Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Motorsports and Skilled Driving
Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver.
Old 11-28-2012, 02:47 AM   #1471
KA240SX808
KA240SX808's Avatar
KA240SX808 will become famous soon enoughKA240SX808 will become famous soon enoughKA240SX808 will become famous soon enoughKA240SX808 will become famous soon enough
Send a message via AIM to KA240SX808 Send a message via MSN to KA240SX808
although downshifting to first may work. I vote against that for the sake of the first gear Synchro. Our trans don't take first gear downshifts very well. At least for what I've exp. and seen.
Oh, It's just that Hawaiian Kid......
- Looking for some parts:
* PigNose SMIC Grille/Vent P# 62697-44F00 *
LMK What you guys got
KA240SX808 is offline   Reply With Quote
Old 11-28-2012, 03:09 AM   #1472
iamtheyi
iamtheyi's Avatar
iamtheyi is an unknown quantity at this point
Originally Posted by tauntdevil View Post
What gear would you be in once you transitioned for the shack? Sounds like you needed to downshift or setup the turn before hand to let you leave it in higher rpms so you have enough power to get somewhat through the turn.
Also, your friends camera makes the video look like an old 2005 ish video or like the old Drift101 videos. haha
I'm in second gear. I enter third, downshift to second on the first transition. No downshift again. I really don't want to downshift to first. That sounds retarded lol.
I know. Friends camera sucks something terrible when I look at the footage. Didn't realize it was this bad. Probably going to pick up something else soon during the Christmas season. Should've gotten one on Black Friday but meh.
iamtheyi is offline   Reply With Quote
Old 11-28-2012, 11:19 AM   #1473
vibe240
vibe240's Avatar
vibe240 is an unknown quantity at this point
downshifting into 1st ? not unless you have a limitless supply of transmission
drifting in 3rd gear in a ka is definitly possible , downshift in second then clutch kick till your leg cant do it anymore.
vibe240 is offline   Reply With Quote
Old 11-28-2012, 03:31 PM   #1474
iamtheyi
iamtheyi's Avatar
I was also running 70psi in the rear
Old 11-28-2012, 03:50 PM   #1475
KA240SX808
KA240SX808's Avatar
What size in the Rear?
Old 11-28-2012, 03:55 PM   #1476
iamtheyi
iamtheyi's Avatar
Running 215/45/17 all around
Old 11-28-2012, 04:37 PM   #1477
vibe240
vibe240's Avatar
with my ka I was running about 45-60 psi depending on the tire size and course. With my sr , 32-45psi with 205-245 r17
Old 11-29-2012, 05:11 AM   #1478
KA240SX808
KA240SX808's Avatar
You should have no problem with a few clutch kicks if your running 215's @ 70psi.
I did fine on 225's @ 50psi.
Granted not on that track but tight radius turns in 2nd were no problem.
Old 11-29-2012, 11:50 AM   #1479
jtaylor
jtaylor is an unknown quantity at this point
If you watch videos or read of drifters with all skill levels, it's all preference about set up. Youtube the drift king. He will have a Toyota 86 and will walk you through techniques. A huge advantage will be the VLSD. A few if you can spare the money, so one can always be getting rebuilt and one on standby and the other getting the life sucked from it. If drifting on the weekends your rear diff will last about 6 months give or take. Everyday about a month. Buy good tires for the front and get some used tires for the rear and go practice. Then when your skills start improving then worry about sway bars, coilovers, strut bars, camber, toe, and so on. Till then just get the basics down.
jtaylor is offline   Reply With Quote
Old 11-29-2012, 11:53 AM   #1480
whyteboi
whyteboi's Avatar
whyteboi is an unknown quantity at this point
Why do people still mess with VLSD? If you can't afford an actual diff why not just weld yours for close to nothing and then know its locked when you need it, since it's locked all the time.
whyteboi is offline   Reply With Quote
Old 11-29-2012, 12:01 PM   #1481
h2v7
h2v7 is an unknown quantity at this point
^ yea i know at midvale you need like a nice 2way nismo or welded only
h2v7 is offline   Reply With Quote
Old 11-29-2012, 12:37 PM   #1482
jtaylor
Using the VLSD is good to try on since they are abundant and pretty good when rebuilt. The Nismo ones are becoming more rare, just the name alone is why the get bought.
Old 11-29-2012, 12:43 PM   #1483
iamtheyi
iamtheyi's Avatar
Mine is welded... The Drift Bible is incredibly retarded in teaching someone the basics of drifting. He's using footwork and steering that is beyond comprehension to the average driver.
VLSD isn't great for drifting. Doesn't lock hard enough for stock KA.
Old 11-29-2012, 12:55 PM   #1484
jtaylor
Yeah the drift bible was pretty lame but did have a few good pointers. I dont think the vsld is to bad. just need a few upgrades for the motor and you should be able to break traction.
Old 11-29-2012, 01:34 PM   #1485
zenki 95
zenki 95's Avatar
zenki 95 is an unknown quantity at this point
Give or take the videos in general, they are informational and you have to see what they are doing. What happens if you continue drifting.... In time you will buy better parts to fit comfort and goals you will require to advance in skill. On the welded diff, I know they are fairly easy to find open for welding. I have one in my s14 and another going into my vert soon. If done right, (I'm a certified welder) they are awesome 100% Lock. I don't worry about the "bomb in my axle" because mine is solid. If all fails I will throw everything away since I can't disassemble it and i completely fused everything for reassurance in reference to just welding the corners. I will post pics if needed.
