#571 |
![]() Join Date: Aug 2011
I am posting real world data on an SR20DET equiped with a gtx2867r.
Please, remind me what you posted here, besides some nonsense about going top mount and stroking when the question was "can you get 450WHP out out an SR20DET with a gtx2867r ? Just shut up man, and crawl back in your jdm fanboi hole. Thanks. |
#573 | |
But we can talk about you if you want. Note that i dont have anything against you, so please understand this. First, not everyone runs C16 in their car. Second, people are usually also concerned about reliability. So yes, it is prettly important to say that if getting 450WHP requires 1.8bar boost, it puts the turbo nearly in overspin territory (or in it). Now i do understand someone who burns 12$/gallon fuel may not be concerned about reliability, but most people here run pump gas, meaning your answer is a bit irrelevant. I am getting some numbers, very soon i hope, and i really think the setup may nearly be one of the best sr20 + gtx2867r setup you can get running on pump fuel. I am willing to share it, because that is exactly what this thread is about. Now can you please tell me what is the problem here ? edit: i was serious about getting your car mapped. I still dont have the numbers, but i know he has got full boost (1.8bar) at 3500rpm. You seem to hit that 1000rpm later, i am just saying you could get a more responsive engine with a better tune. |
#574 | |
#575 |
trolling with a 4700 Post Count on a Forum for 240SX's without owning a 240SX makes you not a fanboy somehow?
Killer. So basically, it looks like the 2867 has done, and can do 450whp. Which isn't shocking because T3 2871s were doing that forever ago. Has anyone actually leaned on a 2867 yet and seen what it can do? 26psi puts it about right at the edge of its 45lb/min flow rate at 7000rpm. has anyone tried to choke one out at 30?, bet it'd make party torque. |
#576 |
![]() Join Date: Sep 2005
45lb/min doesn't equate to 450whp more like 410-415!!?!!
Maybe with aggressive tuning 430. Anywhoo someone does need to push that turbo, it's didn't even scare me when it hit 25psi, like my 2871r does at 23psi
#577 |
![]() Join Date: Jan 2011
Trader Rating: (26)
![]() Feedback Score: 26 reviews
You want 450whp get a GT3071 or GTX3071
Quit playing with baby turbos lol.
IG/TikTok-ThatS14_Z06guy Last edited by EsChassisLove; 05-03-2013 at 02:05 PM.. |
#578 |
ok, here is the dyno chart. Mind you, the engine was designed and mapped for maximum early torque, which seems to be the opposite of what unijabnx2000 did. Both are nice extremes i think.
![]() green line : 1.8bar boost, 438HP @ 5900rpm, 57Mkg (that is 412ft/lb)@5000. Looks weird to me, like he stopped accelerating at 6000rpm... red line :1.2bar boost, 330HP@6100rpm. And 47Mkg at 4400rpm. Edit: looks like the wastegate was leaking a bit. that could explain some things ... guess it will go back on the dyno some days with this fixed. Edit2 : changed the pic for a working one. Also note this is with a JASMA exhaust that has a 3ft long 2" wide restrictor. And now, the restrictor is gone ![]() Last edited by Croustibat; 06-28-2013 at 12:49 AM.. |
#579 | |
That's if you believe there's a difference between half a car and five!
#580 |
I dont know if it is the correct way to embed a video, but here is the dyno .
http://vimeo.com/65543081 This thing has nearly no lag. note : it cant maintain 1.8bar boost. Cant remember exactly but i think they could only get 1.4bar at 6000rpm ( wastegate leaking ), so its not going to overspin. edit: ok i give up, cant embed. click on the link ![]() Last edited by Croustibat; 05-06-2013 at 07:24 AM.. Reason: 6rth try at embedding the vid ... |
#581 | |
#582 |
It is not my car. The guy on the video is the tuner & (co engine builder ? i dont know if he worked on that one). It spools very fast because it has a twin scroll fullrace exhaust manifold mainly. And its mapped for that (maybe e85 helps too but i dont know, usually it makes turbo spool a bit later). I cant say about the cams, except they are HKS ones.
