Old 07-13-2004, 02:42 PM   #1
s14turbosilvia
s14turbosilvia has a little shameless behavior in the past
Send a message via AIM to s14turbosilvia
LSD differences?
I recently purchased an LSD off of ebay that was locally owned. He claims that it is JDM and from an S13 chassis. Here are a few differences I noticed though:
1) it has 5-star output shafts, 300ZX?
2) when laid next to my stock open diff, the nose on the new LSD is roughly a half inch longer, requiring driveshaft shortening, but all subframe mounts seem to be in the correct places.
3) many different casting numbers on the new LSD, here are a few for somebody to crossreference with their pumpkins:
STOCK
Casting(top) "38311" "40F00"
Casting(bottom) "012" "018"
LSD
Casting(top) "38311" "40F10"
Casting(bottom) "013" "03"
I tried as hard as I could to make out the casting numbers on my open diff, used a wire brush and all, so I posted what I could. What I'm more concerned about is what car is my new LSD from? The first thing that pops into my head is either 300ZX or maybe an S14?
One more thing, on S13's, a VLSD was used, correct? And if it is VLSD, then it uses fluid friction to function, correct? So if the fluid is drained, then the two opposing output shafts should spin freely, right? I may be totally wrong here, i'm just taking an educated guess with this question. The reason I ask is because the output shafts of my new LSD are locked solid, you cannot spin them opposite of eachother at all. They will spin in the same direction, but not in opposite directions. Is this normal or has this unit been modified or locked up?
I know thats a lot of questions, but if somebody has any knowledge about this stuff or could point me in the right direction, I would really appreciate it.
Thanks, BEN
92 coupe, teh sex.
s14turbosilvia is offline   Reply With Quote
Old 07-13-2004, 04:12 PM   #2
Var
Var's Avatar
Send a message via AIM to Var
long and short i dunno? maybe it was from a z32 TT.??? anyways. the fluid for the vlsd is sealed and doesnt use fluid from the rest of the diff.
Hi
Old 07-13-2004, 04:18 PM   #3
kazuo
kazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enough
JDM S13 VLSDs have a 5 bolt pattern.
When you turn one shaft the other is supposed to spin the same way.
JDM driveshafts are an inch shorter than USDM driveshafts. I use a JDM S13 diff w/ USDM driveshaft without any issues.
kazuo is offline   Reply With Quote
Old 07-14-2004, 03:25 PM   #4
s14turbosilvia
Okay, thanks guys a lot.
So am I looking for pre-95 J30 drive axles to mate with the diff and my stock hub splines?
92 coupe, teh sex.
Old 07-14-2004, 08:38 PM   #5
AKADriver
AKADriver's Avatar
not all JDM VLSDs are 5-star, and not all of them have 1" longer noses.
the longer nose is because of the ABS sensor. just like US-spec diffs. only some years/models used the 5-star output shafts.
Old 07-15-2004, 03:26 PM   #6
s14turbosilvia
so do I have to source a driveshaft from a US-spec ABS 240?
92 coupe, teh sex.
Old 07-15-2004, 03:27 PM   #7
Ghettokracker71
Ghettokracker71's Avatar
Ghettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enough
Send a message via AIM to Ghettokracker71 Send a message via Yahoo to Ghettokracker71
some LSD makes you go start sounding like Bubb Rubb,you know all "whoo whoo" and shit,while others..
Ghettokracker71 is offline   Reply With Quote
Old 07-15-2004, 05:03 PM   #8
s14turbosilvia
huh? ******
92 coupe, teh sex.
Old 07-15-2004, 05:47 PM   #9
Andrew Bohan
i think 180s had 6 bolts and s13 silvias had 5 bolts...can anyone verify this?
Old 07-15-2004, 06:57 PM   #10
s14turbosilvia
okay, I think I found my answer...
I have a 91-95 JDM S13 VLSD, 89-90 JDM (R)PS13's had the triangle output shafts. and the reason for the extra half inch in the nose of the pumpkin is the ABS sensor! Now I just need to know if my driveshaft requires shortening?
92 coupe, teh sex.
Old 07-15-2004, 07:10 PM   #11
rps13 SR
rps13 SR is not welcome here anymorerps13 SR is not welcome here anymorerps13 SR is not welcome here anymorerps13 SR is not welcome here anymorerps13 SR is not welcome here anymorerps13 SR is not welcome here anymorerps13 SR is not welcome here anymorerps13 SR is not welcome here anymore
if u look like 2 post after ur first u will find ur answer
rps13 SR is offline   Reply With Quote
Old 07-15-2004, 07:19 PM   #12
s14turbosilvia
Yes, but is your JDM VLSD ABS equipped or not? If so, then great, but if not, then I will keep asking questions.
92 coupe, teh sex.
Old 07-18-2004, 02:11 AM   #13
kazuo
The VLSD did not come from a ABS car.
Old 07-19-2004, 03:59 PM   #14
s14turbosilvia
Then I need to know if my driveshaft will require shortening, or will the bushings in there be enough to make room for an extra half inch?
-ben
92 coupe, teh sex.
Old 07-19-2004, 05:09 PM   #15
adey
adey's Avatar
adey is an unknown quantity at this point
Driveshaft SHOULD be able to take up the slack, or so I'm led to believe. re: 5-bolt "star" axles- these aren't easy to source... unless you're getting a GREAT deal on the LSD, (read ~$100 or 150 range) I wouldn't bother. It'll likely cost you more time and almost as much money to source these axles.
Search the FAQ forum, this LSD stuff's been discussed inside out. No need to beat a dead horse.
Instagram: @SX180HKG
adey is offline   Reply With Quote
Old 02-14-2010, 02:54 PM   #16
LadyS13
LadyS13 is an unknown quantity at this point
Exclamation
Originally Posted by s14turbosilvia View Post
STOCK
I was curious what you ment by stock?? s13 stock or 300z. I am curious because I was given a LSD with those exact casting numbers however they didn't know where it came from or if it was a j30 or r200v/r200.. so if you knew which it was that would be a world of help, i'd love ya forever.
Thanks!
LadyS13 is offline   Reply With Quote
Old 02-14-2010, 03:29 PM   #17
omgRWDgoodness!
omgRWDgoodness!'s Avatar
Trader Rating: (48)
omgRWDgoodness! is an unknown quantity at this point
Feedback Score: 48 reviews
If you're looking for some 5-bolt "star" output shafts, I have a pair from a 300ZX VLSD I could sell you...
omgRWDgoodness! is offline   Reply With Quote