Love this thread btw
Sent from my HTC_Amaze_4G using Tapatalk 2
zenki time! "Cant buy weed and pussy with disney dollars"
zenki 95 is offline   Reply With Quote
Old 11-29-2012, 02:12 PM   #1486
Grenade180sx
Grenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfection
Send a message via AIM to Grenade180sx
For those with VLSD , run a heavy weight gear oil such as 85-140 most VLSD lock up better with them.
i ran Irwindale course(big bank) with a Vlsd and did just fine.
Grenade180sx is offline   Reply With Quote
Old 12-02-2012, 12:59 PM   #1487
tauntdevil
tauntdevil's Avatar
tauntdevil is a well-known jackass
I wouldnt recommend downshifting into first. Second is normally where I stay. I normally run 40-50psi in my tires but I also use 205-245 wide tires depending on the track. When you transition for the shed, try clutch kicking it through the transition. That should be able to bring your RPMs up and keep the wheels spinning through that corner. Try it next time you are out. The weight shift should make the wheels spin a little easier and with teh clutch kick, will allow them to slide out more through the drift.
Camera look is interesting. I would keep it.
The drift bible does do the basics but it also shows a car with 200+ power. They have SR's in their S series cars so they have more power than our 120ish (if lucky) whp KA cars.
S14 KA NA two cylinders, 75whp limper
tauntdevil is offline   Reply With Quote
Old 12-05-2012, 01:58 PM   #1488
TTnickdizzle
TTnickdizzle's Avatar
TTnickdizzle is an unknown quantity at this point
Riley i dont think the weight of the oil has anything to do with the VLSD locking up. the VSLD locks up by a viscous silicone oil which is sealed inside the diff itself. that silicone fluid is completely seperate from the 75w 90 or whatever is inside the diff housing. Once the silicone fluid is shot the whole diff is shot. i havent found anyone that replaces the silicone fluid as i believe its an unservicable part.
Hey are you still over a adams? almost finished working out all the issues in the Z and should be out there soon. see you there.
-Nick
TTnickdizzle is offline   Reply With Quote
Old 12-05-2012, 05:06 PM   #1489
Grenade180sx
-Nick
good to know nick, i still go over there occasionally, i now work over at Falken tire, just let me know when your going again dude and ill swing by!
Old 12-14-2012, 10:09 PM   #1490
Chase_Lovett
Chase_Lovett is an unknown quantity at this point
pull the e brake and powover!
Chase_Lovett is offline   Reply With Quote
Old 12-15-2012, 02:21 AM   #1491
iamtheyi
iamtheyi's Avatar
you are so fucking original.
Old 12-15-2012, 03:18 PM   #1492
bc.
bc.'s Avatar
bc. is an unknown quantity at this point
If you really want to refresh a worn VLSD, shim it. I shimmed mine with some factory shims almost as tight as it could go and still being able to assemble it, I locks almost like a 2-way but it is much more drivable than a welded on the street.
This diff will not last forever though, it is not designed to be this tight, but neither will any VLSD...
* S14SR22 * 9.0 c/r * GT3071R *
bc. is offline   Reply With Quote
Old 12-15-2012, 11:02 PM   #1493
Chase_Lovett
Wink
haha someone had to say it.
Old 12-26-2012, 11:55 PM   #1494
eDmSiL80
eDmSiL80 is an unknown quantity at this point
Hey iamtheyi I met you at the 711 in brea lol. Pretty cool you drift. As for that vid you just have to clutch kick a bit more after transition. Try to keep the revs and wheel speed up and possibly a bit shallower angle. Hmu next time u slide, ill be good once I get my s13.
eDmSiL80 is offline   Reply With Quote
Old 12-29-2012, 11:36 PM   #1495
vibe240
vibe240's Avatar
So I sold my s14 for a jdm ae86 ... cant wait to see the differance between the 2 cars on the track . I'm putting my sr in the AE .
Old 12-30-2012, 12:15 AM   #1496
KA240SX808
KA240SX808's Avatar
SR86 is mad fun. Stock SR with a GTS 4.3 Clutch Rear End is ridiculous.
Old 01-15-2013, 12:52 AM   #1497
jasoncanseeoh
jasoncanseeoh is an unknown quantity at this point
FOR THOSE WITH A VERTICAL (Hydro) EBRAKE:
Do any of you guys have issues like me getting used to the setup?
I have a vertical installed and I'm so used to pulling my stock ebrake and it's horizontal position, my first instinct is to pull down there. We had a few sessions a while ago and whenever I had to pull the ebrake mid-drift, I automatically reached down there opposed to reaching for my hydro.
I understand it may just take some getting used to and whatnot, but it just feels so different compared to the stock one. Pulling back instead of pulling up is just odd and has such a different feel. I know I can just buy a horizontal one, etc. But, I already have this one welded in. I'm doing my best to get used to it, although I just wanted other's opinions.
So for those with a vertical, what did you do to get used to the setup? Was it weird for you at first too?
Any input is appreciated.
jasoncanseeoh is offline   Reply With Quote
Old 02-01-2013, 06:52 PM   #1498
240dream
240dream's Avatar
240dream is an unknown quantity at this point
Hows this alignment look? this is for my s14 drift car ka-t 300hp with 18x10 225 40 all around
All I read was "I'm a little bitch and don't belong in this thread".
240dream is offline   Reply With Quote
Old 02-01-2013, 08:27 PM   #1499
iamtheyi
iamtheyi's Avatar
besides the camber up front almost being a full degree off it's alright.
Old 02-01-2013, 09:44 PM   #1500
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
^Yea, go back and tell them to fix it, and that would be toe out in the rear as well?
di-devol is offline   Reply With Quote
