Old 11-09-2012, 05:36 PM   #1
karate_crimson
karate_crimson is an unknown quantity at this point
1985 AE86 Trueno
Car is now on eBay!
http://cgi.ebay.com/ebaymotors/Toyot...ht_4386wt_1165
Just looking for this car to go to a good home. Here goes...
General
1985 Toyota Corolla GT-S
Manual Transmission (no leaks)
Clean Title
No AC, Heater, or PS
Tags good until 3/2013
Please Note:
Car has come up on some maintenance due dates:
*Needs a new fuel sending unit
*Needs thermostat replacement (runs cooler)
*Needs JDM front bumper brackets
Could use seat & carpet re-upholstery
Could use new driveshaft joint
Could use a newly perfected tune
Could use tire replacement soon
Could use new input shaft bearing for transmission
Could use new springs, this car does not deserve cut springs, even if they are TRD
Exterior
-JDM Zenki Trueno Front Bumper w/ emblem
-Authentic Vintage Cibie Foglights
-Custom JDM Zenki Turn Signals w/ Parking Light (Brand New)
-JDM Zenki Signal Lenses (Brand New)
-Seibon Carbon Fiber Hood
-Carbon Fiber Headlamp Covers
-JDM Trueno Rain visor w/ rubber edge guard
-14" Watanabe RS8 w/ Falken Azenis RT-615
-JDM Zenki Trueno Side Molding Decals
-JDM Zenki Trueno Hatch Decals
-JDM Zenki Trueno Rear Bumper
-JDM Zenki Trueno Rear Mudflaps
-JDM Zenki Trueno Taillights
Interior
-Complete Zenki Maroon/Red Interior w/ Privacy Cover
-RARE 80's Toyota Radio/Tape Player w/ Equalizer System
-JDM Zenki Trueno Cluster
-RARE JDM Maroon Door Cups
-RARE Italvolanti Admiral Steering Wheel
-SMITHS 12k Tachometer face & needle (not installed)
-JDM Zenki Trueno Auxiliary Light Switch
Engine
-20v Silvertop 4AGE (Dyno'd 156whp @9,000rpm), detuned for daily driving @ 140hp @8,000rpm
-Custom 4-2-1 header w/ HKS Sport Exhaust System
-Complete Engine Teardown & Rebuild (less than 1,000 mi on engine) original receipts available
-JSP 16V WATERLINE REROUTE
-304/304 TODA cams
-TODA Adjustable Cam Gears
-Supertech Valve Springs
-ARP Head Studs
-TRD head gasket
-Custom machine balanced edis crank wheel and adjustable sensor bar
-Electric fan w/ Thermal switch
-AFCO Alumninum Radiator (w/ custom tuck)
-Aeromotive FPR
-SETRAB 16-row oil cooler
-Custom AN fittings
-Modified Smallport oil sandwich plate (used only as spacer)
-MOCAL Oil Filter w/ 185 deg temperature sensor
-Megasquirt 2 harness/ standalone ECU
-MSD Custom spark Wires
-TRD Engine/Transmission Mounts
-Exedy Clutch
-Fidanza light flywheel
-BRAND NEW AISIN Brake Master Clyinder
-BRAND NEW AISIN Clutch Master Clyinder
Suspension
-TRD F/R Race Springs (cut, unknown spring rate)
-KYB AGX SW20 (F) / Camaro (R) Adjustable Shocks
-Tein Camber Plates
-Nagisa Auto Shakitto Plates
-88 Rotors Cross Drilled & Slotted Rotors w/ PBR Brake Pads
-88 Rotors SS Brake Lines
-Cusco 2-way LSD (recent fluid, rear bearing change)
-Cusco Rear Adjustable Panhard Bar
Car is valued at $13,000 value.
$9,800 for everything.
$8,600 without wheels, cf hood, and lamp covers.
Feel free to PM me.
karate_crimson is offline   Reply With Quote
Old 11-09-2012, 05:50 PM   #2
Eg_type_r
Eg_type_r is an unknown quantity at this point
careful people be hating on nice ae86s around here. clean build man glws and bump for a fellow 86 owner.
