Old 07-20-2013, 12:47 PM   #1
Bacon_Fish
Bacon_Fish is an unknown quantity at this point
positive camber...
a week ago i hit a "trench" in the road.
destroyed my right front coilover..bent shaft..got a new one.
put wheel on..still camber.
adjusted camber plate..still pos. camber.
then,ball joint looks bent.
control arm isn't bent,but,is there anything else that would
cause thise excessive amount of camber?
help meee,please(:
Bacon_Fish is offline   Reply With Quote
Old 07-20-2013, 02:57 PM   #2
jr_ss
Your control arm is bent and/or the bolt and crossmember are fucked up.
Old 07-20-2013, 03:00 PM   #3
Bacon_Fish
i checked,everything is good.
i did find the problem.
my guy that got my coilover,gave me one that has the bottom
for a the left side..so the bottom that mounts to the spindle is wrong..its a left not a right.
therefor causing the hub to be off,causing my wheel to stand the opposite way.
Old 07-20-2013, 03:01 PM   #4
xoxide
xoxide's Avatar
xoxide is an unknown quantity at this point
^Lower mounts on front coilovers arent directional. Left and right doesnt matter.
xoxide is offline   Reply With Quote
Old 07-20-2013, 03:05 PM   #5
Bacon_Fish
if i flipped this one over it would put the brake line bracket on the opposite side.
Old 07-20-2013, 03:13 PM   #6
jr_ss
It doesn't matter though because other than the brake line bracket they are identical. I'm telling you right now that your lower control arm is bent. Pull it off and set it on a flat surface. If it doesn't sit flat, it's bent. I had a similar issue, you can't visually tell if it's bent or not.
Old 07-20-2013, 03:15 PM   #7
vehicle336
vehicle336's Avatar
vehicle336 is an unknown quantity at this point
I'd recommend taking the time and money and having the whole car re-aligned. Who knows what else has been knocked out of spec or wasn't in spec to begin with.
May the bridges I burn light the way.
vehicle336 is offline   Reply With Quote
Old 07-20-2013, 03:17 PM   #8
Bacon_Fish
i measured the control arm and measured an old one,they were the same,but i will take it off and check;
if they're identical,how would it work if i flipped it over? the bracket ends up on the other side from the brake line.
Old 07-20-2013, 03:19 PM   #9
Bacon_Fish
before the coilover got bent,everything was to spec,everything aligned
Old 07-20-2013, 03:21 PM   #10
jr_ss
You're not getting what I'm telling you. Minus the brake line bracket, the lower mounts are identical. Meaning you can swap them left to right and it not being an issue.
Old 07-20-2013, 03:32 PM   #11
Bacon_Fish
yea i get that,i can cut the bracket off and weld it on the other side..done.
or i can just get another one.
Old 07-20-2013, 03:47 PM   #12
rebornS14
rebornS14's Avatar
rebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of light
Send a message via AIM to rebornS14
i would like to know HOW you measured these lca's
rebornS14 is offline   Reply With Quote
Old 07-20-2013, 03:55 PM   #13
Bacon_Fish
with a tape measure?
thats besides the point,its not bent,the bolt is not bent,i already know what the problem is.
its being taken care of(:
Old 07-20-2013, 04:07 PM   #14
jr_ss
So enlighten us, what is the problem?
Old 07-20-2013, 04:11 PM   #15
Bacon_Fish
the bottom mount that we've been arguing about..
im getting the one for the right side of the car..
Old 07-20-2013, 04:15 PM   #16
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Maybe his lower mount is upside down. Some coilovers have the upper bolt hole offset a bit to give negative camber, so upside down it would give positive camber. Though I am not sure if it would be that noticeable.
Old 07-20-2013, 05:12 PM   #17
jr_ss
It wouldn't be able to move at all if that were the case... He'd be pulling on the control arm, tension rods, and steering linkage to move it that way.
I highly doubt its the coil mount. Seriously, pull the LCA out and lay it on a flat surface. Guarantee you it's bent.
Old 07-20-2013, 06:22 PM   #18
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
First off this belongs in tech section not chat.
Second the mount being right or left won't dick, if it does fix it, it is not because the side it was supposed to go on but some other crap being wrong with the mount. Ignore the brake line bracket as a lot of coilovers don't even have them and don't have L/R stamped on the mount, how are you supposed to know what side if they were not identical? And you bent a ball joint but did not manage to bend the LCA, how the fuck did you get that lucky?
Did you stop and consider if you swear up and down your control arm is not bent that you may have instead bent your crossmember or the car itself? Could have fucked up the strut tower or the frame.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
Old 07-20-2013, 06:25 PM   #19
Bacon_Fish
i looked..ball joint is not bent..after replacing a coilover..nothing else is bent.
im 110% sure that the mount is wrong,i will further inspection once i get the other mount.
other then that nothing is bent.
Old 07-20-2013, 06:48 PM   #20
lalo167
lalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the rough
I had the same problem when i installed my coils. You just need to make sure the offset hole on the bottom mount is on the top! Not the bottom, when you tighten the bolts make sure you push it back.
lalo167 is offline   Reply With Quote
Old 07-20-2013, 08:02 PM   #21
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
If you freaking hit hard enough to fuck up the shock, your LCA is fucking bent. No butts or ifs about it. I've hit shit hard enough before that the damn crossmember got tweaked too.
CLICK HERE!!!
Old 07-20-2013, 08:16 PM   #22
xoxide
xoxide's Avatar
I truly do not understand why people ask for help/advice but wont listen when you offer it.
Old 07-20-2013, 08:23 PM   #23
Bacon_Fish
i was asking until i found out what the problem was,people reaponded prior to me finding out what was wrong
Old 07-20-2013, 08:27 PM   #24
Bacon_Fish
how about this..i take off the LCA and then personally let you know that its not bent?
deal?
Old 07-20-2013, 09:15 PM   #25
fliprayzin240sx
deal?
Take both side off, lay them next to each other. Better yet, find a spare LCA and compare them. You gotta understand something about these cars, parts like the LCA are designed to bend and break to minimize damage to the frame of the car. Would you rather replace a $150 part or a tweaked frame? Thats one of the reason running solid/aftermarket suspension pieces are bad, you wreck the car, you'd damage alot more than just the suspension.
But hey, the fuck do I know right? Its your car, I'm just letting you know what I've experience from fucking with S14s for the last 12 yrs and crashing from time to time.
CLICK HERE!!!
Old 07-20-2013, 10:05 PM   #26
jr_ss
Flip, you're preaching to the quire. Apparently he knows all and an arbitrary "measurent" confirmed it wasn't bent.
GTFO man, others are confirming what I stated from the get go. Pull the fucking arm and check it out. Once you confirm it's fucked, you can come back here with your tail between your legs and tell us we were right.
Old 07-20-2013, 10:08 PM   #27
zerodameaon
Haha that will never happen, he will either just say it was his mount being from the wrong side or he will never come back.
Old 07-20-2013, 10:08 PM   #28
Bacon_Fish
i'll pull it off and take 50 pictures of them side to side,just so i can end all this unnecessary arguing.
Old 07-20-2013, 10:10 PM   #29
Bacon_Fish
even better,i'll take it off and bring it to you..how does that sound?
just so you can see it.
Old 07-20-2013, 10:10 PM   #30
xoxide
xoxide's Avatar
^That would be greatly appreciated.
