Old 08-03-2004, 12:13 AM   #1
SignalAutodrifter_D
SignalAutodrifter_D's Avatar
SignalAutodrifter_D has a spectacular aura aboutSignalAutodrifter_D has a spectacular aura aboutSignalAutodrifter_D has a spectacular aura aboutSignalAutodrifter_D has a spectacular aura aboutSignalAutodrifter_D has a spectacular aura aboutSignalAutodrifter_D has a spectacular aura about
sr20 in but cant get it turnin..help!!!
i jus swap in an s13 in mah hatch and the wiring is all in...the motor is in..i had it for about 4 days.......and i cant start da dam thing.........car turnss but jus doesnt start.......so i need help...i got spark i got fuel.....the onlly thing that mite b wrong is i think the motor mite b flooded i smell gas on the spark plugs...but i tried to deal wit it and still no start.....so please all u expert sr20det cats i need help!!!!!!!i want to drive.....and drift
SignalAutodrifter_D is offline   Reply With Quote
Old 08-03-2004, 12:57 AM   #2
mrmephistopheles
mrmephistopheles's Avatar
WHOAH!! A SINGALAUTODRIFTARR in Minnesota!!
hint: use proper english, use proper punctuation and be concise about symptoms and your actions.
PS. I'm not a cat. I'm a hoomahn.
Old 08-03-2004, 06:54 AM   #3
Bradman123
Bradman123 is an unknown quantity at this point
make sure ur fuel lines arent switched around first thing, thats what i did. feed line from filter goes to line between intake runners not regulator side. kinda suprising how easy i mixed them up cuz i remembered reading about which line goes where and i must not have been payin attention. if that doesnt work, are you positive you have spark, pull each plug and put it on the coil and ground the plug in some way, and crank the motor you should see it spark. check your fuel pump fuse too...after cranking and cranking mine kept blowing and i went through six of them before i found out that the lines were switched up. check all other fuses that could cause it not to start. so if you have spark and fuel FOR SURE. and you are positive all your wiring is right then my next guess is timing. you could sit there and move the CAS tooth by tooth until it goes but just as easily you can pop the valve cover off. line the motor up top dead center on first cylinder and line up the mating marks on the CAS and the cam gear...fsm tells pretty much what to do. lets see...you could also make sure that your ecu harness connector is connected fully, if its not, that could be a problem i spose. hope i helped.good luck.
Bradman123 is offline   Reply With Quote
Old 08-03-2004, 07:30 AM   #4
duey
duey's Avatar
duey is an unknown quantity at this point
i had the same problem and it turned out to be my timing. Check out www.phase2motortrend.com for instructions on how-to adjust timing.
http://members.cardomain.com/duey170
12.3@111mph - basic mods/STOCK t25
duey is offline   Reply With Quote
Old 08-03-2004, 09:54 AM   #5
SignalAutodrifter_D
thankss
yea i checked for spark i got that out of the way then i check for fuel.....the lines are corrected....fuse for the pump is good.it doesnt blow...i feel pressure through the lines......check wiring an harness many many times.......but timing, havent done that yet so imma do that and c wut happens......and sorry about the text i been on AIM all day so i type as quik as i can and it tends to b a lil wierd and .....but thanks guys for the help any more info and input from any one is great.... i been workin on this thing for 4 days jus watchin mah babie sit there when i can b drivin this orange thang around naw mean......and the urge to drive and drift is unbearable if u guys kno wut i mean so help a drifter out@!!!!!! but im goin to check the timing...thanks for everyones info...............=)drift safe but drift scared.......the more ur scared the siker the moves@!!!!
Old 08-03-2004, 10:13 AM   #6
Var
Var's Avatar
Send a message via AIM to Var
Hi
Old 08-03-2004, 02:16 PM   #7
the head
the head's Avatar
you are an idiot
Old 08-03-2004, 02:24 PM   #8
kickertu
kickertu is a well-known jackass
yea.. i was going to chip in on this one.. till i read he is a "drifter" and he considers his 240 to be his orange thang!!!
what a goof
kickertu is offline   Reply With Quote
Old 08-03-2004, 04:37 PM   #9
SignalAutodrifter_D
yo if u guys were fellow drifters and kno what the art is about u wouldnt talk about what i would have to say or how i talk..... u should be helping get mah car up and runnin!!!!!!! do u have better things to do then cum on forums and talk....y dont u get in ur car and drift...or go to work and make sum money to put into ur silvia!!! instead of hittin me back on what you have to say!!!!!! so to real mechanics, and tech heads that rule the forum help me out on my problem instead of hatin on the way i type!! thanksss.......and to the haters mah s13 is better then urs anyway...and mah shit aint even runnin!!!