Eg_type_r is offline   Reply With Quote
Old 11-09-2012, 05:53 PM   #3
karate_crimson
It's ok man, I don't know anyone on this forum so I don't see why there would be an issue.
This is a restoration, so a lot of care and detail went into it. Just a few more things would complete it more or less.
Thank you.
Old 11-09-2012, 05:57 PM   #4
Eg_type_r
im running a similar setup making a lil bit more hp should check it out
Old 11-09-2012, 06:05 PM   #5
karate_crimson
No disrespect man, but I don't feel ok with you posting your for sale link in my thread, I would kindly ask you to remove it.
Do you have a dyno sheet for proof or power output? Are you even running a programmable ECU? To me it just looks like a stock-ish sr5, running a stock silvertop with MSD ignition and velocity stacks. We are not running a similar setup at all.
Good luck with your sale though.
Old 11-09-2012, 06:22 PM   #6
nickgbmx
nickgbmx is an unknown quantity at this point
hahaha i dont see many people hating on this car, because the 10k price tag is justified with quality parts and a clean build to back it up. its not a stock sr5 with 20V swap and XXRs claiming to be a track beast haha. good luck with the sale this car has a lot of attention to detail and is very solid
NEGATIVE CAMBER SAN DIEGO CHAPTER
nickgbmx is offline   Reply With Quote
Old 11-09-2012, 06:28 PM   #7
tryangle
tryangle's Avatar
tryangle is an unknown quantity at this point
Glws man seen you building this on club4ag for years, 10,500 might be alil high for not having front bumper brackets.
tryangle is offline   Reply With Quote
Old 11-09-2012, 06:28 PM   #8
karate_crimson
Thank you sir.
Hey nickgbmx, I recognize your username, didn't we cross paths a while back? If I do recall correctly, I purchased the CF headlamp covers that are on my car now from you. You gave me a good deal on them. Haha small world, eh? Hope all is well.
Ok, I'd like to keep this thread light with comments not pertaining to a sale if possible. Please feel free to IM with off topic questions, thank you.
Thanks good sir, though I don't think lack of front brackets justifies a few thousand dollars price drop if that's what you're getting at.
Old 11-10-2012, 11:36 AM   #9
s13mikesr20
s13mikesr20 is an unknown quantity at this point
prime build right here glws who ever gets this car better not beat it up its to pretty
s13mikesr20 is offline   Reply With Quote
Old 11-10-2012, 12:00 PM   #10
karate_crimson
Thanks!
Please note: Doesn't hurt to make a reasonable offer. No trades though, please.
Old 11-10-2012, 01:14 PM   #11
turkey
turkey's Avatar
turkey is an unknown quantity at this point
very cleann bump to you sir
turkey is offline   Reply With Quote
Old 11-10-2012, 06:25 PM   #12
evils2k07
evils2k07 is an unknown quantity at this point
Bump. Haha i met this dude at 7-11, very clean 86.
evils2k07 is offline   Reply With Quote
Old 11-11-2012, 06:54 AM   #13
karate_crimson
And here I was thinking I was a stranger to these forums. Thanks for the bump people, nice meeting you as well evils2k07. Your username reminded me of which car you were driving when we bumped into each other.
Old 11-11-2012, 09:39 PM   #14
ship2236
ship2236's Avatar
Trader Rating: (18)
ship2236 is making a name for him/her selfship2236 is making a name for him/her self
Feedback Score: 18 reviews
Send a message via AIM to ship2236
Awesome man. Youve done a great job up until this point it seems. Price seems justified by the attention to detail done so far. Glws this is so close to being immaculate. Makes me miss my corolla very much so. Glws sir
ship2236 is offline   Reply With Quote
Old 11-11-2012, 09:42 PM   #15
Banana_Cute
Banana_Cute's Avatar
Banana_Cute is an unknown quantity at this point
You forgot the TOFU sign on the door.
