![]() Join Date: May 2004
S13 Twin Turbos Non-Sequential
Forget Sequential TT set-ups. For the drift or autox scene, you need good response time, not turbo lag. I really dislike to post this type of question, but has anyone done this? I realize it consumes much time and money (custom mani. and dp.) and space, so I'm curious if anyone has done it with 2 stock SR turbos. Thanks
![]() Join Date: Mar 2002
I think Andrave is building a twin turbo KA
![]() ==>>TGL GARAGE<<==.. RIP! S13 coupe KA-T @ 0.5 Bar = SOLD! A31 Cefiro + SR = Current |
are you talking about mounting them in a series? if you are its been done before. your alot better off with a single turbo at that point. Think of the heat a turbo generates, then think of the unneeded passing through of a second turbo would do to that. that air would be scorching hot and harder to cool down before it gets in. that means no real serious gains and the second turbo very much will probabbly act as a restrictive heater and thats about it. twin turbo is the way to go if you want but even single turbo with equal length mani and ball bearing turbo works fine too.
#5 | |
![]() Join Date: Jan 2004
-Snail |
#7 | |
#8 | |
#9 | |
![]() Join Date: Jul 2003
Drew |
Ok, well I'm glad many people are looking at this thread, and giving their opinions, but I want to know if it's been done! Tastyratz, you should read up more on non-sequential TT set-ups. But as 90RS13 said, you are right, heat will be an issue. But it won't be something that is a major concern. SPACE is the largest concern. Also, NZO, I beg to differ. Therefore, my main and original question still remains, "has anyone done this before in an S13?" I've seen a S15 with sequentials, but it's an S15 chasis... Anyhow, this would be great if anyone were to do it!
well you need to clarify what kind of turbo'in you are planning on. Cause there are quite a few ways to put two turbos on one engine. I'm running mine in parallel, which means 2 cyls to go 1 turbo and 2 to another and then after the turbos they Y back together.
#13 | |
sentinelguild.com/nzo/PFCDB/ |
#14 |
I posted on this in the forced induction thread a long time ago at nico.
but I think a large racing wastegate could easily act as the switcher. its got all the diapraghms and such. you could run the exhaust first into a Y pipe, one of the legs gets the small turbo the other gets the large wastegate. The wastegate is closed at low boost, at, say 7 psi the wastegate sense the boost, opens, but instead of venting the smaller turbo it just opens the Y, so all that pent up exhaust is still going through the small turbo, but also flying around it, slamming into the larger turbo, making like the crazy NAWS on fast and furious 2. I see no reason why it wouldn't work. Want me to make a photoshop drawing of it tomorrow? I like making photoshop drawings. |
#15 | ||
![]() Join Date: Jul 2004
![]() ![]() ![]() ![]() Feedback Score: 8 reviews
Wow that would be the frist KA-TT I know of ![]() ![]()
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got ![]() |
#16 | |||
[/QUOTE]Want me to make a photoshop drawing of it tomorrow?[/QUOTE] yes, some people might not be able to visualize it. I like how this thread is going. It's not getting covered in pointless posts, from people who post just to see their name on the thread. Last edited by 90RS13; 07-23-2004 at 02:22 AM.. |
#17 | |
#18 |
I thought of something for the wastegate problem that I mentioned earlier. Using more than one wastegate would be good. For fun let's say you use 4 wastegates. They're set for 7psi. At 7psi, they will all start to open, like normal. Then when you're flowing alot more you would have alot more flow, (becuase of all the wastegates), while still keeping the first turbo at a lower rpm. With only one wastgate when set at 7psi, when the engine's flowing alot of air the wastegate won't be able to pass all of it, so the first turbo wil take in more than you want. Am I explaining this well? See,
one wastgate 4 wastegates | | | || || || | See, more wastegates can flow more gas when needed, but can also keep the first turbo from spinning out of it's effeciency range. Does this make sense? |
#19 | |
"buddy jesus"
![]() Join Date: Oct 2002
instead of having a waste gate open, why not make a cutout (like an exhaust cutout)...just have it hooked up somehow that when it detects 7psi of boost on the smaller turbo it opens up and allows more air to go into the larget turbo...
while you are at it, why not make a proportioning valve that has the ability to limit the amount of air that goes to each turbo?
![]() Quote:
#20 |
well just keep in mind that a waste gate diaphragm could control a larger valve if you wanted it to. Or you could always use a boost activated switch to control an electric cut out. The problem with that, is that they are very slow acting. vaccuum activated are, psh boom and they are open, just like a wastegate. electric, I can't think of anything that doesn't use stepping motors, which equals... "whhhiiiiirrrrrrrrrrR" and by then your engine hit redline and the system is theoretical.
#21 |
If youre really serious about using a sequential setup just reverse engineer an FD or MKIV and see what they use.
#22 | |
![]() Join Date: Sep 2003
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
#23 |
photo shop drawings are too big to post on zilvia, oh well. But anyway I know how the setups work on supras and rx-7s...
its not the same thing we are talking about. You would want to look at one of those porsches they made a while ago (called the ultimate porsche, I can't remember the number), they actually used a smaller turbo and a larger one. the Japanese cars stuck with two of the same size turbos, and basically a wastegate like device that just opens up both turbos. |
#24 |
Twin Turbo GTO's use this setup, and still get heated up pretty bad . Managing engine temps. is critical with this setup.
Differently sized turbo's are better for overall powerband performance. Low end (Smaller) Top end (Large). The two larger turbo's can provide crazy top end horsepower (like Skylines, MK4's, etc.). It justs depends really on what the car will be used for. If a street car, 2 larger turbo's is better. The lag at low RPM's allows for better mpg.
-John 93 240SX FOR SALE!!!!! |
#27 |
haha .... big turbo and bigger turbo, t3/t4 and a T66
you would only have 1000-1500 powerband on the T66, but when it kicked in, plus you would have the t3/T4 from 2700-5500 |
#28 | ||
#29 | |
#30 |
Ive always read about people doing compound turbo setups and getting told its a bad idea and not to do it. it never seemed like a good idea to me. this thread however has sparked curiosity with me... i like the idea of the larger turbo switching. what about chopping up a throttle body and welding it in front of the smaller turbo inlet. this way you could set it up in a way that when you reach x amount of boost you rig the tb to close which in turn would divert all the gas to another pipe going to the larger turbo. this whole idea is creative but its really complicated, and will involve some serious welding and margin of error... id like to hear more though...
