Old 02-14-2013, 05:41 PM   #1
jfalvarado
jfalvarado is an unknown quantity at this point
Sr20det 240sx parts **for sale**
All of this stuff is for sale still and is either for an Sr or s13 chassis, I no longer own my nissan therefore this stuff needs to go. All of my items are not junk and mostly brand name i.e. don't give stupid low offers however everything is best offer, I would rather have my parts collect dust then lose a tard load of money. Before I list parts the best way to contact me is through my phone - 760-401-2757. Also I live in 29 palms ca and not really interested in shipping, if you live in socal do not tell me I should lower my price to compensate for your gas, its not my problem you live far away from me. Here we go....
REDTOP SR20DET FRESH REBUILD, just motor, trans and ecu, appx 300 miles on it, have reciepts, ARP headstuds, EXEDY clutch and flywheel, JGY motor and tranny mounts, all parts from thenismoshop.com, new front cover, front and rear main seals, bearings, thrust washer, flywheel bolts, head gasket, valve cover gasket, spark plug rings, piston rings, valve guides, retainers, starter, alternator, belt and JGY CUSTOMS crank pulley. If I'm missing anything ill let you know --- $1500
KOYO RADIATOR with dual electric fan and hoses one of them SAMCO --- $350
GREDDY INTAKE MANIFOLD (light polish) with tb, s14 throttle pulley, and fuel system --- $550
SKYLINE R32 TAILLIGHTS, corner cracked off on one --- $150
SKYLINE R32 GTST SEATS with RCI 4 point harnesses, condition is 9/10 on both --- $300
SR20DET BLOCK, complete in parts but not put together completely, will need new bearings and what not but has pistons, rods, crank, upper and lower oil pans and I'm throwing in some top end parts. --- $250
GREDDY TURBO TIMER and PROFEC B SPEC II in a custom double din --- $350
PRECISION GT2871R TURBO and tubular bent manifold, under 3000 miles on the turbo, no shaft play --- $900
EGAY T3T4 TURBO with cast iron top mount turbo manifold, I never used the turbo --- $300
FMIC, piping and bov, large intercooler, Jgy hot and cold pipes meant to match up to Greddy intake manifold, one pipe on passenger side is dented in. --- $250
REAR CAMBER KIT, new still in paxkaging, red --- $60
REDTOP BATTERY, tray, and box, needs charge --- $125
zilvia
jfalvarado is offline   Reply With Quote
