Old 06-23-2004, 11:54 PM   #1
s13dan
s13dan's Avatar
s13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enough
20+ hp to the ground?
I heard from a lot of people and places that a turbo manifold for a S13 redtop can add 20+ hp to the ground and for S14 can be 30hp to the ground? is that true? is the stock SR manifold that shitty? and is a Z32 MAF a big preformance gain at all? need anwsers thanx
89 240sx hatch #933-the hot rod
91 240sx coupe #131,603-the daily
s13dan is offline   Reply With Quote
Old 06-24-2004, 09:23 AM   #2
msaskin
msaskin is an unknown quantity at this point
Send a message via AIM to msaskin
Being as I just put a tubular manifold on my car, I can officially say no way, it doesn't add any power.
It helped spool a little bit, but I'm attributing that to putting a new manifold->turbo gasket in place, since my old one was only about 75% there.
~matt
it's not turbo lag...it's foreplay
'01 Ford Excursion Limited.
Powerstroke Diesel
Coming in spring: ???
msaskin is offline   Reply With Quote
Old 06-24-2004, 03:10 PM   #3
-=S14=-
-=S14=- is on a distinguished road
Well, even the cheapass ebay SS autochrome manifolds have been proven to dyno 15 wheel hp. You may not feel it. But for the most part they are beneficial.
Ryan
-=S14=- is offline   Reply With Quote
Old 06-24-2004, 05:49 PM   #4
msaskin
Ryan
As I said, I just didn't feel a change. I'd imagine that the gains from a tubular manifold (i'm running an SS AutoChrome one) are much greater with larger turbos. On a T25, it was almost imperceptible, but then again, I changed a few gaskets at the same time so that may have caused my gains.
It's still well worth it, especially for only $200 or less
~matt
Powerstroke Diesel
Old 06-24-2004, 09:55 PM   #5
C.
C.'s Avatar
C. is an unknown quantity at this point
The Z32 MAF is not a performance mod, it's a supporting mod, like larger injectors, you need it if you're turning up the boost or getting a bigger turbo (or both). but everything else being equal you won't get any power from it.
C. is offline   Reply With Quote
