Need help won't rev past 4-4500
Ok here's my problem car runs fine when it's cold revs up all the way up, but when it reaches operating temp it wnt rev past 4-4500 and gets worse the longer it runs. After a while it doesn't even want to start what could be wrong?
![]() Join Date: Dec 2008
Trader Rating: (63)
![]() Feedback Score: 63 reviews
MAF wiring? Maybe unplug maf and see if it does the same thing. (Warms up and doesnt rev past 4500 with maf unplugged.)
Maybe a sticking injector? Do all the basics. Check plugs, injectors, make sure your getting spark, grounds, etc.
Question is it possible that my fuel pump is going out and gets weaker the longer I run? I know usually it works or it doesn't but i just want to kno if it's possible?
![]() Join Date: Jul 2006
Maybe coolant temp sensor? If its getting an inaccurate reading when hot it can possibly either lean out or richen the a/f mixture. Can also cause no start condition when engines hot.
CLUSTER BOMB EC DORIFTO |
Was exactly my problem when i did my swap. I was experiencing exactly what you are and once i swapped out my fuel pump all hell was unleashed and my baby boosted like no other.
#14 |
![]() Join Date: Sep 2008
![]() Feedback Score: 20 reviews
hey hey hey i think that one happened to me before so luck i found ground wire connect firewall between rear cylinder head was loose bolt then tight bolt also make sure check all ground harness.
