Old 02-19-2013, 02:38 PM   #1
mhubeny180sx
mhubeny180sx is an unknown quantity at this point
Time for a new clutch + flywheel suggestions?
Hey guys, my car is in the shop as we speak, its a 1991 180sx from Japan, and the clutch went out. They called me back today letting me know i needed a new clutch and flywheel. Ive had my eyes set on an exedy stage 1 kit EXEDY Stage 1 Clutch Kit S13/S14 SR20DET 06803B as my car probably makes no more than 250-300 ft lbs torque, but i have no idea what flywheel I should get. Any input would be greatly appreciated on what kind of set up I should go with, and maybe even some deals that you guys know of?? Thanks alot!
mhubeny180sx is offline   Reply With Quote
Old 02-19-2013, 02:47 PM   #2
oni jake
oni jake is an unknown quantity at this point
Cheapest answer, stay with the stock flywheel. Just get it resurfaced.
oni jake is offline   Reply With Quote
Old 02-19-2013, 03:00 PM   #3
greenwood
greenwood's Avatar
greenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymore
if you are close toe 300ft/lbs... why would you only go stage 1?
greenwood is offline   Reply With Quote
Old 02-19-2013, 03:10 PM   #4
mhubeny180sx
i dont think im close to 300. At most 250
Old 02-19-2013, 03:11 PM   #5
mhubeny180sx
I don't believe this is an option, aftermarket clutch and flywheel were already in it.
Old 02-19-2013, 03:25 PM   #6
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
Stage two is good for 295ft lbs.
di-devol is offline   Reply With Quote
Old 02-19-2013, 03:29 PM   #7
mhubeny180sx
is there anything like a combo clutch kit + flywheel together?? I dont really want to spend more than $1000 on these parts
something like this:??
http://www.240sxmotoring.com/exhysiclkits.html
Last edited by mhubeny180sx; 02-19-2013 at 03:33 PM.. Reason: link clutch kit/flywheel
Old 02-19-2013, 03:37 PM   #8
di-devol
A hyper single would be good, but at that point throw another $500 for a twin disk of some kind.
Old 02-19-2013, 03:53 PM   #9
mhubeny180sx
Can you explain why?? Sorry I can barely fix a bike, nevermind talk about types of clutches
Old 02-19-2013, 08:16 PM   #10
Jez
Jez's Avatar
Jez is an unknown quantity at this point
It does not matter if you have an aftermarket flywheel or OEM, it will need re-surfacing (meaning made flat on the friction side)
Have a look on frsport or enjuku racing, both places have decent clutch kits suitable for your needs for under $500, should not cost more than $75 to have your flywheel re-surfaced, cheaper than a new one.
Jez is offline   Reply With Quote
Old 02-19-2013, 08:29 PM   #11
di-devol
I meant, if you're gonna spend that much on a clutch, go all out.
Old 02-19-2013, 09:32 PM   #12
!Zar!
!Zar!'s Avatar
You should only buy as much clutch as you need.
A crazy aggressive clutch will increase the wear on your transmission and axles.
Old 02-19-2013, 09:37 PM   #13
SuperBlackS14
SuperBlackS14's Avatar
SuperBlackS14 is an unknown quantity at this point
Well, You could always talk to Bardabe, they did good work with RPS and though I didn't get the one I wanted, they worked something out and now I have an Aluminum JWT Flywheel and 300ZX Clutch and Flywheel from them too. My setup feels super stock with a Nismo Slave but I know I've got crazy headway.
"Power Is Nothing Without Control"
SuperBlackS14 is offline   Reply With Quote
Old 02-19-2013, 09:54 PM   #14
mhubeny180sx
Alright, Ill ask the shop tomorrow if they can re-surface the flywheel. I mean my car does have a few modifications like fmic, pretty sure the turbo is the same (dont know really as the car was already modified in japan before i bought it) stock size, and standard bolt-ons like the filter, exhaust, and lots of suspension parts which probably don't matter in the case of clutch selection, so i doubt its more than 250ft/lbs tq.
Old 03-01-2013, 12:25 AM   #15
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
I can hook you up with an RPS Sport 6 puck which is good for about 340ft/lbs of torque (around 400hp). I hold the best prices on these clutches period. We have plenty in stock let me know if it's something you'd be interested in.
Review Thread
bardabe is offline   Reply With Quote
