Old 06-17-2004, 01:53 PM   #1
SimpleS14
SimpleS14's Avatar
car will not start...any suggestions?
well...right now I'm having some trouble getting my car to start. When I turn the key I hear one click (possibly the starter) and all the dummy lights go dim and nothing else.
Is there a chance that I have to replace my starter and/or my alternator to fix this problem?
note: my car has been sitting disconnected for almost 5 days
Goals are dreams with a deadline.
L.H.O.O.Q.
SimpleS14 is offline   Reply With Quote
Old 06-17-2004, 02:58 PM   #2
drift into a curb
drift into a curb's Avatar
drift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond repute
Your battery still good? Sounds like that's the problem..
Go big or go home!
drift into a curb is offline   Reply With Quote
Old 06-17-2004, 03:08 PM   #3
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
just a suggestion because it happened to my friend, check starter wires to make sure they are good and maybe hit the starter w a hammer end, we had to hit it a few times, weirdest thing and a lot of people say it works. but it is more likely issue w battery or alt because the lites dim too.
I was going to, but I can not think of a sig less than 75 characters.
mjjstang is offline   Reply With Quote
Old 06-17-2004, 03:41 PM   #4
Demik
Demik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of light
Send a message via AIM to Demik
get a new car.. haha jk..
maybe its ur battery or ur starter.. i went through this . and found out the starter wire was loose and the battery was shoot!! now i got a ka starter motor in a sr starter case eheh and i invested in redtop.......... a optima redtop Y()()
Demik is offline   Reply With Quote
Old 06-17-2004, 05:56 PM   #5
thelinja
thelinja's Avatar
thelinja is making a name for him/her selfthelinja is making a name for him/her self
Funny, my car has been doing the same thing for the past few weeks. The problem has been that the positive battery pickup is corroded to hell. I'd check that out first. I really need to get a new one, but I can't find one that will work with the car because of the positive power that runs to the fuse/relay box. When my car does this, I just pound the pickup onto the post with a socket and that usually gives it enough contact to relay power to the starter.
thelinja is offline   Reply With Quote
Old 06-17-2004, 08:13 PM   #6
-E-
-E-'s Avatar
-E- is an unknown quantity at this point
It does work I know first hand
-E- is offline   Reply With Quote
Old 06-17-2004, 09:54 PM   #7
SimpleS14
SimpleS14's Avatar
so...I should just tap the starter...or hit is hard?...I might do that with a breaker bar.
I don't think its my battery because I tired to jump the car with no luck...the same thing happened.
L.H.O.O.Q.
Old 06-17-2004, 10:21 PM   #8
-E-
-E-'s Avatar
give it a firm tap
Old 06-18-2004, 08:37 AM   #9
thelinja
thelinja's Avatar
This also happened to me. The first time the car failed to start, I called up my brother to bring up some jumper cables, but the car still wouldn't start. We messed around with the positive terminal connection and the car regained power and started like normal.
Old 06-19-2004, 04:35 AM   #10
Matt_240
Internet Drifter
Matt_240 is an unknown quantity at this point
check your starter and battery.
have you had any problems turning your key before it stopped starting? There was one time where my ignition switch crapped out on me. you should check on that...if starter is fine and battery is good and alternator seems good. when did you last replace your starter?
Matt_240 is offline   Reply With Quote
Old 06-19-2004, 02:46 PM   #11
SimpleS14
SimpleS14's Avatar
OK....well what I have did right now was g-rig the starter directly to the battery. I can hear something spinning...but nothing else. I have not replaced my starter since I got my car (three years ago) and my battery is one year old (Die Hard Gold).
I'm guess that its not catching to the flywheel...I don't have enough room for a roll start and I have no idea where to hit the starter exactly.
L.H.O.O.Q.
Old 06-19-2004, 06:18 PM   #12
Pepperoni
Pepperoni's Avatar
Pepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nice
Send a message via AIM to Pepperoni
Yea i was gonna suggest push starting it... if it starts, then it's your starter. Can u not get it on the street so u can push start it?
