95' BMW E36 Sedan, V8 Powered, slammed, stretched, m3 upgrades..and yeah a V8. $7500
***This car is NOT a daily driver, the price is not up for discussion. This is a unique car that I drive on occasion for fun, that should be your intention as well if you are buying it***
Life doesn't allow me to enjoy this car as often as I'd like anymore, so I'm looking to sell or trade for something that I can drive a bit more regularly. The price is $7500, that price is firm. Or I will trade for a well sorted five speed E36 M3 Coupe. Or, a rougher example with some cash on your end. NOTHING else interests me right now. I do not need to sell and if nothing happens before I get the itch to tear the car apart again it'll stay with me. If you don't have an e36 m3 to offer for a trade, please don't waste my time. Cash or an e36 M3 only please. Chassis: -1995 318i -207K on chassis, 4k since build Driveline: -Carbureted Small Block Chevrolet V8 (305) -t5 five speed trans from a firebird -E36 3.15 lsd with six cylinder axles -Shortened Chevrolet driveshaft -300zx Koyo radiator with Hayden fans -Hei distributor with msd wires, accel plugs -Holley 650cfm carb -Holley Intake Manifold -E36 slave/master -Custom block hugger headers -Custom mounts/trans cross member -e36 power steering pump/rack etc. Suspension/Brakes -E36 m3 Front Brake swap (hubs, rotors, calipers) -New; lower control arms, lower control arm bushings, inner/out tie rod ends, ball joints, sway bar links -Raceland coilovers (these work just fine for a car that isn't tracked) -Raceland rear springs with bilstein shocks -Original rear braking -17x8.5 et 13 17x9.5 et 19 Breyton wheels with brand new 205/40/17 all around (Will sell for $6500 with ds1's on shitty tires) Exterior -Resprayed White, single stage paint. Satin black jambs. -M3 front Bumper cover, Side skirts, and rear difusser -Depo Glass Lens headlights with Hids -Depo Clear corners -Red/Clear tails -OEM M3 door moldings with OEM Motorsport badges Interior -E36 M3 Black Vader Front seats, drivers has a separated seam -Lux. Puffy Door cards with woodgrain accents -Some fancy cd player that I can't figure out how to use -Black base e36 rear seat -ALL windows work. Sunroof does not. Sunroof cover has no fabric and is covered in random stickers, headliner was rewrapped in black fleece but is sagging in the rear. -Black visors, grab handles, a,b,c pillars. -Carpet was dyed black and is fading in spots. Other -Shaved Engine bay. Filler was used so do expect it to crack out and need redone over time. I intended on re-doing it this winter with welds. -Fuse box is behind the drivers kick panel, fuses are no longer labeled. -All accessories work based off of turning the key. Distributor power, fuel pump, and fans are switched next to the dimmer. Starter is a push button. -Fuel gauge and speedo work as they originally did. Original temp gauge and tach do not function. -Oil pressure, Temperature, and voltage gauges reside where the OBC once did. -Window switches were cleanly relocated all to the right side for shift clearance -Air cleaner is exposed. I run a mesh cover, but no filter. This has not posed a problem in the 4k miles I've driven the car. ***I've driven this car several hundred miles on multiple occasions without a hiccup, but it is a custom built car and anything can happen at any time*** ***The 305 was not the best engine choice, but I had it, it runs well and was recently overhauled so that's what's there. This car is set up for ANY classic small block chevy engine now. Although, for a weekend cruiser the 305 does just fine. The car ran 14.7 at the drag strip with this engine/trans/rear. Notable Items: -Driveshaft should be replaced with a custom built and balanced shaft.The current shaft is a shortened and welded original Gm unit that is not balanced. This causes a noticeable vibration above 50 mph. -The car runs hot in traffic. I have no issues when I use the car on my daily routine, but when idling for long periods of time in stand still traffic the temperature will rise to a point where I will shut the car off. A better fan setup should help this a ton. -The transmission shows its age, it is from an 80's era car and while it shifts 1st-5th just fine the downshift to second is hard, and reverse syncros grind a bit everytime. This has not worsened since the car was assembled but it is notable. -I've noticed a drip from the timing cover and Oil pan gaskets. -Power steering has a drip as well. -Exhaust needs redone. As you can see in the photos it's pretty ugly, a rush job last minute that I haven't fixed up yet. I keep telling myself I'm going to drop it off and get it done but I have a hard time letting someone else work on the car so it hasn't happened yet... -Paint looks decent but was done by myself in my garage, it's not a $5k paint job. Fenders are flaking and a bit rough from being low and the wheel fitment. Front bumper paint is flaking in various areas. This car is inspected in PA until June 2013. It is emissions exempt in PA as I don't drive is 5K miles in a year. PLEASE check your local laws before purchasing. There is nothing emissions related on this car, so without a lenient state or a "friend" most of you will have trouble with inspection/registration. This is an OBD1 car so it is much easier to push through but please do your research. An in depth build thread can be seen here: 1995 318i, boring to roaring in six weeks (v8 inside) CHANGES UNDERWAY SEE POST 61!! - Bimmerfest - BMW Forums please see the later pages for the most recent info. I will take detailed photos of any area for seriously interested buyers. This is a custom car, built on a budget. It will be sold AS IS and a buyer will sign a notarized waiver stating that they are aware of the custom work done to the car and will not hold me responsible for anything after the title is transferred. For now I'll leave you with these: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I am located in Denver, PA 17517 Questions? Pm me, or text 717-271-8781 Serious offers only please. I am very busy and do not have time for games. I feel that I described the car in as much detail as possible, if I left anything out please let me know. I see that I don't have any interior pictures, I'll get on that tomorrow. I don't get onto Zilvia often just thought one of you guys might want to make a drift whore out of this thing, text me for fastest reply! Thanks for your time! -Jason
2002 M3, 1995 V8 e36, TT z32 |
The vert is for sale too. $3K: (PA) 94' E36 Vert. BBS style 5, low, roll bar, fun, fun, $3K - StanceWorks
92 Lexus SC400 5spd Roll Cage!!
Trade man? Priced low because I have a little one on the way text me if you have some questions or pm me! |
