S13/S14 Pedal Pads
Hi, my S13's clutch, brake, and gas pedals are all missing their pads. The clutch and brake are just the metal without the rubber, and the gas is just a metal rod. I've searched and all I can find are S14 pedal pads. Are these interchangeable? If not, can someone link me to some S13 pedal pads? And same with the gas pedal.
Thank you~ |
They should all be interchangeable. You will have to mod the S14 clutch pedal to work on the S13 though. There's a spacer bracket built into the S14 pedal, the S13 has it on the chassis. Decide which one is easiest to remove.
Personally, I'd spray the metal with some rhino liner to give it grip/texture and just replace the gas pedal.
Man w/ CTSV & a Car Seat
Not really, I got them in my car. Just like having wider pedals, makes it easier to heel/toe to rev match. But I didnt use the flimsy hardwares, I actually drilled holes on the OEM pedals and bolted them straight on.
#10 | |
I would know since I sell those damned things. That's totally unsafe imo. I would have at least gotten a Sparco set and welded them straight on |
Eh, so what if they're soft metal, they're still bolted down on the damn solid metal pedals. Not like I'm gonna lose the pedals if these pieces of shit breaks apart or anything.
Got the generic Sparco knock off pedals, had the same type in Japan on my silvia, never had any issue with it. Like I said, they're just pads sitting on top of the actual pedals. Ricey, sure but it serves its purpose for me and just doesnt justify spending $100. ![]() |