Old 08-03-2004, 04:54 PM   #10
ISTOTOSAO
ISTOTOSAO's Avatar
ISTOTOSAO will become famous soon enoughISTOTOSAO will become famous soon enoughISTOTOSAO will become famous soon enoughISTOTOSAO will become famous soon enough
This has got to be a joke. If not, this guy makes me ashamed of the human race.
Yo MaH dAwG. I DoNe GoNe An SmOke Ya CaW En AY AiN EiN MoOoO It.
Sorry.
Steven- "You don't know me, but I am better than you."
ISTOTOSAO is offline   Reply With Quote
Old 08-03-2004, 07:12 PM   #11
Bradman123
lol check the timing...lmao.
Old 08-03-2004, 07:15 PM   #12
Ghettokracker71
Ghettokracker71's Avatar
Ghettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enough
Send a message via AIM to Ghettokracker71 Send a message via Yahoo to Ghettokracker71
Ghettokracker71 is offline   Reply With Quote
Old 08-03-2004, 07:16 PM   #13
BSeay
BSeay's Avatar
BSeay is an unknown quantity at this point
Send a message via AIM to BSeay
Man take a fuckin english class dude! jesus i feel dumber after reading your post...
1995 240SX SE - Sold
BSeay is offline   Reply With Quote
Old 08-03-2004, 08:36 PM   #14
SignalAutodrifter_D
dat issototot mutha sucka u aint shit....and mr bsayyy sum shit dat is y ur 240 is still a workin progress cause ur to busy talkin shit!!! hahaha get to workin on ur car homeboi...or may b ur mama didnt get u ur allowance yet....sorry buddi hard work pays off u kno.....but bradman thanks for the info!! and not gettin into this mess....if any body else got sumthin to say holla at me. or help me out!!
Old 08-03-2004, 08:47 PM   #15
ThatGuy
Admin Asshole
ThatGuy's Avatar
Seriously, spell out your words. No one can understand what the hell you are trying to say. I'm sure everyone would be happy to try and assist you if you didn't sound like a complete jackass, bragging about your "Drifta Skillz" and how you car is so much better then everybody elses. Maybe you just need to take a step back and try not posting again till you have a little bit of maturity.
Old 08-03-2004, 08:50 PM   #16
mrmephistopheles
HOLLA! Keep this attitude of yours up, and you'll be gone, Signalautodriftaaaaaaa.
Most people don't like reading that crap. I already suggested using proper english, spelling and punctuation. It's up to you, but if you decide to not change, be prepared to reap the whirlwind.
Old 08-03-2004, 08:52 PM   #17
SignalAutodrifter_D
ok now we have mr smart ass joinin the battle....well first of all mah car aint betta then no one else only betta then the people who talk shit,,,cause if they fail to help and want to start stuff then they aint shit...only the real characters are down to help...and i type like this because this is how i type and i can type fast like this so i do it...i aint changin mah ways jus for sumone that cant take there time to look at words differently..if u can read then u can read mah typing...stop bein lazyy....but to others that can deal wit wut i got and willing to help thanks!!! haters gonna hate...
Old 08-03-2004, 08:55 PM   #18
SignalAutodrifter_D
And Mr Memepsrotho....u Guys Started This Stuff With Me...i Did Not Bring This To You Guys I Asked A Simple Question For Some Readers To Help Me And Some Of You Guys Think Im A Joke And Mess With Me....so It Wasnt Me So Dont Report In For Starting This Stuff With Me.....what A Punk......but Yes Here You Go I Type This Out In Big Bold Font And Proper English For You That Cant Read!! Thank You Very Much Have A Nice Day.....=)
Old 08-03-2004, 09:09 PM   #19
mrmephistopheles
I guess you really do want to be banned. I'm proud you have the ability to spell words out completely and have some sort of grammar. Your punctuation is still lacking, but I can live without that.
If you'd open your eyes, you'd realize that people are mocking you because of your apparent inability to type a coherent sentence. Not all of us are 'frum da hood' (or would that be 'is frum da hood'), so we don't type like that, much less speak like that. I know Minnesota is a hardcore place to grow up. I've heard of the gang wars that put NYC and LA to shame. I know you probably had to 'bust a cap in sum foo' when they tried to steal your lunch money. Funny thing is, nobody here cares about you. You come here asking for help, and when you're told to be more clear and have what you wrote make sense, you get butthurt about it and start trying to insult people.
