Old 06-19-2004, 05:30 PM   #1
DJ_Sunrise
DJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to all
Send a message via AIM to DJ_Sunrise
s13 i had a car accident.. front right suspension is nearly gone.
well.. i had an accident in my 92 240. i wish i had been smart enough to turn into the curb so atleast my suspension woulda bottomed out and bent my rim, not snapped my control arm, bent my tie rod and axle, wasted my rim and tire, and left a big dent right behind my tire, by the passenger. looks like unerneath the car, those are the only parts damaged. oh yea.. and i cant get my lug nuts off the wheel. i was wondering how much im going to spend trying to fix the damage? i have a 300z setup all the way around riding S14 spindles.
1)front right axle is bent
2)FR tie rod- tension rod?
3)hub and spindle?
4)my strut tower cap popped off, so im assuming theres some strut damage
5)crack in sidewall by tire.. should i get it fixed or what? whats my next step?
all of a sudden, i dont care about getting good gas mileage.. id rather my car just drive.
~Sunrise
DJ_Sunrise is offline   Reply With Quote
Old 06-19-2004, 05:35 PM   #2
NismoSilvia270R
NismoSilvia270R's Avatar
NismoSilvia270R is an unknown quantity at this point
Send a message via AIM to NismoSilvia270R
front axle?
whats your tension rod look like? and that brace its attached to?
look at where the frame comes together(seam) and hope it isnt wavy.
NismoSilvia270R is offline   Reply With Quote
Old 06-19-2004, 05:59 PM   #3
msaskin
msaskin is an unknown quantity at this point
Send a message via AIM to msaskin
It's a front tie-rod and end, not an axle
Also, I would suggest not repairing a cracked wheel, assuming you can even find a shop that will repair it. A cracked wheel will never be structurally solid again, just buy a new one.
~matt
it's not turbo lag...it's foreplay
'01 Ford Excursion Limited.
Powerstroke Diesel
Coming in spring: ???
msaskin is offline   Reply With Quote
Old 06-19-2004, 06:44 PM   #4
DJ_Sunrise
well.. i bent both the front tie-rod and end, not an axle, lol.. theres a big ass dent in my sidewall where my wheel rammed into. fixxing the rod and axle cant be that hard, and replacing my rim is fine, i have a 300z one on there. i just found out that what the front control arm attaches onto, braces the 2 pieces of the unibody chassis, and the engine mounts. im so fukked . im gonna have to get a torch and bend that piece back to normal, which shouldnt be too hard . but is there anything that could have been severly damaged between my wheel, and the passenger? theres a big ass dent where the wheel was. do you guys think my hubs and spindle might be messed up? i took a bunch of pictures, ill post them up soon.. if anyone knows of a mechanic in the central NJ area that can help me out, please.. help!!! i put my car on the RIP list, but i need to save her!!! the parts shouldn't be too expensive, since my bro works at a nissan dealer. or lets hope they wont be.
~Sunrise
Old 06-19-2004, 07:23 PM   #5
NismoSilvia270R
i just replaced that whole side twice. the spindles and hubs were fine but i changed them anyway (got a whole setup dropped from the j-yard) um, i dont recommend heating and bending back.
i also needed a new rack.
as for the labor. i did it all in two days with a jack and two stands. tools: craftsman kit with 50 pcs.
not too bad.
Old 06-24-2004, 10:01 PM   #6
niceassfd
niceassfd's Avatar
niceassfd is an unknown quantity at this point
im going throught the same thing but on the left side. i have a s13. right now i got a s13 lca with a s14 ball joint. and i got tein t/c rods. im going to put on s14 five lug nuckle and hub. good luck with yours. i don't know if you have a s13 or s14.
niceassfd is offline   Reply With Quote
Old 06-26-2004, 03:02 PM   #7
DJ_Sunrise
i just remembered.. i have a 300z brake setup all the way around.. shiiiitt. and since they were on my car when i bought them.. i gotta find out what on my car is S13/S14/Z32. fudge.
~Sunrise