Simplicity is the key to brilliance
Banana_Cute is offline   Reply With Quote
Old 11-11-2012, 09:45 PM   #16
s14j
s14j's Avatar
Trader Rating: (72)
s14j is an unknown quantity at this point
Feedback Score: 72 reviews
karate crimson! remember me ae86j?! don't sell it! haha you came a long way with this car looks nice!
gl with the sale but i don't think u should sale it..
95 s14 ka DD
s14j is offline   Reply With Quote
Old 11-11-2012, 09:52 PM   #17
JSimpson
Banned from the Marketplace
JSimpson is an unknown quantity at this point
BEAUTIFUL car sir. 4ag TRD love. free bump for a nice ride
JSimpson is offline   Reply With Quote
Old 11-12-2012, 07:47 PM   #18
karate_crimson
Thanks.
Yes I do, what's up? Gotta do what I gotta do...
Thank you.
Bump for some considerable offers. One I would call pending, but first with cash gets it.
Old 11-12-2012, 08:02 PM   #19
scels240
scels240's Avatar
scels240 is an unknown quantity at this point
Send a message via AIM to scels240 Send a message via Yahoo to scels240
woww finally that EG guy shuts up
i cant believe he compared his car with yours
scels240 is offline   Reply With Quote
Old 11-14-2012, 08:12 PM   #20
karate_crimson
Wednesday bump
Old 11-14-2012, 09:42 PM   #21
gusisboosted
gusisboosted is an unknown quantity at this point
I want this so bad.
petrolhead
gusisboosted is offline   Reply With Quote
Old 11-15-2012, 12:17 AM   #22
karate_crimson
Make me an offer, working to make some sort of deal. Send me an IM...
Just drove it tonight. Gives off a distinct howl at night that only individual throttle bodies could...it's addicting. I know I'm going to miss it, but I'll be back in the seat of one soon enough.
Old 11-15-2012, 12:47 AM   #23
overpaid4myfc
overpaid4myfc has made poor choicesoverpaid4myfc has made poor choicesoverpaid4myfc has made poor choicesoverpaid4myfc has made poor choicesoverpaid4myfc has made poor choicesoverpaid4myfc has made poor choices
I think if anyone of us had the cash we would be all over this thing.
I went to school with a guy who had a completely restored white 86 hatch with the same wheels mud guards and window visors it was amazing.
overpaid4myfc is offline   Reply With Quote
Old 11-15-2012, 11:30 AM   #24
Mofuhcka
Mofuhcka's Avatar
Mofuhcka is an unknown quantity at this point
Awhhh mman no trades..
@hcr32love 400whp NEO R32 Sedan
Mofuhcka is offline   Reply With Quote
Old 11-15-2012, 04:05 PM   #25
P-Funk alot
P-Funk alot's Avatar
P-Funk alot is an unknown quantity at this point
Send a message via Yahoo to P-Funk alot
what did you do with the dist.. hole in the firewall
P-Funk alot is offline   Reply With Quote
Old 11-15-2012, 04:15 PM   #26
scels240
scels240's Avatar
It says he has edis wheel
Mostly likely edis system
Old 11-16-2012, 03:38 PM   #27
karate_crimson
Yes, the car uses EDIS system with MSD ignition all synched by Megasquirt V 2.2
NO hole in fireweall, engine is distributor-less.
Old 11-16-2012, 07:21 PM   #28
Kevin920415
Kevin920415's Avatar
Kevin920415 is an unknown quantity at this point
uj!! i dont know if you remember me haha, but free bumps for you..I remember when you know what happened at gmr.. lol
You drive DA 2 fo tay?
Kevin920415 is offline   Reply With Quote
Old 11-17-2012, 01:39 PM   #29
karate_crimson
I do. Such a long time ago, fancy bumping into you here!
Speaking of bump, price drop. $9800 FIRM! Had several buyers at 10.5, but all flaked.
This is priced to move. Looking to sell within the week as I have some things to take care of. First with the cash gets it.
Old 11-17-2012, 07:18 PM   #30
Car95
Car95 is an unknown quantity at this point
This is Clean! Nice ride.
Car95 is offline   Reply With Quote