Turbo piping, Intakes and More:
http://www.pipingpro.com
Pepperoni is offline   Reply With Quote
Old 06-19-2004, 08:13 PM   #13
SimpleS14
SimpleS14's Avatar
my car is located between some houses and the roads between them are very small strips with no steep slopes. I try to get the car pushing...but once I popped the clutch the car stopped. I did not have enough momentum(sp?) and road to really get somewhere.
I'm going to take off the starter and get it tested. My guess is that its not catching with the flywheel....so I might have to replace it. It's just a pain getting to that top bolt.
L.H.O.O.Q.
Old 06-19-2004, 10:59 PM   #14
Ivan
Ivan is an unknown quantity at this point
why not try a different battery also? I know you tried jumping it but maybe having the battery connected directly wouldbe better.
Ivan is offline   Reply With Quote
Old 06-20-2004, 03:48 AM   #15
Matt_240
Internet Drifter
i dont think theres a specific place to wack it. just hit it when you're trying to start it. but i guess best bet would be to take it off and test it at autozone or something, if you can't roll start it.
Old 06-20-2004, 08:09 PM   #16
SimpleS14
SimpleS14's Avatar
Tried to roll start again...but no luck. I used the battery from my other car and still the same shit. I'm going to test the starter real soon.
I need my car back.
L.H.O.O.Q.
Old 06-20-2004, 10:18 PM   #17
Matt_240
Internet Drifter
if ya tried roll starting it and it didn't start. im 95% sure its your starter. do you have someone elses starter you can borrow?
Old 06-21-2004, 02:21 AM   #18
idlafie
idlafie's Avatar
Pull both your battery & starter from the car & take them both to Pepboys/Autozone/Kragen & have them tested. If the starter turns out to be bad, DON"T get a remanufactured one from Pep Boys/ Autozone/Kragen. The remanufactured ones they get will only last you about a year or two before they start acting up also. Why do you think they give you a "lifetime" warranty on 'those" parts??
Now if your battery & starter turn out okay, then check your ignition switch. It is a five position switch that has copper contacts inside of it. The contacts on the "START" position may have gone bad on you. I had the same problem as you a while back & literally replaced everything on the starting circuit before I realized that the ignition switch had gone bad. Once I replaced the ignition switch, the car started up fine. Haven't had any starting problems ever since.
Hope this helps...
Diego
'95 SE
Old 06-21-2004, 08:12 PM   #19
SimpleS14
SimpleS14's Avatar
Hope this helps...
Diego
'95 SE
I had my starter tested...and it popped and spun just fine..the guy also said it was reaching proper levels. I will now have to test the battery. Please excuse me for being a newbie...but where is the ignition switch located exactly? and how much does it cost?
L.H.O.O.Q.
Old 06-22-2004, 08:16 AM   #20
aznpoopy
aznpoopy's Avatar
http://www.trademotion.com/partlocat...25&model=240sx
twenty-ish bucks.
iirc the iginition switch is exactly what it sounds like... its the thing u stick ur key into. of course i could (very easily) be wrong. :X
Old 06-22-2004, 10:15 AM   #21
skatanic28
skatanic28's Avatar
skatanic28 is an unknown quantity at this point
Send a message via AIM to skatanic28
if you cant even push start it my guess would be a dead battery. test it.
skatanic28 is offline   Reply With Quote
Old 06-23-2004, 03:55 AM   #22
idlafie
idlafie's Avatar
twenty-ish bucks.
Actually...you are right...and wrong....
The link you posted appears to be correct..it lists the ignition switch for $27.92...you want the SWITCH and NOT the ignition lock cylinder...the ignition lock cylinder comes with the key portion.