On that note, I'm THE ASSHOLE. Not 'mr smart ass'. Furthermore, I'm not a punk.
Your direct insult of me is a violation of the user agreement/rules & regs here, and I have every right to ban you if I see fit. However, I'm going to be patient and give you the benefit of the doubt by assuming you are NOT a troll.
You're wrong when you say you didn't 'bring this' to us. You did so by asking a poorly formed question. Not only is nobody here bound by any rules to answer your question, we are at the same time, not bound to give you quarter and show you any respect. Respect is earned, not given.
My rant is over on these final notes:
Your car is not a Signal 180sx.
Your car is not even a 180sx. (mine is though)
You are not a drifter for Signal Auto.
Old 08-03-2004, 10:04 PM   #20
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
have you checked for cut break lines. cause if I was your neighbor and happened to be reading this post, I would have cut them by now.
I was going to, but I can not think of a sig less than 75 characters.
mjjstang is offline   Reply With Quote
Old 08-04-2004, 12:29 AM   #21
kickertu
im thinkin this kid came from the honda camp.. cause he saw too many initial D movies.. and go work on your "silvia" huh
hmm no one has a silvia on this forum (well maybe one or two real ones) so learn that its a 240sx.. and no matter what you do to it, it will always be a 240sx..
and the answer to your problems is timing. reset your cas and go "DRIFT" in a curb
Old 08-04-2004, 07:29 AM   #22
Bradman123
ur welcome
Old 08-04-2004, 08:35 AM   #23
the head
the head's Avatar
Technically that is not proper english, in the written forms of communication one does not capitalize all of the words. Not to mention you are missing some words in your sentences plus the apostrophe in can't.
Old 08-04-2004, 06:35 PM   #24
CHOUKI240
CHOUKI240 is an unknown quantity at this point
did you get the sr running yet?
CHOUKI240 is offline   Reply With Quote
Old 08-04-2004, 06:48 PM   #25
nightwalker
nightwalker's Avatar
nightwalker is an unknown quantity at this point
what a turd. You must have some gall to use a screen name like "SignalAutodrifter D". I hope your SR never runs, and if it does, it runs like shit, then blows up. That, or you drift yourself into a ditch.
Let us know when you accomplish one of them.
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing.
nightwalker is offline   Reply With Quote
Old 08-05-2004, 12:35 PM   #26
90sr
90sr is an unknown quantity at this point
:hammer: Oh man they cut you up really bad, you really do have to be more specific when you try to post on here, I have learned that, proper sentencing equals proper response, and yeah it is your CAS timing and or the plug that goes into it, I just recently got my sr running and the whole fucking time the plug going into the CAS was backwards of the way I put it in so the right little solenoid on the CAS wasn't lined up to the right wire so I found in the sr manual that the plug had to be turned around 180 degrees, done good to go she started right up. Good luck with that man.
chris's sr
90sr is offline   Reply With Quote
Old 08-05-2004, 04:29 PM   #27
SignalAutodrifter_D
thanks to everyone!!!!
yo sr90 and all the other cats that left me good response on my thread thanks.....im going to mess with my cas and timing tonight so ill tell you how it goes.....to all the other with negative feedback, and just something good to say....well thanks for your effort and creativity...i like the things you have said and stated..ill be for awhile so you will hear and have to deal with me sorry...fellas but thanks for taken the time to think about the things you say and to type them in this thread!! thank u everyone!!!
o yea sorry i dont have a 180
im dont know shit about signal
and drifter x is mah idol......
Old 08-06-2004, 05:59 AM   #28
Brolewigi
Brolewigi's Avatar
Brolewigi is an unknown quantity at this point
My mind is blown.
Brolewigi is offline   Reply With Quote
Old 08-07-2004, 02:47 AM   #29
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
SignalAutodrifter_D: You appear to be one who stepped on the bandwagon...
By the way, how the f*uck do you swap an "s13 in mah hatch"???
The way you talk makes you appear like a person who read a bunch of forums and heard people talk about driting as an art and now you use that. I hope you have 300zx brakes to help harness the power of the SR as well as a silvia front end because it is much more aerodynamic than those pop up headlights when drifting...
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
