2012, 12:07 PM   #8
dawagarage
dawagarage's Avatar
dawagarage is an unknown quantity at this point
are you hitting it with a hard or soft mallet?
a hard (metal) mallet poses the risk of damaging/disfiguring the cap
formerly known as "hotboiblaze"
ratsun: dawa (73 datsun 620)
clublexus: properD (97 sc300)
dawagarage is offline   Reply With Quote
Old 10-24-2012, 07:10 PM   #9
Frank_Jaeger
Soft rubber mallet. I tried the caps on my old hubs and they fit perfect, but not on my new hubs. I'm not hitting them hard enough to disfigure them anyway.
What else can I do besides sand the lip?
Old 10-25-2012, 06:31 AM   #10
Mikester
Mikester's Avatar
Do a search for wheel bearing dust caps
https://www.google.com/#q=wheel+bear...w=1280&bih=808
Find one with an OD that matches the measurement you need for the DE hubs. Not saying it can't be done, but sanding them thinner than they already are to fit may not be the best course of action.
Old 10-25-2012, 11:03 AM   #11
tapdeznutz
tapdeznutz's Avatar
Trader Rating: (50)
tapdeznutz is an unknown quantity at this point
Feedback Score: 50 reviews
use some light grease on the cap to help it tap in. Get it tap, lol never mind.
FS: DSS 1pc Steel Non ABS, 6bolt axles
WTB: Boost Gauge, Hatch Roof Wing
tapdeznutz is offline   Reply With Quote