#583 |
![]() Join Date: Nov 2003
So how many of you guys are still on stock bottom end and head gasket with this turbo?
And how far can you safely and reliably push it without building bottom end or changing head gasket?
-Kyle ![]() |
#584 |
![]() Join Date: Oct 2007
![]() ![]() Here is a lotus super7 replica with a sr20det ! We just did a tuebo swap from stock s14 t28 to gtx2860r ! Ill post the dyno result soon
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
#586 | |
The decision to swap a headgasket is tricky. My head, block and gasket showed no signs of detonation. I do still have the gasket hanging in the shop and could get pictures. This is probably because of my tune. I followed the 11.5wot, and 14.7-15.2cruise rules Timing rules you can't have. So if you've been having, spark plug breaking issues, cooling issue, oiling issues you might reconsider even pushing the engine hard. So no one can actually say what is the safe limit, you will either take it there yourself or not. Someone posted a picture about the stock max power, but that was passed by me long ago. So again not true in my case. And I'm not saying 424hp 372tq and 22.5psi is the max either, but what is MAX right before it blows up? or what?
#587 |
Yes ! The owner is driving it to is time attack chalenge around here ! Must be a blast to drive
#588 |
![]() Join Date: Sep 2004
Trader Rating: (24)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 24 reviews
I am still on stock bottom end and hg -- only running 14-15 psi. Car made 342 on a mustang dyno, guessing it'll be around 360 or so on a dynojet?
#589 | |
Out of the 3 dynos I use the dynojet reads the highest, but not every dynojet will read the same. I look for consistency between the same dyno, then compare across I avg 10hp on a dynojet, 9.6on a dynopack and 8.6 on a mustang per psi of boost.
#590 | |
I'm just trying to figure out at what power level should I stop trying for more if I don't want to have to build it, or start significantly decreasing reliability.
-Kyle ![]() |
#591 | |
Trader Rating: (24)
#594 |
Anyone know if I can fit the compressor housing from my GT2871R onto a GTX286_? After 200k miles at 15+ psi the turbo is showing it's age and I'm thinking about upgrading it while I have the head off. It certainly looks like I can because they have compressor wheel upgrades for my 2871. I really like my OEM style intake and outlet housing though and would love to avoid fabricating new pipes.
Thanks in advance.
'89 hatch DD'd SR'd 2871'd - Sold 2006 Legacy GT Wagon |
#595 | |
Sr20det engine and transmission , mazda miata diff , custom drive shaft , aem ems4 ecu , 7**cc injectors It made Around 280whp at 14psi // mustang dyno
#596 |
Since this is applicable....what are the advantages of extrude/honed manifold with EWG vs. normal manifold with EWG? Both OEM obviously.
Like is it butt dyno fun? Or actual more power to the ground? Looks like I'm going to be going GTX2867 and MVS EWG with OEM manifold sometime in coming months, just trying to figure out if it would be worth the extra 500 bucks to get the extrude job as well. Also, talk to me about thermal coatings on the manifold...worth it? Advantages?
-Kyle ![]() |
#597 | ||
#598 |
That all sounds like a great idea either way. I pretty much in the process of going through everything I can to keep temps down under the hood. I'll probably follow suit with all of that.
How about extrude?
-Kyle ![]() |
#599 | |
Code:
743347-2 446179-32 53.10 71.00 56 0.60 53.90 76 0.86 743347-4 443179-32 53.10 71.00 56 0.60 53.90 76 0.64 Code:
816366-1 446179-94 49.70 67.40 55 0.60 53.90 76 0.86
#600 |
That's my bad... For some reason I thought that was larger than the 2871R, but it's larger than the 2860R.
Tags |
gt2871, gtx, gtx2867r |
