Old 07-29-2004, 04:48 PM   #1
kdillard21
kdillard21 is an unknown quantity at this point
Send a message via AIM to kdillard21
IAP turbo kit, 5psi by 1800 rpm?, quick spool huh?
ok so i was talking to marc at import auto performance IAP....yea i posted this on another thread, and he says their t3/t4 hybrid no shit has 5 psi boost by 1800 rpm on their stage 1 car. he says theirs is custom made from turbo innovations and has 360 thrust bearing and super light i guess. but anybody with one of these kits attest to that? is that possible? i was thinking of going straight t3 but now i like the sound of that spool up.
kdillard21 is offline   Reply With Quote
Old 07-29-2004, 05:50 PM   #2
Var
Var's Avatar
Send a message via AIM to Var
maybe with a chevy 350 motor
Hi
Old 07-29-2004, 08:01 PM   #3
kidinthehall
kidinthehall's Avatar
kidinthehall is an unknown quantity at this point
hes full of shit. unless you missed the part of the conversation where he said ".................in 5th gear"
90 S13:............fitter, happier, more productive.
04 Yamaha R1: 210rwhp on gas/161rwhp on motor
kidinthehall is offline   Reply With Quote
Old 07-29-2004, 08:34 PM   #4
kdillard21
yea i guess its too good to be true, i told him that sounded a little fudged...but he swears up and down that is what its spooling up at. ok im just going back to piecing it together with my straight t3 60 trim, .48 a/r and conventional bearings, i think that should work for my tastes. and cheaper!
Old 07-29-2004, 08:40 PM   #5
sykikchimp
WOW addicted
sykikchimp's Avatar
.48 is really small, and will really choke things up high in the rpm's.
Old 07-29-2004, 08:44 PM   #6
kdillard21
ya think? what you recommend then, i more concerned with spool that high horsepower. im only looking for 230-250 horsepower to the wheels...
Old 07-29-2004, 09:47 PM   #7
fastpace
fastpace is an unknown quantity at this point
you should look at a T-3 super 60, with a .63 turbine and .60 compressor. This is what I am running and have actually taken it up to 1 bar and didn't witness any choking in higher rpms. I got mine from turbocalculater.com
life is what you make of it!!!!
"well, I go out, I do the practice, I think about it and I concentrate on one small thing I can change that will have an effect. I make that change then I go out and drive to my maximum." -Ayrton Senna
fastpace is offline   Reply With Quote
Old 07-30-2004, 01:17 AM   #8
1998cc
1998cc is an unknown quantity at this point
I make 6psi at 2500 with a t3 super 60 and an IAP manifold. I also make 10psi at 4800 with a 3.5psi wastegate spring.
Pop-ups Rock
1998cc is offline   Reply With Quote
Old 07-30-2004, 04:52 AM   #9
kdillard21
that IAP manifold is so expensive though...well so what everyone is saying on here is that .48 turbine a/r is too small, but the guys at turbocalculator.com and my calculations and my niftly little program say .48 is fine for what i want.
Old 07-30-2004, 08:20 AM   #10
orion::S14
orion::S14's Avatar
^^^ Hahahahaha...
I'm really beginning to wonder about these guys...
There have been SO many of their manifolds that have boost creep...and to their credit, they have been working with everyone to fix it (from what I read on this and other forums)...but the fact remains, they all creep.
But now quoting such rediculous spool...c'mon...
I've done a KA-T with a Z31 T3 and JGS manifold, and it's at 5psi by ~2500 in most gears...that's about the best you can get. Even Ace's T25 wouldn't make 5psi under 2000rpm...
About the .48...it'll do, but for a 2.4 liter motor, the .63 will spool in a very similar fashion, plus give you better top end b/c the turbine can flow a lot more...
IMO, I'd rather spool 200rpm later and have ~1500rpm more up top where I make power...rather than choking it off.
- Brian
