KA t25 Turbo Kit Part Out
FS: t25 turbo kit for s13 ka24de motor. Buy everything that is still available today for 500. Otherwise parts are OBO Since no commitments have been made I will be parting out.
Located in Berkeley CA next to UC campus. m. Turbo: $150 Garret t25 turbo (with intake elbow, no hot pipe elbow),18" rubber oil return line (to be cut to fit however you'd like), Oil feed line with T for oil pressure sensor. SOLD Hot pipe and intake elbows Piping: SOLD Custom Mid mount intercooler setup with all couplings and blow off valve (not installed, ebay brand) >Includes hot pipe turbo elbow since it is rewelded specifically for this mid mount SOLD stock sr20 rubber intake $30 n60 MAFS (no pigtail but if not sold soon I may go to the junkyard and nab one) Fuel: $80 Q45 370cc injectors (will come with brand new in bag Orings) SOLD adjustable fuel pressure regulator with fuel rail adapter with gauge (brand new) SOLD Walboro 255lph fuel pump Exhaust: Sold ISIS v2 Manifold (clears transmission BMC) SOLD sr20 Stock turbo elbow (clears transmission bell housing and steering column) SOLD 3" down pipe with wideband bung and flex pipe MISC: $40 Oil pan (untapped but an extra so you can have it tapped before installing your kit) $10 Boost gauge (off brand I believe, with vacuum T and hose) $25 Ricer JDM tachometer with oil pressure, oil temperature, water temp, and shift light. Things not pictured: Fuel pump, Oil T, untapped oil pan, injector orings, ![]() ![]() ![]() ![]() ![]() ![]() ![]() -Also have 3 extra 370cc injectors (also new o rings in bag) $25 shipped each There are still two minimum things missing; and oil return bung and a legitmate tune. I recommend this tune as it is the one I ran on another car. Used - KA24DET, T25, ECU | RS-Enthalpy In addition, once the car is on the road, it is still highly recommended you get a wideband and oil gauges. Thank you for your consideration. Last edited by milto0n; 08-23-2015 at 05:42 PM.. |
#13 | ||
How much for the hot/cold pipe inlet/outlet elbows shipped to 92129? Sorry won't part the piping from the intercooler. |
