Old 06-27-2004, 08:21 PM   #1
brainfood
brainfood's Avatar
Trader Rating: (18)
brainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond repute
Feedback Score: 18 reviews
s14 driveshafts impossible to find?
I need to find an s14 abs 5sp driveshaft for my 5sp swap on my 95 and I cant find one anywhere even local junkyards and such dont have any. So I decided to look for an alum. driveshaft figured I could get a little performance out of the swap as well and I cant even find those. enjuku used to sell them now they dont anyone have any idea where I can find a stock or aftermarket driveshaft?
brainfood is offline   Reply With Quote
Old 06-27-2004, 08:36 PM   #2
SilviaDriver
SilviaDriver's Avatar
SilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enough
Send a message via AIM to SilviaDriver
oberkill has alum driveshafts i beleive
edit: http://www.project240.com/custom.html
he [oberkill] had a thread with pics that shows the alum driveshaft installed with other stuff he had
SilviaDriver is offline   Reply With Quote
Old 06-27-2004, 09:47 PM   #3
golds14
golds14 is an unknown quantity at this point
driveshaft?......you need driveshaft?
i got a used 95 driveshaft if you need it....150+ shipping from jersey....i do paypal
golds14 is offline   Reply With Quote
Old 06-27-2004, 10:53 PM   #4
S14DB
AFC #1
S14DB's Avatar
I thought you only had to swap driveshafts in the S13.
Old 06-28-2004, 05:31 PM   #5
brainfood
brainfood's Avatar
Trader Rating: (18)
"I thought you only had to swap driveshafts in the S13" you may have just made my day. I will measure a friends 5sp shaft and see if it is the same length would the splines on the front be different from the auto to the 5sp? I have a full s13 swap and as far as I know everything fits the s14 but the driveshaft so all I am looking for is the driveshaft by if I dont need it the that is even better.
golds14: is it from an abs equiped car? I have a vlsd in mine and I guess the abs and non-abs are different lengths.
Old 06-28-2004, 05:59 PM   #6
S14DB
AFC #1
S14DB's Avatar
Yeah, I just looked and you do need one. The junk yards around here have them for $75
http://www.car-part.com/
Old 06-28-2004, 10:23 PM   #7
brainfood
brainfood's Avatar
Trader Rating: (18)
lots of non-abs driveshafts not any abs driveshafts
Old 06-29-2004, 10:20 AM   #8
blitz240a
blitz240a's Avatar
blitz240a is an unknown quantity at this point
Non-abs DS will work fine, I had mine on for a year and no problems at all.
blitz240a is offline   Reply With Quote
Old 06-29-2004, 01:56 PM   #9
brainfood
brainfood's Avatar
Trader Rating: (18)
whats the difference then? anyone know sorry for all the questions but this is my daily driver so I need to do the swap in a day which shouldnt be a problem as long as there are no snags.
Old 06-29-2004, 02:47 PM   #10
S14DB
AFC #1
S14DB's Avatar
OK, found the legnth info:
The drive shaft is two sections.
1st section:
A/T:441mm
M/T:421mm
2nd Section:
With ABS:636mm
Without ABS:650mm
Old 06-29-2004, 05:13 PM   #11
brainfood
brainfood's Avatar
Trader Rating: (18)
so then I would need the abs equip'd ds or else it will be too long
Old 06-29-2004, 07:43 PM   #12
S14DB
AFC #1
S14DB's Avatar
You could take apart both at the joint and join the old rear(ABS) to the new front(MT).
Old 06-30-2004, 09:11 AM   #13
brainfood
brainfood's Avatar
Trader Rating: (18)
do you have lengths for s13 driveshafts because if I was going to do that maybe I can use my s13 front
Old 06-30-2004, 03:25 PM   #14
brainfood
brainfood's Avatar
Trader Rating: (18)
btw that site doesnt carry s14 shafts anymore either.
So if I get the non-abs shaft and swap the fronts on mine so I have a new 5sp front on my old abs rear then do I need to get the shaft balanced? or is it fine? also do I need to take it to a shop to get the u-joint pressed out or can I do it myself with a hammer and a socket? or will it bolt on I noticed the front shaft bolts to the rear on the front side of the u-joint. at least on the s13 shaft it does. Any help would be great! thanks
edit: Nevermind I checked on how the shaft comes apart now my only question is will I have balance problems putting the 2 shafts together?
Old 06-30-2004, 09:14 PM   #15
S14DB
AFC #1
S14DB's Avatar
No, they are independently balanced. The rubber in the center should Isloate them.
Old 07-01-2004, 01:00 AM   #16
brainfood
brainfood's Avatar
Trader Rating: (18)
cool I ordered a non abs shaft $60 shipped so hopefully all goes well. Thanks for everyones help. I couldnt have completed the swap without the advice! I will let you guy's know how it goes I will be doing the swap first week in aug when i dont need the car as much but hopefully I can get it done in one day. I am going to mount the clutch pedal and do all the wiring before and then all I have to do is the actual swap in one day so it shouldnt be a problem.
