Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver. |
#1471 | |
![]() Join Date: Jul 2004
![]() ![]() ![]() ![]() Feedback Score: 8 reviews
although downshifting to first may work. I vote against that for the sake of the first gear Synchro. Our trans don't take first gear downshifts very well. At least for what I've exp. and seen.
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got ![]() |
#1472 | |
![]() Join Date: Mar 2008
![]() Feedback Score: 21 reviews
I know. Friends camera sucks something terrible when I look at the footage. Didn't realize it was this bad. Probably going to pick up something else soon during the Christmas season. Should've gotten one on Black Friday but meh. |
#1473 |
downshifting into 1st ? not unless you have a limitless supply of transmission
drifting in 3rd gear in a ka is definitly possible , downshift in second then clutch kick till your leg cant do it anymore.
#1475 | |
What size in the Rear?
#1478 | |
You should have no problem with a few clutch kicks if your running 215's @ 70psi.
I did fine on 225's @ 50psi. Granted not on that track but tight radius turns in 2nd were no problem.
#1479 |
If you watch videos or read of drifters with all skill levels, it's all preference about set up. Youtube the drift king. He will have a Toyota 86 and will walk you through techniques. A huge advantage will be the VLSD. A few if you can spare the money, so one can always be getting rebuilt and one on standby and the other getting the life sucked from it. If drifting on the weekends your rear diff will last about 6 months give or take. Everyday about a month. Buy good tires for the front and get some used tires for the rear and go practice. Then when your skills start improving then worry about sway bars, coilovers, strut bars, camber, toe, and so on. Till then just get the basics down.
#1480 |
Why do people still mess with VLSD? If you can't afford an actual diff why not just weld yours for close to nothing and then know its locked when you need it, since it's locked all the time.
#1483 |
Mine is welded... The Drift Bible is incredibly retarded in teaching someone the basics of drifting. He's using footwork and steering that is beyond comprehension to the average driver.
VLSD isn't great for drifting. Doesn't lock hard enough for stock KA. |
#1484 |
Yeah the drift bible was pretty lame but did have a few good pointers. I dont think the vsld is to bad. just need a few upgrades for the motor and you should be able to break traction.
#1485 | |
![]() Join Date: Jun 2011
Love this thread btw Sent from my HTC_Amaze_4G using Tapatalk 2
zenki time! "Cant buy weed and pussy with disney dollars" |
#1486 |
![]() Join Date: Aug 2007
For those with VLSD , run a heavy weight gear oil such as 85-140 most VLSD lock up better with them.
i ran Irwindale course(big bank) with a Vlsd and did just fine. |
#1487 | |
![]() Join Date: Jun 2010
Camera look is interesting. I would keep it. The drift bible does do the basics but it also shows a car with 200+ power. They have SR's in their S series cars so they have more power than our 120ish (if lucky) whp KA cars.
S14 KA NA two cylinders, 75whp limper |
#1488 | |
![]() Join Date: May 2008
Riley i dont think the weight of the oil has anything to do with the VLSD locking up. the VSLD locks up by a viscous silicone oil which is sealed inside the diff itself. that silicone fluid is completely seperate from the 75w 90 or whatever is inside the diff housing. Once the silicone fluid is shot the whole diff is shot. i havent found anyone that replaces the silicone fluid as i believe its an unservicable part. Hey are you still over a adams? almost finished working out all the issues in the Z and should be out there soon. see you there. -Nick |
#1489 | |
#1492 | |
This diff will not last forever though, it is not designed to be this tight, but neither will any VLSD...
* S14SR22 * 9.0 c/r * GT3071R * |
#1494 |
Hey iamtheyi I met you at the 711 in brea lol. Pretty cool you drift. As for that vid you just have to clutch kick a bit more after transition. Try to keep the revs and wheel speed up and possibly a bit shallower angle. Hmu next time u slide, ill be good once I get my s13.
#1496 | |
SR86 is mad fun. Stock SR with a GTS 4.3 Clutch Rear End is ridiculous.
#1497 |
FOR THOSE WITH A VERTICAL (Hydro) EBRAKE:
Do any of you guys have issues like me getting used to the setup? I have a vertical installed and I'm so used to pulling my stock ebrake and it's horizontal position, my first instinct is to pull down there. We had a few sessions a while ago and whenever I had to pull the ebrake mid-drift, I automatically reached down there opposed to reaching for my hydro. I understand it may just take some getting used to and whatnot, but it just feels so different compared to the stock one. Pulling back instead of pulling up is just odd and has such a different feel. I know I can just buy a horizontal one, etc. But, I already have this one welded in. I'm doing my best to get used to it, although I just wanted other's opinions. So for those with a vertical, what did you do to get used to the setup? Was it weird for you at first too? Any input is appreciated. |
#1498 |
![]() Join Date: Nov 2010
Hows this alignment look? this is for my s14 drift car ka-t 300hp with 18x10 225 40 all around
All I read was "I'm a little bitch and don't belong in this thread". |
