Old 12-23-2012, 10:04 AM   #1
Styrykermcgee
Styrykermcgee is an unknown quantity at this point
K24de no Start after swap
Old Motor ran dry on oil in my S13 so I put a new one in.
Before putting in the new motor we replaced: front main seal; Rear main seal; intake gasket. Also used the fuel rail, alternator, and PS pump from my original motor.
Removed charcoal canister, egr, coolant lines running through intake, and emissions lines running around the intake.
Turning the key will spin the motor but engine will never fire. pulled the car around in first gear and nothing happens except a popping when i step on the gas.
So Id say I've got fuel, I've got spark, and I am rather positive its got compression.
What do y'all think?
Styrykermcgee is offline   Reply With Quote
Old 12-23-2012, 11:42 AM   #2
mx250z
mx250z is an unknown quantity at this point
Make sure your fuel lines arent backwards. Check your timing, it could be off.
mx250z is offline   Reply With Quote
Old 12-23-2012, 11:57 AM   #3
mantas
mantas's Avatar
mantas is an unknown quantity at this point
+1 on fuel lines backwards lol
mantas is offline   Reply With Quote
Old 12-23-2012, 12:11 PM   #4
ghoti
ghoti's Avatar
ghoti is an unknown quantity at this point
This also check for grounds and pull spark plugs to make sure you did not flood it
Originally Posted by SaNTi View Post
^ That shit always scares me... and I clinch my asshole a little bit.
ghoti is offline   Reply With Quote
s13 not starting
