Old 06-29-2013, 10:52 AM   #1
Juantwo3
Juantwo3's Avatar
Juantwo3 is an unknown quantity at this point
Cooling wiring experienced opinions
excuse me if this is in the wrong section.
does anyone have any experience using this set up?
Adjustable Dual Electric Fan Thermostat Kit, w/ relay and AC cir - Enjuku Racing Parts, LLC
right now i currently have my efans wired up to 8 gauge wire a switch inline fuse and the battery battery
i dont want to run this micky mouse wiring. i dont know witch route to go does anyone have any educated in put?
GO DUCKS!!!!!!!!!
Juantwo3 is offline   Reply With Quote
Old 06-29-2013, 11:35 AM   #2
cotbu
cotbu's Avatar
The enjuku price....ridiculous!
I have this unit works great, also has the ability to be manually turned on via A/C button, defrost or a 12v switch.
It's not a complicated setup at all either.
I would have preferred a solid state relay vs a standard automotive relay. The price listed there...., it should come with two!!
My unit is mounted underneath the core support, hasn't had an issue.
This unit is being sold elsewhere for less than $50 search more better.
Old 06-29-2013, 11:44 AM   #3
Juantwo3
Juantwo3's Avatar
thanks do you have the link for the set up your using?
GO DUCKS!!!!!!!!!
Old 06-29-2013, 11:54 AM   #4
cotbu
cotbu's Avatar
Mine is actually a hayden 3647 summit, jegs etc. Same thing..Mine is from summit.
http://www.summitracing.com/parts/hda-3647
Sent from a Highly Tuned SIII using Tapatalk HD
Old 06-29-2013, 12:42 PM   #5
Juantwo3
Juantwo3's Avatar
Can it support 2 fans or just one?
GO DUCKS!!!!!!!!!
Old 06-29-2013, 12:58 PM   #6
cotbu
cotbu's Avatar
Dual means 2, that link has a description and even a manual IIRC
Old 06-29-2013, 01:27 PM   #7
S14DB
AFC #1
S14DB's Avatar
Yeah, they are the same company.
It has two leads on it for fans. So you can trigger a second.
The key thing with this kit is the adjuster. I never needed to adjust it but, the thermistor they use is a better quality than the kits that use the on/off style thermal switch to actually trigger the fans. The thermal switches have a lower service life and if they aren't activating when you want them too you are screwed.
My only problem is been finding a good A/C trigger. I don't want to splice the triple pressure switch as recommended in the manual. I was going to use the stock low speed wire but, it doesn't always seem to be on...
Old 06-29-2013, 01:37 PM   #8
Croustibat
Solid state relay is a bad idea on a car, as it always leak current and a battery can deplete quite fast.
Old 06-29-2013, 03:16 PM   #9
cotbu
cotbu's Avatar
I know all the characteristics of a solid state relay, use them for HID quad projectors to h4 with working high and low beams. I know about the leakage as well, I just don't have a battery depletion problem.
I just think it would be more durable, when sliding the car around, but that's probably because I only have it zip tied down.
Old 06-29-2013, 06:36 PM   #10
S14DB
AFC #1
S14DB's Avatar
High amp switching consumable I would rather have a replaceable relay than an expensive solid state. For electrics like the HID example solid state would be better.
