Old 07-21-2013, 11:19 PM   #1
s.tamayo1991
s.tamayo1991 is an unknown quantity at this point
Wheel rub
So i have a base model s14.. 4 lug SMH. Anyway i have the hubs and some stock SE wheels im going to slap on.. my car has Type 2 coilovers rite now. 2 Questions
1) The wheels rite now are the same size as the SE wheels. The back tires are maby 3 cm away from the coil overs, Cant tell for sure. How wide of a spacer would i need to clear a 225 tire in the rear? Does anyone have experience with this?
2) Will 225 tires rub in the front? Will i need a spacer? Im also installing Tien inner and outer tie rods, will that be an issue?
Thank you
s.tamayo1991 is offline   Reply With Quote
coil overs, rubbing, se wheels, type 2
