Old 02-15-2013, 12:50 PM   #1
CorvettKilla
Trader Rating: (-1)
CorvettKilla is an unknown quantity at this point
Feedback Score: -1 reviews
300zx Calipers&Rotors&Master/IS300 W55/Aftermarket&Stock S13/S14/SR20Parts/SerialNine
Here is all my parts I have for sale !**LOCATED IN CANADA**!, please make me and offer, buyer pays shipping!
300ZX:
For sale is my complete front and rear set of 300zx non turbo brake calipers that come with pads with descent life, rotors and brake master cylinder. These are great as an upgrade from smaller stock calipers for a 240sx toyota cressida ect. Price is $500. Please text or call me at 4037105579
W55:
I have a W55 transmission for sale that came out of a 2001 Lexus IS300. The transmission has slightly over 100k on it and is a great replacement or transmission for someone wanting to do a 5sp on a Toyota Cressida ect. It comes with a 7m bellhousing and shifter housing to drop into any vehicle with a 7m or can be put onto a 1jz/2jz with a JZ to W series bellhousing. Please call or text me for the quickest response
Price is $500 obo
SR20 Parts:
SR20 180sx Power Steering High Pressure Hose and Loop. Fits 240sx with SR20 or replacement for 180sx, almost brand new
SR20 Stock Shifter
SR20 Stock Turbo Hard Lines w/o Banjo Bolts
SR20 Top Half Of Intake w/ Fuel Rail
SR20 Coilpack Harness
SR20 Red Top Coil Packs 3x good
SR20 Stock Fuel Pressure Regulator
GT2871r Clocking Plates BNIB 2x
Greddy Type RS Replica BOV
Z32 MAF
S13 Parts:
S13 Flip Up Lights
S13 Hub Caps
S13 Stock Fuel Pump
S13 Stock Steering Wheel
S13 Heater Core
S13 Grey Suede Glove Box
S13 Rear 4x114.3 No-name Drilled & Slotted Rotors
S13 AC Box
S13 Hatch Brake Light
S13 Steering Colum w/ signal, wiper lever switch
S13 Stock Inner and Outter Tie Rods *good condition*
S13 Clutch Hardline to Master
S13 Red 93 Front Bumper w/ Signal lights ect
S13 Hatch Cargo Cover
S13 Non-power Doors
S13 Stoptech Drilled & Slotted Rotors (100km on them)
S13 Hawk HPS Break Pads (100km on them)
S13 2x Front and Rear Calipers (One Set Is Painted Gold)
S13 Non-ABS Front Spindles w/ 4 Lug Hubs
S13 ABS Hicus Rear Subframe
S13 ABS Hicus Rear Spindles
S13 ABS DriveShaft
S13 Climate Control
S13 Hood Support Bar
S13 Pop Up Headlight Brackets
S13 Hood Hinges
S13 Center Console
S13 Steering Colum Plastic Cover
S13 Energy Suspension Round Power Steering Rack Bushing
Z32 MAF w/ pigtail
S13 2x Ebrake Handle w/ Cables
S13 Coolant Res *uncracked with cap*
S13 2x 3 Prong KA24 Maf's
S13 LHD near mint Driver LCA
S13 LHD Driver near mint Megan Racing Tension Rod
S13 Pioneer Deck w/ usb
S13 Brake Pedal Assembly
S13 Metal Door Sills
S13 C Pillar plastic *no holes from gauges*
S13 Hatchback Tail Lights w/ Center piece
S13 Clutch Pedal
S13 Slave Cylinder
S13 Gas Pedal
S13 Ka24E & DE Throttle Cable
S13 Hatch/Gas Door Lever w/ cable
S13 180sx Power Steering loop
S13 180sx High Pressure PS Line *near new*
S13. 240sx Power Steering Res with Lines
S13 Alpine Rear Speakers for Hatch
S13 6 bolt axels
S14 Parts:
S14 MPH Guage Cluster
S14 Coolant Res
S14 Brake Booster
S14 Wiper Arms
S14 Power Steering Loop
S14 Passenger Mirror
S14 Signal Lights
S14 Gas Door
S14 Brake Master
S14 Signal levers *switches*
S14 Rocker Panels * for those rusted out rockers*
SERIALNINE COILOVERS:
For sale is my Brand New In The Box SERIALNINE X8 Stance D Full Coilover Kit for a 1989+ Toyota MX83 Cressida. Here is some info...
We have developed the First and BEST FULL coilover kit for X8 chassis.* Our kit is THE*LOWEST and*most comprehensive*setup*for Aggressive street/Drifting/Track. Comes with 15 way adjustable STANCE GR+ SS-D dampers, HD weld on strut tubes, 12/10 k springs, SERIALNINE engraved*adjustable front and rear upper plates (camber adjustable front) Front swaybar endlinks, and all hardware and bushings required. Street and track tested, engineered for MAXIMUM lowness, able to Drive and Drift Tucking 19's with full travel, yet can go up to 1" lower than stock if required. This is the SAME KIT used by Ameen Rizvi in the Formula D series.
*** This kit Requires WELDING TO YOUR EXISTING SPINDLE.******
* Requires Drilling and Welding*for installation.
$1500 FIRM!!! Paid $1800 with shipping and took me 9 months to get! Save $300 and don't wait serialnine months!
Please Call/Text for quickest response 4037105579 or e-mail me and ill get back to you.
Thanks
CorvettKilla is offline   Reply With Quote
Old 02-25-2013, 07:16 PM   #2
coupe92
coupe92 is an unknown quantity at this point
bump for this man, gave me free advice.
coupe92 is offline   Reply With Quote
Old 02-25-2013, 08:11 PM   #3
arh7cf
arh7cf is an unknown quantity at this point
Can you quote me the s13 clutch pedal, brake pedal, and clutch master cylinder to 65401?
Thanks
arh7cf is offline   Reply With Quote
