Old 06-24-2013, 10:12 AM   #1
richmond82
richmond82's Avatar
Trader Rating: (30)
richmond82 has a spectacular aura aboutrichmond82 has a spectacular aura aboutrichmond82 has a spectacular aura aboutrichmond82 has a spectacular aura aboutrichmond82 has a spectacular aura aboutrichmond82 has a spectacular aura about
Feedback Score: 30 reviews
Oil Filter Relocation,Oil Cooler and Turbo oil feed
Previously my setup was routed like this.
  1. Stock oil block plate with Oil Filter
  2. Oil feed from BLock (turbo side) going into my oil cooler
  3. out of oil cooler to turbo ATP Restrictor feed line
  4. out of turbo returning to block
Wanted to setup like this-
  1. Oil block adapter to oil filter relocation
  2. out from filter relocation to oil cooler
  3. from oil cooler to turbo
  4. from turbo back to block.
?'s that i have on this
  1. Do i plug the oil feed (from block to oil cooler currently) ?
  2. what about the oil that is to return through the stock filter plate ?
  3. IF i am using the Tomei Block adapter do i just block off the return port and use the oil out only ?
(when you take off the filter plate there is a feed and return port/hold in block)
any advice given is appreciated
Drake: 95 Swapped S15SR Z32 Swapped TT 1991Vert
richmond82 is offline   Reply With Quote
Old 06-24-2013, 11:07 AM   #2
richmond82
richmond82's Avatar
Trader Rating: (30)
Sorry for the Shit Pix was hoping to give a visual to go with the questions asked
Old 06-24-2013, 11:19 AM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Why the hell do you have an oil cooler in between the engine and the turbo?!?! You need to route the line after the cooler back into the sandwich block on the engine.
CLICK HERE!!!
Old 06-24-2013, 11:39 AM   #4
richmond82
richmond82's Avatar
Trader Rating: (30)
Talking
I do not. I was asking if this is the proper way to route with the added relocation kit/adapter plate.
Your comment answers the question. So the turbo will continue to use the lower Feed port from the block (turbo side)?
Old 06-24-2013, 12:06 PM   #5
hobbs
Trader Rating: (43)
hobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the rough
Feedback Score: 43 reviews
Oh my.
I don't even know what to say about the oil cooler inline with the turbo feed, I really can't believe anyone would set that up, pictures please?
hobbs is offline   Reply With Quote
Old 06-24-2013, 12:13 PM   #6
richmond82
richmond82's Avatar
Trader Rating: (30)
Originally Posted by hobbs View Post
Oh my.
i dont have any pics of it setup as the motor is out of the car.
Old 06-24-2013, 04:04 PM   #7
richmond82
richmond82's Avatar
Trader Rating: (30)
so far ive gotten two messages on this. Both of them were like "Woooaaahhh, what the hell? " Someone please drop proper setup education here so i can learn what the correct routing of lines is. From my understanding it goes.
IF using the Tomei Block adapter
  1. filter block out to oil filter relocator
  2. from filter relocator to oil cooler
  3. out of oil cooler back to filter block
For Turbo
  1. oil feed from block to turbo
  2. turbo back to block
Old 06-24-2013, 04:48 PM   #8
135bootleggerz
135bootleggerz is an unknown quantity at this point
some one buy this guy a kia or something
135bootleggerz is offline   Reply With Quote
Old 06-24-2013, 05:16 PM   #9
fliprayzin240sx
For Turbo
Leave the turbo lines to where they're supposed to be. Leave the turbo oil lines alone. Basically, oil feed line from the block to the turbo and let the turbo drain naturally.
You routing the oil cooler in between the oil filter relocation back to the turbo would mean you're gonna squeeze ALL your oil thru the damn turbo. Fastest way to kill everything in your car (TURBO AND ENGINE).
Like I said, route it from the oil filter block to the oil filter relocation block, to the oil cooler, then back to the oil filter block. Run the turbo oil feedline straight to the turbo. Even your current setup is baaaaaad idea. There is no need to have an oil cooler inbetween the turbo and the block, pretty much defeats the purpose of a cooler since you're only cooling the oil going to the turbo and not thru the whole engine.
CLICK HERE!!!
Old 06-24-2013, 07:33 PM   #10
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
godsmack is offline   Reply With Quote
Old 06-24-2013, 07:35 PM   #11
godsmack
godsmack's Avatar
or
Old 06-24-2013, 09:09 PM   #12
richmond82
richmond82's Avatar
Trader Rating: (30)
thanks for the offer. maybe a daiwoo...
Old 06-24-2013, 09:10 PM   #13
richmond82
richmond82's Avatar
Trader Rating: (30)
thank you for the info. was looking for a straight forward answer on this and you brought it.
Old 06-24-2013, 09:11 PM   #14
richmond82
richmond82's Avatar
Trader Rating: (30)
Talking
Originally Posted by godsmack View Post
thank you very much. I appreciate the help on this
Old 06-24-2013, 09:12 PM   #15
richmond82
richmond82's Avatar
Trader Rating: (30)
or
Thanks Godspeed. you are indeed very helpful
Old 06-24-2013, 09:16 PM   #16
richmond82
richmond82's Avatar
Trader Rating: (30)
and thats all the info i needed. Thank you Zilvia for the insight and thank you 135bootleggerz for the comedy !
Old 06-24-2013, 09:35 PM   #17
fliprayzin240sx
or
Just be weary of setting it up like this. You usually want a thermostatic filter block so it wont let the oil thru the cooler until the oil gets up to temp. Cold oil is not good for the engine since the oil is thick like molasses. With a pass thru to the oil cooler, it'll take a while for that oil to get up to temp.
CLICK HERE!!!
Old 06-25-2013, 10:22 AM   #18
richmond82
richmond82's Avatar
Trader Rating: (30)
This is the setup my sponsor had put together for me. Thank you for the info, now i am on the hunt for a Thermostatic filter block. Greddy makes a few, trying to get a good deal on one
Old 06-27-2013, 08:22 AM   #19
richmond82
richmond82's Avatar
Trader Rating: (30)
Greddy unit with thermostat purchased from 240sxmotoring - I am glad i posted this Tech thread to get on the right track - Thanks again all
MODS PLEASE CLOSE -
