Old 05-09-2013, 02:56 AM   #1
smdodgers
smdodgers's Avatar
smdodgers is an unknown quantity at this point
Compression tester stuck!!! Help
I was compression testing my motor yesterday and the adaptor got stuck in cyl one -_-
I tried loctiting the hose part to the adaptor but the actual fitting on the hose came off and got stuck to the adaptor. I've tried needle nose pliers but they just don't grip at all.
A drift a day keeps the Hondas away.
smdodgers is offline   Reply With Quote
Old 05-09-2013, 04:14 AM   #2
91EfSi
91EfSi is an unknown quantity at this point
That happened to me on when I was doing my KaDE compression check, I used an easy out big enough to fit into the inside hole and was able to break it lose and pull out.
91EfSi is offline   Reply With Quote
Old 05-09-2013, 04:18 AM   #3
OrangeVirus1
OrangeVirus1 is an unknown quantity at this point
happens to me sometimes, just keep connecting and disconnecting the compression tester, get various angles on it and eventually it will come loose.
But if your compression tester is like any normal tester you should be able to get a XXmm socket on it..
OrangeVirus1 is offline   Reply With Quote
Old 05-09-2013, 09:09 AM   #4
smdodgers
smdodgers's Avatar
I don't really want shavings to fall In the chamber
Old 05-09-2013, 09:48 AM   #5
OnTheChip
OnTheChip's Avatar
OnTheChip is an unknown quantity at this point
If you can find a piece of hose with large enough id to slide tightly over the fitting, but small enough od to fit in the hole...
OnTheChip is offline   Reply With Quote
Old 05-09-2013, 09:58 AM   #6
S12 Drifter
S12 Drifter's Avatar
S12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymore
easy out + socket + ratchet
Originally Posted by S13slida View Post
Your wife has bigger balls then you.
S12 Drifter is offline   Reply With Quote
Old 05-09-2013, 10:16 AM   #7
Frank_Jaeger
Remove the compression tester hose from the cylinder. Take a flat head screwdriver and hammer it into the center of the fitting until it's pretty stuck. Twist it out and enjoy. This is usually a last resort, but it will work no matter what.
In the future use antiseize on the threads of the adapter and finger tighten it only. It doesn't even have to be snug.
Frank_Jaeger is offline   Reply With Quote
Old 05-09-2013, 02:52 PM   #8
91EfSi
I didnt have any shavings fall into the cylinder, the easy out just wedges into the inside hole.
Old 05-09-2013, 10:00 PM   #9
smdodgers
smdodgers's Avatar
i guess its torqued on too tight. I dont know how it got so tight
Old 05-09-2013, 10:06 PM   #10
Lancaster
Lancaster's Avatar
Lancaster is an unknown quantity at this point
Put some red loctite on the threads and screw it in. Leave it for a few hrs. and viola! Happened to me a few months ago.
Lancaster is offline   Reply With Quote
Old 05-10-2013, 04:46 PM   #11
smdodgers
smdodgers's Avatar
Thank you guys for the help, i got the sucker out with an Easy out bit
http://zilvia.net/f/attachment.php?a...1&d=1368225885