The ignition switch is actually located directly opposite of where the ignition key is inserted into. The ignition switch is a tannish/beige-colored switch that has 5 wires coming out of it. It's held onto the ignition lock cylinder AND the steering column by two small phillips head screws. Remove the two screws & un-plug the wiring from the wiring harness,, and the whole switch should come loose from the car. Once you get the switch removed from the car, then take a voltmeter & test the wiring on the switch. Put a small screwdriver in the slot on the front of the switch & turn the screwdriver to the five positions on the switch. Test for continuity as you turn the screwdriver from position to position. If the switch is good, then everything should check out okay. However, you may have to replace the ignition switch - the electrical contacts on the inside of the switch can go bad, (especially on the START position...remember it draws a heavy electrical load on the switch/contacts when you crank the key over to the START position).
Once you replace the defective switch, then your car should start like new.
Anyhow, hope this helps....If you need any more info just PM me....I might be able to find my old defective part & take a picture of it for you.
IdLaFie
'95 SE
Old 06-24-2004, 01:53 PM   #23
b-s14
b-s14 will become famous soon enoughb-s14 will become famous soon enoughb-s14 will become famous soon enoughb-s14 will become famous soon enoughb-s14 will become famous soon enough
Send a message via AIM to b-s14
I'm with 95KoukiS14 as he was working on his car...and MAN...the car will not start after we checked everything. He replaced the battery and ignition switch....but now when he cranks the car...smoke is coming out the starter...wtf does that mean?
b-s14 is offline   Reply With Quote
Old 06-24-2004, 02:55 PM   #24
GamblerZ
GamblerZ's Avatar
GamblerZ will become famous soon enoughGamblerZ will become famous soon enoughGamblerZ will become famous soon enoughGamblerZ will become famous soon enoughGamblerZ will become famous soon enough
Send a message via ICQ to GamblerZ Send a message via AIM to GamblerZ Send a message via MSN to GamblerZ Send a message via Yahoo to GamblerZ
Your starter gear and your flywheel teeth could probably be misaligned(tooth on tooth) creating a kink or bind. That is the reason some people whack it with a hammer. If it is not catching the flywheel, you will HEAR it.
My thinking is you have something hooked up backwards. It may sound ridiculous, but I have seen people hook up their batteries wrong. Or, perhaps the starter is hooked up incorrectly.
Visit WTI - WestTexasImports.net
GamblerZ is offline   Reply With Quote
Old 06-25-2004, 07:54 AM   #25
SimpleS14
SimpleS14's Avatar
How do you guys get a good wack at it? There really is not much space when I'm underneath that car. I don't think the starter is hooked up wrong...there is only one way to install it IMO. Damn...I'm so frustrated.
L.H.O.O.Q.
Old 06-25-2004, 08:33 AM   #26
Grant
Grant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura about
I think it's the starter.. that was the problem with mine..
Grant is offline   Reply With Quote
Old 06-25-2004, 11:15 AM   #27
GamblerZ
GamblerZ's Avatar
http://www.zilvia.net/f/showthread.p...163#post500163
Try the above link. It could be as simple as the starter relay.
Old 06-25-2004, 12:06 PM   #28
SimpleS14
SimpleS14's Avatar
Thanks for the link...you have a nice list of cars in your sig...excluding the ML (hate those things).
Starter relay? hmm..everything looked fine and hooked up..I will give it another check. I might be a complete newbie since I didn't know where exactly its located.
But unlike this guy...my car does not start with a push start..and I don't have the issue he did with the gauge cluster.
I will give this a try...and might try to replace the starter.
I need my car back
L.H.O.O.Q.
Old 06-26-2004, 07:05 PM   #29
SimpleS14
SimpleS14's Avatar
replaced the starter....same shit happens...my car will not start
I'm all kinds of confused.....I have no idea where exactly this starter relay is located...everything seems to be wired up and hooked up fine.
L.H.O.O.Q.
Old 06-26-2004, 11:53 PM   #30
240Driver39
240Driver39 is making a name for him/her self240Driver39 is making a name for him/her self
Send a message via AIM to 240Driver39
dude, are you SURE u wired up the 5 speed swap correctly. It worked before, doesnt work after, seems like a good place to look again.
1990 240sx 5spd fastback
240Driver39 is offline   Reply With Quote
